Old 08-10-2015, 05:32 PM   #15
2007 28' International CCD
Deland , Florida
Thanks for the help. One less thing to worry about as I head down the highway.
printman is offline   Reply With Quote
Old 08-10-2015, 06:25 PM   #16
DuncanK1's Avatar
2015 30' Flying Cloud
Berrien Springs , Michigan
Printman - thanks for the detailed write-up, and everyone for the helpful advice. I'll be doing this very soon. New truck and AS arrives very soon.
DuncanK1 is offline   Reply With Quote
Old 08-11-2015, 08:14 AM   #17
Springfield , Missouri
So, going by your weight figures, the total weight(Gross combined weight) is 12640. And, if you subtract the actual weight of your uncoupled tow vehicle(6080) then subtracting that from GCW is 6560 lbs., which would be weight of trailer and tongue weight combined. 6560 minus 6080(TV weight) would be approximate actual tongue weight(900lbs) on tow vehicle. Is this correct way to figure the additional weight applied to the payload ratings of the tow vehicle by the trailer?
coolbikeman is offline   Reply With Quote
Old 08-11-2015, 08:12 PM   #18
Sorry, should have checked my post before submitting. I should have said The total trailer weight(6560) minus the original trailer axle only weight(5660) would be a 900lb. tongue weight.
CAT Scale Alternatives? 100 Miles Away! redwoodguy Hitches, Couplers & Balls 12 01-09-2012 09:42 AM
CAT Scale results 2009 F150 Supercrew 2X4 and 1997 34" Excella Aviator Hitches, Couplers & Balls 11 07-14-2010 12:29 PM
CAT Scale Numbers for 25' Safari greatlakes 2004 Safari 4 03-26-2010 11:44 PM
CAT Scale Numbers for 25' Safari greatlakes Hitches, Couplers & Balls 0 03-21-2010 05:17 PM
Cat Scale Etiquette campadk Towing, Tow Vehicles & Hitches 15 11-24-2006 03:46 PM
