Old 07-18-2017, 02:29 PM   #1
2017 30' Flying Cloud
Pleasant City , Ohio
CAT Scale Results
Made my way to the cat scales before our most recent trip
1st pass with truck only:Click image for larger version
Second pass with the weight distribution not connected:
The third pass with truck and trailer and weight distribution connected:
If my math is correct my tongue weight is 1,140 lbs.?
Currently using equalizer hitch - considering switching to Blue Ox to allow for a softer ride. According to this I would need to purchase the 1500 lb. hitch head due to the tongue weight being over 1,000 lbs. I see many folks on here using the 1,000 lb bars on Blue Ox - are you all using the 1,500 lb. hitch head with the 1,000 lb. bars?
KCCO is offline   Reply With Quote
Old 07-18-2017, 02:47 PM   #2
Frederica , Delaware
There is only one hitch. You can interchange bars with Blue Ox.
Overloaded is offline   Reply With Quote
Old 07-18-2017, 03:21 PM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
The first ticket shows your truck weighs 9020 pounds.
The second ticket shows a total combined weight of 16220, so you trailer weight is 7200. The second ticket also shows your truck axles add up to 9820. That says your tongue weight is 800 pounds (9820 minus 9020).
The second ticket shows that the front axle got lighter by 340 pounds. Then the third ticket shows that the front axle gained back 200 pounds. So your WD hitch has "restored" more than half of the weight transfer.
I used to own a Blue Ox Sway Pro. As I recall, there is only one version of the head. It's basically a 1500 pound head. It accepts any of the Sway Pro bars. Based on 800 pound tongue weight, I'd go with 1000 pound bars.
SSquared is offline   Reply With Quote
Old 07-18-2017, 03:34 PM   #4
2010 25' FB Flying Cloud
Tulsa , Oklahoma
A little bit unrelated, but if one were to use the scales (as opposed to using the measuring tape/fender method) to determine appropriate setup of weight distribution hitch, don't you really only need to weigh the front axle with and without the trailer attached? I know having all three weights gives you additional information that is needed, but in regards to the weight distribution, you could just weigh the front axle, right?
Is my logic correct/incorrect?
rlhendren is offline   Reply With Quote
Old 07-18-2017, 03:40 PM   #5
Thanks for the clarification on the Blue Ox!
Old 07-19-2017, 09:48 AM   #6
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
KCCO, Thanks for posting your weight tickets. SSquared nailed the weight calculations. Wow, only 800# tongue weight on a 30' seems low versus my equally heavy 25FB. My next question is how does it feel in crosswinds and traffic?
Before I restored all the steer axle weight on my 25' with blue ox, I felt bow push while being passed and minor cross wind affects. After cranking up the links to restore my full steer axle weight, it now feels rock solid all the time. My Nissan Titan XD manual recommends restoring 100% of steer axle weight, and doing so made a big improvement on my rig.
RLHendren: You are correct that restoring the front axle weight was the critical measurement needed to set up my WDH. But it is good to know all the weights with the three passes to verify that you are not exceeding any ratings on your rig such as individual axle weights, GVWR, GCWR and hitch maximum. Also to verify you are in the 10-15% tongue weight recommendation.
2017 Flying Cloud 25FB (Miles) 266 nights (6/16/19) 35,133 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's, TM66 TPMS
2019 F250, 6.7 Power Stroke, 4x4
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 07-19-2017, 10:41 AM   #7
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Just curious how many links you are using on your Blue Ox to restore all the steer axle weight on your truck?
Old 07-19-2017, 10:53 AM   #8
AirMiles's Avatar
On my 2017 FC25FB with 2016 Titan XD Diesel with 1000# blue ox bars, I put the 11th link from the loose end of the chain in the latch slot which results in one and one half links showing under the latches when connected.
Old 07-20-2017, 02:30 PM   #9
AirMiles - I'm shocked at the exceptionally light tongue weight.....it's actually 100 lbs less than published weight from airstream, and it makes me wonder if the measurement was accurate.
My Blue Ox arrived today and I hope to install it over the weekend and make another pass at the scales - I'll let you know what I find out.
The dealership set up my equalizer with very minimal weight distribution, and I too felt a good bit of bow push while being passed by semis and the like. After adding some additional washers to the setup that has gone away, but the steering still feels just a touch light. In addition, the camper sits just a little bit tongue low and the ride just isn't the best.
CAT scale results .. your thoughts RTurnConn Hitches, Couplers & Balls 23 10-04-2018 05:43 AM
CAT Scale results trumpetguy Towing, Tow Vehicles & Hitches 4 05-27-2017 07:17 AM
CAT Scale results 2009 F150 Supercrew 2X4 and 1997 34" Excella Aviator Hitches, Couplers & Balls 11 07-14-2010 12:29 PM
CAT Scale Results - '08 Safari 23' FBSE + '08 Tundra DC 5.7 4x4 bonginator Towing, Tow Vehicles & Hitches 9 06-17-2010 07:54 AM
results of CAT Scales and WD hitch adjustments funkill Hitches, Couplers & Balls 10 07-11-2009 06:35 PM
