03-29-2012, 05:21 AM
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
Concrete roads and porpoising
I have played with my WD several times. Add links, take away links but still all that bouncing. Paved roads are just fine. But concrete roads are bad. Is it something I'm doing wrong or should I always make sure I use the men's room before I go?
Judging a person does not define who they are, it defines who YOU are.
03-29-2012, 05:27 AM
1995 30' Excella
Bowie
, Maryland
This is usually a sign that there's not enough weight on your lifter bars. Your bars may be too heavy or too light for your trailer, too. To get more detailed, the experts will need to know what hitch you have, what weight lifter bars you have (usually marked on them - for example mine are 1200 lb), and ideally the tongue weight of your trailer (if you know it).
I was having the same problem, but I tightened up my lifter bars and it has totally gone away.
You may also have too much weight in the back of the camper.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
03-29-2012, 05:41 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
Ricky
03-29-2012, 06:02 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
We have a section of Interstate 90 here that porpoise's our Burb whether towing or not. The frequency of the seams interacting with the wheelbase.
Slowing to 55mph is the best option to reduce the aggravation while towing.
That being said, it is very important to have the proper weight returned to the TV steering axle, with a level rig, TV & AS.
03-29-2012, 06:35 AM
Wise Elder
2010 30' Classic
South of the river
I have found that there are particular roads that cause porpoising no matter how the WD is dialed in. The only things to do about it are slow down or take another road.
Stiffer rear shocks might help matters somewhat, too, did that in my pickup. It helped a little.
03-29-2012, 08:56 AM
2012 25' FB Eddie Bauer
Eugene
, Oregon
I had that problem once on I-90 traveling east just inside of Montana. The right hand lane was so bad (at almost any speed) that it was getting uncomfortable to ride in the car. The left hand lane was perfectly fine. There was little to no traffic. Any guesses as to where I was driving? ;-)
Anywho, I don't think that it had anything to do with hitching, it was just a bad stretch of road.
Are you having these issues all the time or is it only in certain areas?
03-29-2012, 09:14 AM
St. Cloud
This is a common problem on aging concrete highways (and sadly, some newer ones). It seems that the middle of each concrete slab is depressed in relation to the edge. Once on I-35 in southern Minnesota I saw some nice grinding at the junction of each slab and that sure did ride nice! The second solution comes later in life when they give it an asphalt topcoat.
MN-23 between Ogilvie & Mora is very bad and a common route between us and Duluth/the Northshore. I do a personal detour to avoid it. About the very worst I've seen on fair-condition interstates is I-90 between Madison, WI, and Rockford, IL. I-90 between Rochester, MN, & LaCrosse, WI, has been written up but has nothing to compare the beating I get both directions on the Madison-Rockford section!
http://www.airforums.com/forums/f42/...oad-34017.html
http://www.airforums.com/forums/f464...nco-40014.html
http://www.airforums.com/forums/f464...mph-61233.html
These are real rivet breakers! When I find myself on one I've had to just get in the right lane and go as slow as 35-45 mph and just get through it. Detours are hard to come by when you're on a 4-lane...
03-29-2012, 09:32 AM
2008 30' Classic S/O
Dearborn
, Michigan
"porpoising" seems like such a graceful description for what I've experienced...
maybe we should call it emesising
Dolphins Porpoising - YouTube
03-29-2012, 09:35 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
"Any guesses as to where I was driving? ;-)"
Butte...
03-29-2012, 10:56 AM
Trabuco Canyon
I think there's some combination of wheelbase, spring rates, and who knows what else that causes porpoising in some trailer/tow vehicles on certain stretches of concrete highway.
My 1999 F250 super cab and Airtream would porpoise between about 50 and 60 mph. I tried to run it at 62 which is right on the edge of a ticket here in CA, to avoid porpoising. It was not always possible to go that speed due to traffic. I tried hitch adjustments, shocks (Bilstein) but nothing seemed to change the fundamental porpoising.
I replaced the truck with a Tundra, nearly the same wheelbase, and it doesn't porpoise in that speed range. Perhaps it porpoises in a different speed range, but it isn't one I drive in. For me it was a huge relief the first time I towed with the new truck.
The porpoising is surely uncomfortable, and at its worst for me it bordered on dangerous or damaging. If there's some way you can tow test a new tow vehicle (when in market), I'd surely recommend it over rough concrete. Probably every rig has its harmonic frequency and you don't want it to be at speeds you drive.
03-29-2012, 11:42 AM
moderator
2016 27' International
Wilton
The airsafe hitch really helps with that condition.. atleast it made a huge difference in my case.
Vinnie
03-29-2012, 11:49 AM
1999 28' Excella
Frederick
, Maryland
Don't know what Tiger tows with, but like tpi, in my experience I have found that a 3/4 ton is much more likely to porpoise, towing or not towing than a 1/2 ton. In that case it would seem that the "stiffer" less "forgiving" suspension is part of the problem. This happens to me quite often on the westbound span of the Chesapeake Bay Bridge. The concrete sections all have pretty good bumps as you move from one to the other. I just slow down and it pretty much goes away. For example: last weekend coming back from Assateague the wind was gusting to about 40 mph, so I drove much slower than usual over that rather high (186ft above sea level) bridge and didn't experience nearly as much porpoising as I do at my normal speed. We don't have a lot of concrete roads around here, but I know on the newer concrete Rt 50 Salisbury, MD bypass, it rides nice and smooth, same on the newer Rt 50 bridge at Cambridge, MD.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
KC3MAP
On internet forums, please research and separate the wheat from the chaff (including mine!)
03-29-2012, 12:35 PM
Eugene
, Oregon
Small World!
Butte...
Ha! Sounds like we were "enjoying" the same stretch of road. If I remember correctly, they were in the process of repaving the pass. Maybe there's hope that they'll keep going and fix that section.
03-29-2012, 12:47 PM
1981 31' Excella II
New Market
, Alabama
Put some heavy duty shocks on the back of your tow vehicle. The purpose of a shock is to damp out periodic motions. The load bars only add spring rate and don't add damping. I believe Airsafe hitches provide some damping. Too little weight distribution can contribute to this. A little porpoising is probably not a bad thing. If the system is too rigid you are transfering a lot of stress to the frame of your tailer and tow vehicle.
Perry
03-29-2012, 01:11 PM
2012 25' Flying Cloud
Battle Lake
With single axle and tandem axle Airstreams in past few years, we had same bouncing on the same stretches of road. I don't think its good for the truck, trailer, or us. We either slow down or if still rough, detour around it.
doug k
03-29-2012, 03:55 PM
2020 30' Classic
Derwood
, Maryland
My 2011 F350 SRW does fine over those bridges when towing the 30' Classic - maybe some of the newer Super Duties and/or 2500 or above trucks have a bit better suspensions? :-)
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
03-29-2012, 04:17 PM
Moderator Emeritus
1964 26' Overlander
Anna
Porpoising was a constant problem with only one of my tow vehicles, and that was my 1995 K1500 Z71 Chevrolet Club Cab Pickup. The most objectionable stretch of highway was US 151 from DuBuque, Iowa to Madison, WI - - then I-90/I-39 into Rockford, IL from Madison, WI - - speed made no difference nor did hitch adjustment -- softer rated shocks did help some as did derated rear springs on the truck but it was never completely remedied. All I had to do was switch to a different tow vehicle -- the problem disappeared when I switched to my 1984 Jeep Grand Wagoneer, my 1975 Cadillac Eldorado Convertible, my 1965 Dodge Coronet 500 Convertible, or the problem disappeared when I traded the pickup on a new 1999 K2500 Suburban in April 1998. My conclusion was that it had something to do with the harmonics created by the distance between the tow vehicle axle and the trailer axles ('64 Overlander) in the pickup that was not replicated in any of my other combinations -- all being towed over the same stretch of highway.
Kevin
P.S.: I have had no problems with the Suburban and either of my coaches porpoising anywhere that I have traveled from the Blue Ridge Parkway and points to the West. The pickup, on the other hand, proved problematic with either coach on nearly any route having concrete surfaces with prominent expansion joints - - porpoising would be immediate and remain a constant until a smooth strech of asphalt was encountered.
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
03-30-2012, 07:02 AM
1974 Argosy 26
Morrill
, Nebraska
It has to do with the space between the axles of the TV and the coach. The slabs of concrete on the highway have been shifted by the heavily loaded semi trucks. This is why the right lane is always worse.
It happens even when you are not towing the trailer when the axle spacing on the TV is the right length.
03-30-2012, 07:19 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Even though it was over 10yrs ago with our 63 that Butte-ful section of road still stands alone, sounds like not much has been done since.
03-30-2012, 07:58 AM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
steel road plates
“porpoising” was the December night three years ago we were towing westbound across the downhill side of the Tappan Zee Bridge and suddenly found the outside lane, without any real warning, fully populated with the dreaded “steel construction plates”. I was pulling the 31’ 1976 Sovereign at about 40 mph.
I was on the brakes immediately, but not before we already “rolling” over the second one. those plates felt like they had to be 3 or 4 inches tall....
for more than just a brief moment, I thought the trailer was coming over my shoulder!!!
thankfully, it stayed behind the truck….
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
