Old 12-26-2013, 02:55 PM   #15
1981 31' Excella II
New Market , Alabama
I am assuming it is on grass and not concrete? Photos would help. It would be possible to rig a temporary hitch by removing the bumper. You would need to make sure the front hitch is off the ground. This would at least get you far enough to get to the front of the trailer. I am assuming this is flat ground a not a hill. On flat ground you could just pull it with a chain or rope. You need some spotters with some chocks to put in front of the wheels if it does not want to stop on its own.
Perry
Old 12-26-2013, 07:13 PM   #16
reinergirl's Avatar
Hollis , New Hampshire
Once you have a wheel under the front jack you'd be surprised how easy it is to move , I'm assuming level ground.... The pieces of plywood will help, if the ground is spongy you'll need them under the wheels as well. We used the chains in the front to move ours on the driveway, we used wheel chocks and big landscape timbers, being careful to never go more than a foot or two at a time, momentum is not your friend in this case.
If you post pictures, there may be other creative solutions...
Would a front hitch on your truck do it? Inexpensive and useful in many other situations...
reinergirl is offline   Reply With Quote
Old 01-07-2014, 10:07 PM   #17
1964 30' Sovereign
Canoga park , California
Thanks again for all the great ideas. I will let you know how it turns out.
Cavefalls is offline   Reply With Quote
