Old 10-11-2015, 12:04 AM   #15
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Airstream Service recommends and installs DirectLink controllers. They are connected to the TV OBD-II system . Mine works great with the EOH set up. In fact, with the Banks Speed Brake, I have to keep an eye on the rear view camera for tailgaters. Remember the old saying, "stops on a dime and gives you nine cents change." You just can't beat 5 axle disc brakes and "grade braking" for stopping a rig.
guskmg.
Old 10-12-2015, 09:19 AM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
We have many 2007-2011 Duramax/Allison trucks with integrated trailer brake controllers and cargo trailers. The integrated trailer brake controllers work fine. Usually the gain is adjusted to 6 or 6.5.
We only have one 2015 with integrated trailer brake controller, and so far it works fine with a horse trailer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-28-2015, 11:00 AM   #17
2016 27' International
Ladera Ranch , California
I too have an 2015 GMC Denali Duramax...I have a 2016 International and have not had any trouble with the trailer brakes...as others have suggested, have you engaged the "towing mode"?.....other than that....not sure what is going on...sorry could not be more help
David "heavyyeti"
2016 International Serenity 27FB
2015 GMC Sierra 2500 HD Duramax/allison
Heavyyeti is offline   Reply With Quote
Old 12-28-2015, 11:11 AM   #18
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When we converted the 2014 Classic to Kodiak 12" disc brakes, the distributor of the Titan RiteBrake II SD never mentioned that it was incompatible with ALL factory installed trailer brake controllers. I found out that tidbit of information driving home through the mountains in the dark. It was challenging.....
So we started the research into a third party trailer brake controller along with researching how to bypass the factory controller without throwing error codes in the 2012 Dodge Ram 2500HD Cummins. We settled on the Tuson OBD plug DireLink NE trailer brake controller and found the bypass information for the truck wiring.
This combination has worked well.
When the BrakeRite II gives up, we will probably convert to the Tuson Actulink ABS brake controller and replumb the brakes lines and replace the existing disc brakes for ABS models. That is the ultimate safe brake system for the our Classic that weighs around 9,300 pounds camping ready.
2011 Chevy 2500HD factory brake controller TinTop Towing, Tow Vehicles & Hitches 9 03-11-2014 03:33 PM
2012 Chevy Silverado 1500 Brake Controller Wiring AirHeadsRus Brakes & Brake Controllers 9 11-20-2011 05:20 PM
Chevy Duramax Diesel Problem:Thought I Was Invincible! SSChanger Tow Vehicles 12 06-26-2010 10:57 AM
chevy duramax Tom-Mc Tow Vehicles 22 02-06-2009 09:28 AM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
