Old 02-08-2013, 03:39 PM   #1
2012 25' FB Eddie Bauer
Wilton Manors , Florida
Can I tow a 25' Eddie Bauer with a Chevy Silverado 1500?
Hello,
I just bought my first Airstream this week - a 2012 25 FB Eddie Bauer. I need to buy a tow vehicle and I notice that there is a lot of active discussions around tow vehicles. I'm looking at a 2009 Chevy Silverado 1500 LTZ 5.7 and 3.42:1 axle. with a tow package. It looks like it has a tow capacity of 9,600 lbs. The GVWR of my trailer is 7,300. Will this be enough to tow without any issues? I don't want to buy too large of a truck since it will be my main day-to-day vehicle.
Thanks. I'm excited to be part of the Airstream community!
Vic
VicIde is offline   Reply With Quote
Old 02-08-2013, 03:44 PM   #2
Originally Posted by VicIde View Post
Hello,
Vic
Vic.
Install a transmission oil cooler and you will be good to go.
You can tow anything Airstream makes,with your TV.
Old 02-08-2013, 04:52 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Hello,
Vic
The truck would probably be much better if it had 3.73 gears. I just did a walk-through on an EB today, and the tow vehicle was a 4x4 F250. Ride was very smooth, with no bouncing around, and the truck was more than enough to handle the trailer. Since yours is also an EB, it would probably be a good idea to get a 4wd truck, since getting out there is part of what that trailer is made for.
Old 02-08-2013, 04:54 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
yes
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 02-08-2013, 04:58 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I don't believe Chevrolet put a 5.7l engine in the 2009 Silverado... LTZ were standard with the 5.3l and some bodies had optional 6.0 or 6.2 V8s.
In Florida, without a lot of big hills around, the 5.3 should do OK. For occasional steeper grades you may need to tolerate lower gears and higher RPM but it'll do it. People towed with a lot less torque for a long time.
David
DKB_SATX is online now   Reply With Quote
Old 02-08-2013, 06:51 PM   #6
dznf0g's Avatar
Oswego , Illinois
DKB is correct. no 5.7....but that's Ok as the 5.3 has more torque and HP than the last of the 5.7s. I question the 9700 lbs with a 5.3 and 3.42s. That's awfully close to the 10,000 lb rating for a max tow package with a 6.0 and 3.73s.
-Rich-
Old 02-08-2013, 08:17 PM   #7
1987 25' Sovereign
Oregon , Ohio
I have been towing a 1987 25' Sovereign for the last two years with a 2001 F150 S-Crew 5.4 and a 3.55 rearend with a trailer towing package, no problems on the flats or through the Tennesse mountains.
msmcv51 is offline   Reply With Quote
Old 02-08-2013, 09:07 PM   #8
1988 32' Excella
Robbinsville , New Jersey
You will need to watch your payload. The trailer tongue weight will take close to 800lbs of the payload, plus passengers and gear.
Old 02-08-2013, 09:26 PM   #9
1993 21' Sovereign
Okay, I dd a little further checking, and the tow rating for your truck with 3.42 gear and 5.3 engine is 6800 pounds, not 9600. I don't know where that number came from, but it is not listed for that truck at all. So, to anwer your question, NO. It will NOT tow the EB. You will need to find a tow vehicle with more towing capacity.
Old 02-09-2013, 02:40 AM   #10
1999 34' Excella
Cinnaminson , New Jersey
It will do it if you get steeper gears but dont expect a speed demon. The 3.42's just dont cut it in the towing world. I have a 2005 Yukon 1500, 5.3l, 3.42 4x4. I purchased my 1990 29' and figured it would be ok to tow... The trailer is under the tow rating and the package was just under the combined rating empty. I pulled it 100 miles and decided I was buying a new tow vehicle when I got home.
If the truck had 3.73 or 4.10 gear it would have been much better. I was not comfortable pulling a slight hill in second gear at 4000 rpm to try and keep it in the 40 to 50 mph range. Flat land I was able to stay in 3rd at about 2500 rpm and maintain 60/65 mph. Any grade at all and it was in 2nd to get up the hill. Forget OD if you have 3.42's you can only pull it in D. Now the newer trucks have a much better trans that the 05's but they HP and TQ thru a 3.42 gear just doesnt cut it.
I got home, pulled the check book out and went truck shopping. Bought an 03 F350 7.3 psd... now I can hit a 6% grade with the trailer loaded to the max, kids and wife in the truck, bed full of firewood and she doesnt even come out of OD at 70 mph... plenty of power to pull anything I want .
My suggestion would be to get the 2500HD with the 6.0L and say a 3.73 gear and you will be reliable, and comfortable towing. It will have plenty of power for the hills.
excellaf350 is offline   Reply With Quote
Old 02-09-2013, 03:19 AM   #11
1999 34' Excella
Oh and this really depends on how much towing you plan to do. If you furthest trip is 150 miles from home in flat FL ground and you do it once a month maybe every other month... no sweat get the 1500 with a 3.73 gear and you will be ok. If you are going 800 miles from home, 1 or 2 times a month I would definately skip it and go for the 2500/6.0L combo.
Old 02-09-2013, 03:30 AM   #12
2005 28' Safari
saline , Michigan
Had the same truck, same year, same package, and towed my 28 footer all over without any issue. Sure it's a little slower up the steep passes out west but so what. My advice is don't change vehicles just for that trailer.
Kosm1o is offline   Reply With Quote
Old 02-09-2013, 05:49 AM   #13
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
What Andy said. Use you truck for a while then decide.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 02-09-2013, 06:37 AM   #14
Thank you all for your great input. Gives me a lot to think about and consider. Much appreciated!!
Vic
