Old 10-28-2013, 12:43 PM   #1
Can 2011 Toyota Sienna tow a Bambi 16' with Sway control only?
I had the airstream dealer hookup my sienna with a 2013 Sport 16, the rear of the van did not sag at all just riding on the ball. I presently tow a Alioner Classic that weights 1800 lbs.,the airstream about 3000 lbles loaded(no water).Will this be safe to tow?
rjd111 is offline   Reply With Quote
Old 10-28-2013, 12:51 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
There is a guy on here that tows a 34' Airstream with a Sienna.
He will probably chime in.
I am going to say it will tow a Bambi.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-28-2013, 02:48 PM   #3
andreasduess's Avatar
1984 34' International
Toronto , Ontario
That's Steve - I think his trailer is a 27'. I tow a 34' with a Honda Odyssey, comparable to the Sienna in every way.
rjd, you will need a weight distribution hitch, they are recommended by Toyota for trailers heaver than 2400lbs. Otherwise, you will be just fine. The Sienna has a payload of 1400lbs, i.e more than ample, for the projected hitch weight of the Bambi.
To put a comparable on it, it is as capable as many 1/2 ton trucks (like a Ford 150 or Tundra) when it comes to carrying weight, with none of the drawbacks inherent in truck design, like a high centre of gravity and a narrow frame.
andreasduess is offline   Reply With Quote
Old 10-28-2013, 02:59 PM   #4
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Almost right, a 28' International; there's only inches in it, as the actress said to the bishop.
Andy's right, a well set up weight distributing hitch and some form of sway control or elimination will make towing a whole lot easier and safer. Brake controller is important and I use a second transmission oil cooler to help out with the load when thrashing into a stiff headwind for hours on end.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 10-28-2013, 03:24 PM   #5
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
This setup is one of the only ones I would say is ok to tow with the Sienna. The trailer is small enough and light enough to not over burden to TV unlike the larger trailers that are pulled by these. Weight distribution would be optional but sway control would probably help especially on the shorter trailer.
You don't need to spend the couple thousand dollars on propride or hensly hitches which I am sure will get recommended. If you feel you need WD hitch any of the other brands would work fine, just make sure to use light weight bars on the hitch setup
panheaddale is offline   Reply With Quote
Old 10-28-2013, 04:09 PM   #6
Road Ruler's Avatar
Images: 38
We really enjoyed towing our 23' for years with a 150HP Nissan mini van. No problem at all. Towing a smaller Airstream with a more capable van like a highly rated Sienna should work great. A WDH should be on your to do list.
Old 10-28-2013, 04:21 PM   #7
MrUKToad's Avatar
Chatham , Ontario
Forgot to mention the beefed up hitch, which is a necessity for my set up, but probably not essential for the OP's set up.
Old 10-28-2013, 04:41 PM   #8
m.hony's Avatar
2013 30' Classic
Get you some mirror extensions and go for it.
TAC #MS-10
Airforums #70955
Old 10-28-2013, 05:27 PM   #9
My van is a LTD AWD with reese class 111 hitch,and P2 Brake Controler,I see the need for sway control but no mention of WD system in my owners manuel.Also why do I need the hitch receiver to be beefed up ?it is rated with 3500 lbs. WO/WD or 5000 W/WD?
Old 10-28-2013, 05:53 PM   #10
MrUKToad's Avatar
Chatham , Ontario
Weight Distribution is exactly as the name suggests; it spreads the load over all the available axles. My Sienna wouldn't work without weight distribution but with a lighter set up like yours, it's still advantageous to get some weight put back to the front axle and have a little taken to the trailer axle. You'll tow so much better with a properly adjusted WD system.
I'm no expert on these things and I didn't suggest that your set up needed to have its hitch beefed up. Mine has some additional steelwork that counters the torque applied by the WD system and helps transfer the weight forward. With your tongue weight I would imagine your hitch will do just fine.
Old 10-28-2013, 06:07 PM   #11
2015 28' Flying Cloud
Melbourne Beach , Florida
The Sienna should tow OK. The V6 has plenty of power. I towed my Bambi with a 2008 Lexus 400h and had no issue.
Kingsmen 33 is offline   Reply With Quote
Old 10-28-2013, 06:33 PM   #12
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . I think a Toyota Prius could pull an AS 16. (properly equipped, of course) ........regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 10-28-2013, 07:49 PM   #13
Toronto , Ontario
The Bambi has an empty hitch weight of 350lbs, loaded for camping that might well be around 420-450lbs.
While the Sienna can handle that weight on the rear axle, I personally would install a WD hitch to distribute it as evenly as is possible across all six available wheels. Your handling will thank you.
Old 10-28-2013, 08:32 PM   #14
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Dont know your Bambi's tongue weight, but Check your hitch receiver tongue weight rating also. if your tow rating is 3500 # I bet it's rated for 350 # or less. It may be 500# but I would check to be sure.
Howard L. is offline   Reply With Quote
Need a truck to tow a 2007 16' Bambi rportillo Tow Vehicles 15 10-24-2011 01:48 PM
2007 Airstream Bambi Special Edition with 4 point tow eBay Watch Airstreams on eBay 0 02-09-2011 05:30 PM
