01-21-2016, 01:40 PM
2018 28' Flying Cloud
Newnan
, Georgia
Choosing the proper hitch
Okay, this may be a dumb question but I have never towed anything other than a U-Haul before. We got a 1979 Tradewind and are making plans to go pick it up. I looked up the details and found that the dry weight is 4005 lbs, hitch weight is 670 lbs and the ball height is 19.5 in. I'm assuming that, when getting a hitch, I would look for one that is capable of towing a loaded trailer, not just the rated to tow the dry weight. (See, I told you this may be a dumb question). Anyway, I read somewhere that getting a hitch rated for a much heavier weight than I'll be towing is just as bad as getting one that isn't rated high enough. Is that true? If so, can anyone tell me a ballpark weight I can expect the trailer to weigh when loaded? And, can you recommend a weight distribution hitch that will do the job and is easy to use? We are eager to pick up are new trailer and getting to work on it so we can enjoy traveling the country. Thanks for any help and advice you can give.
01-21-2016, 06:17 PM
1986 31' Sovereign
Miami
A rough guess would be empty weight plus 1500#. Figure 12% of that total as tongue weight.
I would get 600# bars.
Mike
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
01-21-2016, 09:31 PM
2012 25' Flying Cloud
Battle Lake
Read this article and you will know more about selecting weight distribution and sway control hitches than most.
https://www.etrailer.com/faq-weightdistribution.aspx
Doug and Cheryl
01-22-2016, 07:19 AM
Newnan
, Georgia
Thanks for the responses. This will help a lot.
01-22-2016, 07:27 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Mike
I thought this sounded correct.
But when I ran the numbers through the Equalizer Selection Tool, the suggestion leans toward the 1,000 bars.
@living.somewhere.yonder | Instagram
01-22-2016, 10:39 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
A Reese straight line with 800 lb bars will do a good job with a 25'. Too heavy bars combined with a very stiff truck like a 250 is thought to possibly damage a trailer but I have towed 60000 miles or so with a Dodge 2500 with the Reese hitch and 800 lb bars and have not had a problem.
01-22-2016, 10:44 AM
2013 30' Classic
Greenwood
, Mississippi
Many times a weight distributing/sway control hitch comes with the trailer when you buy it. Do you know for sure a hitch is not included?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
01-22-2016, 10:54 AM
Wise Elder
2010 30' Classic
South of the river
Correct bar selection is widely debated. I don't think it matters that much.
Typically the dry weight in the specifications is less than the dry weight of the trailer as delivered. Typically trailers gain weight over the years from repairs and upgrades. You can figure water at 8# a gallon, propane at 4# a gallon, 200# a person for stuff, and 200# for baseline "stuff" beyond that. That will get you close.
But you should take your trailer over the scales early and often so you know for sure.
01-22-2016, 03:54 PM
Anna Maria
You sure opened up a contentious subject. Put your seat belt on.
01-22-2016, 03:59 PM
Anna Maria
With the Equalizer you should get as close to the actual weight as possible. You go over too much and you will get rivet popping rides. I made that mistake and even my shower door fell down.
01-22-2016, 06:43 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Aww! The voice of experience!
"Good judgement is the result of experience; experience is the result of bad judgement." (Transport Canada
01-22-2016, 08:21 PM
1977 Argosy 28
Euless
Hitch and bar selection and suggested reading
These articles by Andy Rogozinski are suggested reading before buying a hitch and you tow vehicle weight should be taken into account.
The hitch torsion bar story
http://www.inlandrv.com/articles/hitch-torsion-bar-story.html
and towing myths
http://www.inlandrv.com/articles/towing_myths.pdf
What weight bars you use is tied to your tow vehicle weight. Heavier tow vehicle = lighter bars.
The goal of the bars is to transfer some of the tongue weight and lower the front of the tow vehicle. My 2013 Tundra is close to the trailer weight and my trailer is 4300# empty and about 6000# loaded with full water tank (front) and full propane tanks, but, my tongue is light at a measured 540#. I have both 750 and 1000# bars and tried both. Everything I read said 750# bars should work but I could not get the front to come down. With the 1000# bars I was able to get the front of the truck within 1" with the rear.
I was concerned with the heavier bars but after 8,000 miles towing I have had no popped rivets and nothing is out of place unless I hit a big upheaval in the road. My hitch is the original 1977 Eaz-lift hitch and I have never had any sway or wind problems.
01-23-2016, 06:32 AM
2015 23' FB Flying Cloud
Sacramento
We were sold Blue Ox by the AS dealer. It is totally adequate for towing the weight of our trailer, but it is so low to the ground that we scrape the ground even on slight dips out of gas stations regardless of how slow we go. We can't wait to get rid of it.
01-23-2016, 07:47 AM
2016 25' Flying Cloud
Holly Springs
, Mississippi
This is an excellent question.
I have just finished spending the past few weeks reading everything I could get my hands on, and corresponding with a number of users, regarding weight distribution hitch selection. Andy Thomson at CanAm suggested an Eaz-Lift hitch with 1400# bars, plus a pair of Husky sway bars (this is for an F-150 crew cab 4X4 and 25' Airstream). His observation was that it takes this strength bars to transfer enough of the high tongue weight to the front of this somewhat long wheelbase TV. He likes the Husky sway bars because they are quieter than others.
In the end, I essentially followed Andy T's advice. I chose round bars because they may ride somewhat "softer" than trunnion bars. Rather than the Eaz-Lift, I chose Curt because I wanted grease zerk fittings in the head and I liked the way the torsion bars are released, but I am using the Husky sway bars. Frankly, I couldn't discern much difference between the various round bar heads, except the Reece head is forged while all the others are welded steel. Of course, some claim "4-point" sway control like Equal-i-zer and a couple of others. Blue Ox claims built in sway control because its chains are tightened close to the take-up bracket. It may be worth noting that Sean and Kristy, of Long Long Honeymoon fame, use a Reese round bar hitch, but not dual cams--he selected just one sway bar rather than two for his 25' Airstream, and they have towed in all 49 states.
I rejected the ProPride/Hensley because I didn't want any more tongue weight, not because of cost. I opted out of the Reese dual cams for reasons not especially relevant here.
Andy R. at Inland suggests the tighter sprung the TV, the lighter weight the torsion bars should be. He's the pro and I'm not, but the physics imply that wheelbase is important. That's but one reason I followed Andy Thomson's advice.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
01-23-2016, 08:55 AM
Anna Maria
You know how it is.
The tongue wight on my 30' International was around 890 Lbs. So in my infinite wisdom I thought the 800 pound bar would be marginal so I chose the 1,200, the more better. It took me a while to realize why the ride became so stiff.
Changed back to the 800 pounder and it worked beautifully.
01-23-2016, 09:35 AM
Battle Lake
I've often wondered if 800# w.d. bars raised to the limit of their range in vertical movement would actually ride softer than a 1200# w.d. bar raised to half of their range of vertical movement?
My limited mechanical reasoning tells me no, get the size bar you need for your tongue weight and truck bed load. Restoring the front axle weight (as recommended by the tow vehicle manufacturer) is the goal.
In the case of heavy duty truck suspensions, heavy unsprung truck axle weight you may not be able to achieve a softer ride for your Airstream no matter size of the w.d. bars.
In the case of a long wheelbase tow vehicle, you may need a heavier w.d. bar than a shorter wheelbase vehicle to restore front axle weight. Suspension stiffness may also make a difference.
Select a w.d. bar based on best information; scale weights or wheel well measurements will determine if the bar is restoring enough weight to the front axle.
We were not able to get the best handling, braking and ride until we got our weight distribution right.
Doug and Cheryl
01-23-2016, 10:55 AM
Oswego
I can tell you that my 600# Reese DC bars were perfect for my 850 tw classic (before I got the hensley )
-Rich-
01-23-2016, 11:03 AM
Oswego
See pic. This was on an Escalade or Yokon XL Denali. I towed with both and can't tell in the pic. So, pretty long wb and soft suspension.
-Rich-
01-23-2016, 12:15 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Often overlooked.......
........RECEIVER DESIGN.
The OEM hitch on our 2500 Burb struggled to transfer enough weight even when using haha 1400b bars.
Short mount arms= less purchase.
Longer arms = 840lbs moved with 1000b bars plus a much better ride.
01-23-2016, 02:37 PM
2012 27' Flying Cloud
W
, New England
Apologies for the hijack here - but I can totally see the difference in those 2 receivers - with the second one installed (on the same Burb) does that change the tow ratings, the tongue weight capacity, neither, both, something else? Thanks!
