Old 04-18-2018, 11:09 PM   #1
2013 25' International
Boise , Idaho
CAT Scale Results
Truck - loaded for light camping with about 350 lbs of gear, 3/4 tank of gas. I was not present in the seat for any weights, wife not included either.
Trailer - close to camping weight - 70% propane, 100% fresh water, no food.
Pass #1 - TV only
FA: 3260
RA: 2820
Pass #2 - Trailer only
Tongue: 1060
Axels: 5280
Pass #3 - NO WD (bars no included in measurements)
FA: 2920
RA: 4020
Trailer: 5480
Pass #4 - WD engaged
FA: 3040
RA: 3880
Trailer: 5540
Definitely some oddities - like how did the weight on the axles go up when hitched? Airstream claims 886# for tongue as specd but I've dropped the LA batteries and would expect the tongue weight to be below original spec.
Am I right in concluding I need a little more WD - planning on adding another washer on the Equal-i-zer. Trailer attitude is good, slightly tongue down but going up again would not allow me to lower my truck bed door which would suck.
Any other thoughts? Thanks!
Adam
afk314 is offline   Reply With Quote
Old 04-19-2018, 04:55 AM   #2
2012 19' International
Southeastern MI , Michigan
Pass #1 - TV only
FA: 3260
RA: 2820
Tongue: 1060
Axels: 5280
FA: 2920
RA: 4020
Trailer: 5480
FA: 3040
RA: 3880
Trailer: 5540
Adam
3000 lbs on the front axle ought to be plenty. But more importantly, how does it drive???
You’re not transferring much weight. And I’m not surprised by the tongue weight being over spec.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is online now   Reply With Quote
Old 04-19-2018, 06:30 AM   #3
Byron Center , Michigan
I’ll comment on the tongue weight - AS provides a general guestimate without options and without water and cargo. They’re also known to be somewhat off. As you add your supplies, the tongue weight will go up. Especially if you used a Propride or Hensley (the head adds directly to tongue weight).
I’d also suggest that good weighing technique include you and your wife in the TV so you can see how that affects the payload numbers.
Glad you’re doing this. It’s cheap, and you learn a lot about your setup. I know I find it interesting.
YippieKiYa is offline   Reply With Quote
Old 04-19-2018, 07:46 AM   #4
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Looks like you are still 220lbs light on the front. That is is you are looking for 100% restorative force.
As well as CAT numbers, I like to measure the TV’s actual measurement of the change in heights of the TV’s “attitude”. That is how far off “normal” is the TV. Ie: does it show high or low at the front and rear axles. As well as the measurements of the AS hitch and bumper.
You are heading in the right direction.
As you noted, another washer in the head should do it. Including the extra cargo you would load. Just don’t forget the wife!
And as Countryboy noted; published hitch weights are just that, a number, nothing close to actual because every AS is loaded differently with unknown items.
Would you rather have a properly hitched setup or have the tailgate open all the way. That’s for you to determine.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 04-19-2018, 09:00 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I'm also 200# light on the front axle...I've restored to 100% with no appreciable handling improvement.
As noted it, is paramount that both TV & AS be level when WD is properly set. (tongue 1"-2" low better than high)
My tickets.... notice the weight is transferred from the TV rear axle to the steering axle and back to the AS axles.
When tongue is lifted the weight runs 'downhill' to the front and rear.
ID:	309037   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 04-19-2018, 09:22 AM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Adam
Axle weight will change if the trailer is not in the same attitude as when weighed with the truck. Axle weight will be higher the higher the tongue is.
Others have commented on the tongue weight. The published tongue weight means little or nothing. For good towing common practice is the tongue weight should be 10%-15% of trailer total weight. I try to run at around 12%.
You can also raise the equalizer brackets to increase weight transfer. It is an iterative process of adjusting the number of washers, the bracket height, and the shank drop to get weight distribution dialed in and the trailer level. General guidance is to restore 50% to 100% of the weight back to the front axle. Some vehicle manufacturers put their recommendation in the manual. You can get close in your driveway by measuring the distance from the center of the wheel well opening to a point on the wheel instead of weighing, then confirm your setup with a weighing.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-19-2018, 10:11 AM   #7
Mollysdad's Avatar
Interesting.
Not surprising.
I'd try one more washer.
Old 04-19-2018, 11:11 AM   #8
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
I think you're missing some very important information. I often help people setting up the WD hitches. What is also important is the individual trailer axle weights. Too much difference between the trailer axles can cause instability when towing. It's important to look how all the axle weights are distributed when adjusting your WD system.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 04-19-2018, 03:48 PM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Ill assume you have the CAT Scale App
Method will help. Consistency.
Top off fuel tank at travel center arrival
First pass:
With WD engaged.
Second pass:
Simply loosen bars. Slack, not removal
Third pass
Drop trailer in designated parking spot. Cross scale solo
A fourth pass can be done for a split-axle weighing. Go to fuel desk first and be sure scalemaster knows procedure. (Manual at desk covers it)
Point here is to make no real changes between passes. All passengers aboard, etc.
Old 04-19-2018, 04:58 PM   #10
Trailer axle weights or individual trailer wheel weights?
Amanamus
"Tahawus"
Old 04-19-2018, 11:23 PM   #11
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Thumbs up
Pass #1 - TV only
FA: 3260
RA: 2820
Tongue: 1060
Axels: 5280
FA: 2920
RA: 4020
Trailer: 5480
FA: 3040
RA: 3880
Trailer: 5540
My math from your numbers shows that when you hitch up and don't have WD applied, you have 858lbs of tongue actually sitting on the rear axle.
6940lbs truck - 6082lbs truck previously.
Adam
I think you could adjust it. But your setup looked level to me from where I was standing but you might of been just a tad nose high.
Hi again.
You're setup is a lot lighter than mine, I'm a bit jealous.
But from my personal experience, you def do want more weight on the front. And you could shift some weight off that rear. You have close to 1060lbs on the rear and 220lbs light in the front.
I have a much heavier setup, but look at my spread.
I started (first photo) with a FA of 5060 and end (3rd photo) with a FA of 5320 so 260lbs extra up front. And a RA starting of 4000 (first photo) and ending with 4420lbs (3rd photo).
That's balanced, compared to no WD where I had 400lbs come off the front of the truck and nearly 1340lbs on the rear axle.
Personal opinion, open to debate here among others, but you certainly could dial that in better.
Good luck.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-19-2018, 11:23 PM   #12
Nomadic , USA
First pass:
With WD engaged.
Second pass:
Third pass
I basically do it the same way, but in reverse.
Old 04-20-2018, 04:33 AM   #13
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
I didn’t know we were permitted to go through the CAT scales backwards?
Hibby
Hibby is offline   Reply With Quote
Old 04-20-2018, 05:26 AM   #14
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
"I basically do it the same way, but in reverse." - WOW Bold! You must be good to back onto a CAT scale!
Also interesting that Bold chooses to travel at over 100% FALR (Front Axle Load Restoration) as do I. Here is a link to my scale tickets and picture of my rig with 11 links of weight distribution on a Blue Ox hitch. http://www.airforums.com/forums/f42/...ml#post1985301 I always travel at 11 links, 80# over FALR on these scale tickets, to improve my rig's handling. I tested even more front axle weight by trying 1500# bars which completely ruined my rig's handling to the point that I had to abort my test drive to the CAT scale. So it is possible to go too far with front axle load restoration. I've found that adjusting a weight distribution hitch is a balancing act where the "sweet spot" is found through trial and error and then confirmed with weight scale tickets.
2017 Flying Cloud 25FB (Miles) 218 nights 30,171 miles
400W Solar, Blue Ox SwayPro, 16" Michelins
2017 Nissan Titan XD 5.0 Cummins Diesel 4x4
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
CAT scale results .. your thoughts RTurnConn Hitches, Couplers & Balls 23 10-04-2018 06:43 AM
CAT Scale Results KCCO Towing, Tow Vehicles & Hitches 8 07-20-2017 03:30 PM
CAT Scale results trumpetguy Towing, Tow Vehicles & Hitches 4 05-27-2017 08:17 AM
CAT Scale results 2009 F150 Supercrew 2X4 and 1997 34" Excella Aviator Hitches, Couplers & Balls 11 07-14-2010 01:29 PM
CAT Scale Results - '08 Safari 23' FBSE + '08 Tundra DC 5.7 4x4 bonginator Towing, Tow Vehicles & Hitches 9 06-17-2010 08:54 AM
