Old 11-20-2008, 03:06 PM   #29
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
MoHos are a totally different beast....you can in fact put things on the back of those.....it's hard to tell from the pic the Vespa is on a MoHo. Eyes aren't what they use to be.
Trailers are the no-no.
Old 03-28-2009, 01:59 PM   #30
Deland , Florida
looking to haul a Honda Helix 250 scooter behind a 1990 Airstream Motorhome in a carrier that goes into the receiver hitch ... not a trailer ... only ones I have found are only for dirt bikes ... help???
myfavrv74 is offline   Reply With Quote
Old 03-28-2009, 04:47 PM   #31
2008 23' International CCD
golden , Colorado
I use Tilt-A-Rack to haul a Vespa around. Only on the back of my F-150, not on the airstream itself. It works great. I think I have the 400 or perhaps 200 version. They have a 600 that can hold a 600 lb bike. Ideally, you want to find a place higher on the vehicle to attach the upper part of the bike to with tension, to minimize the bounce and torque on the receiver.
Tilt-A-Rack Aluminum Hitch Mounted Products for Motorcycles, Dirt Bikes and Scooters
Be sure to check your tongue weight and torque limits on the receiver to make sure you don't exceed the frame's capacity.
1cericks1 is offline   Reply With Quote
Cargo Carrying Capacity (CCC) of 23' Safari SE LS OrangeKid 2007 Safari SE 45 04-05-2010 08:26 PM
Carrying and securing Honda Generators Raptorrider2001 Generators & Solar Power 21 06-13-2008 11:21 AM
Motorcycle inside Airstream? Foureagles Towing, Tow Vehicles & Hitches 25 01-08-2008 03:19 PM
Carrying your toad!!! myoung General Motorhome Topics 13 03-26-2007 12:42 AM
Carrying Canoe on top of 1971 Safari Larry71 1969 - 1973 Safari 30 08-02-2005 09:48 PM
