Old 09-12-2015, 12:41 PM   #1
1985 31' Excella
Jasper , Texas
Can box trucks tow travel trailers?
I am not planning to tow my new trailer at the moment, but if I ever do try to tow it, I do not have a vehicle I am sure is a good tow vehicle
What I do have is a 94 E350 17ft box truck that is a retired Uhaul, that I picked up a while ago off Craigslist when I needed to move because it was cheaper than renting a UHaul. It notably does have a trailer hitch on it and a wiring connector
I have never seen a box truck pulling a camper trailer however, so not sure it is actually a feasible idea. It certainly would allow you to haul a lot of stuff (though admittedly I hate the idea of taking a 17ft box truck grocery shopping and all the other stuff a tow vehicle is used for when not towing)
alexj is offline   Reply With Quote
Old 09-12-2015, 01:11 PM   #2
1976 31' Sovereign
Oswego , Illinois
No reason that box truck can not pull travel trailer. The E350 should not be prob. as many tow with 150 or 250 pick ups. Many dif. types of racing use box trucks to pull trailers, some with living quarters and racers. Only dif. some AS snobs look askew at this, before any body gets there nose bent because I said SOME SNOBS NOT ALL AS are snobs.
Old 09-12-2015, 01:50 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Before you decide to tow an Airstream with a U-Haul truck, you will need to add a 7-way plug to the bumper section and a brake controller as well.
Any U-Haul trailer with brakes had hydraulic surge brakes that did not require a controller. The trucks were wired for lights only, not electric trailer brakes.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 09-12-2015, 01:56 PM   #4
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Was done by Michael . . .
alexj:
Five or more years ago there was an active participant on these Forums named Michael J. Depraida (screen name "Artstream") who was an artist, primarily a painter and T-shirt guy. A full-timer, he towed his Airstream with a box truck for his supplies, including a small portable freezer run by solar panels on his roof. Do a Google search for his posts and/or his photos and you might find a few photos of his box truck tow vehicle. Good luck!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 09-12-2015, 02:26 PM   #5
1974 Argosy 20
Kooskia , Idaho
Just a question for everyone.... is there any problem with the width of the box and the turning radius which could cause the box to hit the trailer and dent it on sharp turns? I know it would be difficult to see the trailer back there to know what is going on.
Old 09-12-2015, 03:47 PM   #6
Mission , Texas
Jackknife hard enough with any TV and the AS bends ...
I'd look at the thread about the artist with a box truck - my guess is the receiver on the hitch is longish.
nrgtrakr is offline   Reply With Quote
Old 09-12-2015, 03:49 PM   #7
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by idroba View Post
.... is there any problem with the width of the box and the turning radius which could cause the box to hit the trailer and dent it on sharp turns?...
Yes - the likely hood of denting the trailer in a tight turn is high - not only because of the extended width, but also due to the hitch usually being buried (recessed) into the bumper.
I have a vertical patch on the driver side front of the Vintage Classic due to immediate PO from whom I purchased the trailer.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-12-2015, 04:41 PM   #8
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
The E350 will pull it just fine. Make sure the transmission is good to go before you head for the hills. A lot of "flat land" TV's wind up in the tranny shop when they start pulling the load uphill. Especially the higher mileage / service vehicles. Be careful in the sharp turns while backing.
NavyCorpsman is offline   Reply With Quote
Old 09-12-2015, 05:21 PM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
You may need cargo over the rear axles for better traction and stopping power when towing. This type of vehicle is typically lightly loaded on the rear axle when empty.
Old 09-13-2015, 11:22 AM   #10
1957 18' 18 Footer
Casper , Wyoming
Just curious ... You say "But if i ever do try to tow it....."
Why would you not be towing your new Airstream"
CM in WYO
cmadis is offline   Reply With Quote
Old 09-13-2015, 11:41 AM   #11
2004 22' International CCD
2015 30' International
Box Elder , South Dakota
For each truck UHaul rents, they list the towing capacity on their site. Here is one:
U-Haul: 15ft Moving Truck Rental
lbdesign is offline   Reply With Quote
Old 09-13-2015, 11:47 AM   #12
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Nobody has mentioned the rough ride your bound to have and how this will effect your coach.
Ahab is offline   Reply With Quote
Old 09-13-2015, 12:06 PM   #13
Terlingua , Texas
Calculate distance from truck end to trailer front. Then calculate length of extended hitch receiver for a minimum of 60 degree turns. This should provide adequate distance between TV and AS. Rear side mirrors should give plenty of visibility when turning as well as backing up. Service shops that mount custom hitches should be able to figure the required length and you may have to modify the ASs tow arms to accommodate the required distance. Good luck and a good ride to you!
sbeckett is offline   Reply With Quote
Old 09-13-2015, 12:42 PM   #14
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Sure it will do a great job. Some things to consider. Need hitch long enough so the truck box will not hit the trailer while turning. If it is long then it has to be strong enough to carry trailer. As was mentioned you need a 7 pin electric plug in and a break controller.
You will be the envy of everyone with all your storage capacity. Or you could use truck for sleeping area for quests. Or?
Good luck.
larryglarson is offline   Reply With Quote
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Towing larger trailers with SUV or 1/2 ton trucks RivetNV Tow Vehicles 61 05-14-2013 09:16 PM
Who rents trucks to tow my 1962 Airstream Globetrotter? M Cordell Tow Vehicles 5 04-04-2011 10:36 AM
what can we tow w/ older trucks? nurngen Tow Vehicles 7 01-29-2011 12:48 PM
Mileage for gas trucks vs diesel trucks? mrchinup1 On The Road... 126 04-21-2008 06:43 AM
