Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 12-13-2003, 10:05 AM   #1
richardjohnsonlaw
Profile:
Post color code for hookup plug
I have a 99 28 ft. Excella and need to replace the hookup plug. Does anyone have the code for where each wire goes on the new plug? Thanks, Richard Johnson
Richard P. Johnson
richardjohnsonlaw is offline   Reply With Quote
Old 12-13-2003, 10:44 AM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Welcome aboard Richard! Be careful though -- these forums are addicting. Just remember to take your "baby" out camping.
The variety of Airstream wiring schemes can be seen at: http://www.airstream.com/product_lin...faq.html#plugs
Details on the modern 7-way connector can be seen at: http://lib1.store.vip.sc5.yahoo.com/.../wirecolor.gif
Old 12-13-2003, 10:59 AM   #3
Navigator
Profile:
Oh Dear!
Some one disconnected the hitch, and drove off with the umbelical attached!
Ben there, done that.
Navigator is offline   Reply With Quote
Old 12-14-2003, 10:24 AM   #4
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
thnx
i have been looking for hook up info.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 12-14-2003, 04:11 PM   #5
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
You have to look at info for both ends
The corporate Airstream site referenced earlier in this thread gives the diagram for the plug at the Airstream end that varies with the model year. You have to check your vehicle for that end. Recent GM trucks and SUVs with factory harness installations do a good job with their 7 wire plugs by having a clear diagram on the protection cap. I don't know how other manufacturers handle it.
My 1971 plug was totally different than my Trailblazer. It appears the 1999 Airstream plug is closer to my Trailblazer but it is not exactly identical.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 12-14-2003, 08:15 PM   #6
CanoeStream
Images: 13
Okay, I had the info quickly at hand because I soon have to go on the road and make the conversion from the 1976 seven round pins to the modern 7-pin flat plug. Can anybody say how readily I will be able to take apart the old trailer side plug? Or is it molded right around the wires and plug body?
If it's the latter I'll have my VOM along with and can match wires to plug position, thus matching function from the diagrams...
Any clue on how the "1966 Thru and Including 1981" trailer side plugs were put together?? Thank you!
Old 12-14-2003, 08:28 PM   #7
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
The old plug
Bob,
They come apart easy. I'll post a picture here of my 1971 plug that was the same at both ends of the cord. I took the vehicle end off and attached the wires to a modern plug that fit into my Trailblazer. As I mentioned earlier you have to realign the wires and even ignore the colors. You just have to figure out the matching combination.
Davydd
Old 12-14-2003, 08:40 PM   #8
JPAIRSTREAM
JPAIRSTREAM's Avatar
Profile:  1972 31' Sovereign
, Ohio
Images: 47
http://www.airstream.com/airstream/p...lug1966-81.pdf
JP
JPAIRSTREAM is offline   Reply With Quote
Old 01-10-2004, 10:40 AM   #9
Theo
Confused & Wandering
Theo's Avatar
Profile:  1993 34' Excella
Right here, , where ever I wake up
Useful knowledge to take with me to pick up my A/S next week. This site rocks..
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
Old 01-10-2004, 11:51 AM   #10
CanoeStream
Images: 13
Theo -- I did this recently. Your perspective on the diagrams may be mirror imaged from what the website intended. Just keep an open mind. Verify your tow vehicle's wire functions -- the 7-plug hinged plastic cap has a diagram on mine. Airstream's listed wire color functions for your model-year are quite accurate.
I needed to change the terminal connectors on the trailer end and was aided greatly by bringing an assortment along with a wire stripper/crimper. I found one like this link at my local fleet store (hardware, Home Depot, etc). You need three size 12-10 and four size 16-14 spade connectors I believe -- but bring spares if Murphy rides along.
We blew a fuse in the truck changing bad running light bulbs with them turned on. Also never test the breakaway switch with a Prodigy brake controller turned on -- it'll fry the brake controller.
Old 01-10-2004, 11:03 PM   #11
CanoeStream
Images: 13
Theo again -- I remember now but don't recall how I forgot so easily. It was necessary to cut off the terminal connectors from the trailer line because they would not fit as a group through the back end of the 7-way RV connector. Guess I could have left one or two...
BTW you only need 6 connectors because the 7th center-post wire was held by a screw (at least in the one I bought from rjays.com).
test
