03-16-2015, 01:01 PM
2015 25' Flying Cloud
Apollo Beach
Circular base on jack
Just purchased a 2015 FC twin rear bedroom and have installed a pro pride sway bar/weight distribution hitch 1400lbs. My question is about the circular foot on the jack. Do most of you with the pro pride find it necessary to remove the circular foot? or is it not necessary. I noticed on the install video Sean had removed his. Thanks
03-16-2015, 01:11 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Our 2015 FC 25FB also came with one of those big round feet on the tongue jack rod. I removed mine immediately on the dealer's lot as it was in the way when I was installing the Hensley. We also use a "tongue twister" under the jack. It would not work with that pie plate on it.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-16-2015, 01:12 PM
2007 22' International CCD
Corona
Mine flat falls off when I raise the jack. I find that the space between the bars is a bit narrower than the jack base and I have to slip it in from the back. If you can retract it fully so it won't interfere with the WD bars in a turn it shouldn't be an issue. Otherwise, remove it. I put mine in the TV when we travel.
03-16-2015, 01:14 PM
Corona
For that matter, the foot was in the way on our old non-ProPride WD hitch. It's hand in soft ground, however.
03-16-2015, 01:25 PM
2012 25' Flying Cloud
Battle Lake
The foot is not attached, it should fall off when raising the jack. Unless it sticks as they often do, then knock it off.
Be sure to raise the jack post higher than the ProPride w.d. bars or they will contact the bars when making turns with the trailer. Not a good thing.
cheryl k
03-16-2015, 01:28 PM
Santa Rosa Beach
When we picked up our 2015 at the dealer, the pie plate was bolted to the jack shaft. It was easy to remove with w wrench.
Brian
03-16-2015, 02:29 PM
2012 25' FB International
Trent Woods
, North Carolina
Yes, I remove mine when driving. There is a pin to hold it so I reinstall it before unhitching.
Larry
03-16-2015, 02:38 PM
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo
Brian
I also use the tongue twister and have it placed on a 2x8 between it and the ground. Really helpful when hitching up the Pro Pride. My back up camera is great but a few twists of the tongue twister lines up the stinger and the head perfectly. While I'm at it, I painted the 2x2 part of the stinger bright orange and this makes quite a difference looking through the back up camera when hitching up in limited light.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
03-16-2015, 04:22 PM
Apollo Beach
>>ron<<
My wife suggested painted something bright to see in the back up camera as you have done. Thanks will try you suggestion since it sounds like it works.
03-16-2015, 04:24 PM
Apollo Beach
Thanks for the suggestions. I noticed the bolt holding the round thing on but wanted to check with you all before doing anything. Will check out the tongue twister.
03-17-2015, 10:22 AM
2013 30' Classic
Greenwood
, Mississippi
My jack foot comes off and goes into the storage compartment when underway. I was under the impression they were all like this.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
03-17-2015, 01:56 PM
2008 34' Classic S/O
Arnprior
, Ontario
mine flew off after the second time I hitched up to the new Hensley. I mean 'flew off' when it got caught up on my W.D. bars on the way up. I carry a nice piece of 4x4 and it works well.
03-17-2015, 01:59 PM
Trent Woods
, North Carolina
Well I learned about the tongue twister on this thread, after 2 years of the plain way. I have one coming this week!
Larry
03-17-2015, 02:31 PM
2015 28' Flying Cloud
2018 33' Classic
Cumming
, Georgia
Tongue Twister on ProPride
Pardon my ignorance, but what is this Tongue Twister? I have ProPride being installed in a few weeks on my 2015 FC 28.
03-17-2015, 03:20 PM
2005 28' Safari S/O
Paradise
The tongue twister is a jack stand device that allows you to wrench the hitch point right or left. It's handy for PP and Hensley users as you don't have to keep moving the tow vehicle to align the stinger with the hitch head if it's within a couple inches. BAL Tongue Twister 28100 | Hitch Helper | Helps To Align Trailer for Hitching
I use one as well but found it to be a little unstable on occasion from front to back. I made a base for mine out of some scrap 3/4" plywood. Much better IMHO. The 4x4's in the pic are not part of it.
Steve
"THE OLDER I GET, THE BETTER I WAS"
03-17-2015, 04:04 PM
Santa Rosa Beach
We've been using a tongue twister/hitch helper for nine years now. It's the bomb to get that Hensley right or left an inch or two.
Brian
03-17-2015, 04:13 PM
2011 28' International
Chatham
, Ontario
Interesting. I'd never heard of these devices but they look like a Hensley/ProPride users dream.
03-17-2015, 10:39 PM
1999 34' Excella
Hillsboro
Here ya go..
BAL Tongue Twister to Adjust your Trailer Tongue - PPL Motor Homes
Peace and Blessings..
Channing
WBCCI# 30676
03-17-2015, 10:41 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
If you don't have a back up camera on your TV you are missing a real treat when placing the stinger in the slot on the first attempt with a Hensley or ProPride. And, if you have one, all you need is a switch to use a camera on the rear of your TT. That's a double treat. I got all my stuff for that at CarToys. They are probably cheaper online, but I needed technical help and advise. You can pay for your backup camera if you avoid just one backing accident. That is why I have both!
03-18-2015, 04:19 AM
2011 30' Classic
1993 32' Excella
Largo
Great idea. There are times when I unhook that there is a little resistance due to the trailer and the tv not being in the same plane side to side with the result that there is movement of the tongue twister forward.
>>ron<<
