Old 08-13-2018, 05:46 PM   #1
weirdstuff's Avatar
2018 23' International
San Diego , California
Burning smell on steep downhill, not brakes
Drove up and over Teton Pass, heading east. F150, towing 23CB.
No problems uphill, with rpm’s around 3,000.
No handling problems going downhill, engine braking the whole way.
Some of this pass is 10% grade, with lots of curves, and going 20mph as suggested.
We were almost to the bottom of the pass, when we smelled burning smell. Didn’t seem like it’d be the brakes, since we were barely using them. And the engine was running at normal temperature.
So wondering what was overheating, and how to avoid this in the future.
Also, should we have been applying truck brakes more frequently, to engage trailer brakes?
This was the steepest pass we’ve been on in our 7,000 miles of towing. We’re headed to Colorado, and want to be better educated before we get there!
Grand Teton National Park, Wyoming
weirdstuff is offline   Reply With Quote
Old 08-13-2018, 05:50 PM   #2
Long Island , New York
What was the air temp, and do you have a separate cooling radiator for the transmission fluid? Just a layman's guess, but in hot weather with that much engine braking you might have been smelling the tranny heating up.
As you started downhill, it might have been a good idea to adjust the trailer braking gain, so that the trailer brakes were doing a bit more work on the downhill IMO. In a panic stop situation, it would be good to have the trailer doing this extra work, in order to avoid contributing to a possible sway event developing. Mountainous areas often have weird and unexpected cross-winds, and a sway situation can come on suddenly, especially as the tires don't grip as well, with the rig's combined weight "falling downhill."
At least have one hand on the brake controller at times like these IMO.
Peter
Old 08-13-2018, 06:08 PM   #3
ITSNO60's Avatar
Tucson , AZ
How new is the F-150?
Brian
ITSNO60 is offline   Reply With Quote
Old 08-13-2018, 06:13 PM   #4
weirdstuff's Avatar
F150 is 1 year old. Just had oil change and tire rotation the day before.
Was 80 degrees out.
No idea if there’s separate radiator cooler.
Trailer brake gain set to max (6).
Old 08-13-2018, 06:29 PM   #5
ITSNO60's Avatar
Tucson , AZ
Maybe check for any kind of leaks that could be dripping on the exhaust. Sometimes when an automatic gets hot it can push out fluid from the vent or the front seal but on the newer transmissions I don't know if that is still true.
Brian
Old 08-13-2018, 06:30 PM   #6
Thanks for the reply.
Gone are the days of having a transmission temperature gauge on the dash, but that is still a possibility IMO.
Are you sure this max(6) gain setting is necessary on a level road? There are posts about adjusting the gain in general. If this setting is too high, it is possible you were smelling the trailer brakes overheating. Also, there are posts about using a temperature-sensing device that you aim at the wheel for an instant reading. This might be good to try IMO.
Without knowing the temps of the tranny fluid, and of the trailer's wheels/brakes, we are just guessing IMO, so this layman will sign out of the discussion!
Good luck,
Peter
Old 08-13-2018, 06:46 PM   #7
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
When the exhaust got hot with towing I got a burning smell from the rust proofing being burned off the exhaust system.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 08-13-2018, 07:24 PM   #8
weirdstuff's Avatar
Smell was coming from truck. I sniffed around the trailer and trailer tires, and didn’t smell it.
Old 08-14-2018, 09:14 AM   #9
2019 25' International
Washington , Washington, D.C.
You gave some great advice, I think, in your first post in this thread. Thanks!
PatLee is offline   Reply With Quote
Old 08-14-2018, 09:19 AM   #10
1979 30' Argosy
Everton , Arkansas
Both my 2006 3/4T chevy and the current 2017 3/4T chevy pick up have transmission temperature gauges and going down hill they don't heat up at all. we went down hill for about 2.5 miles at a 10 percent grade with out problems. I like how the 2017 down shifts to help braking on hills
DEDUBE is offline   Reply With Quote
Old 08-14-2018, 09:35 AM   #11
r carl's Avatar
Lin , Ne
When they changed the oil the day before, oil could of been spilled on the motor.
Old 08-14-2018, 09:37 AM   #12
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I smell burning brakes on most steep downhill sections, very rare that it is me. Any semi traffic?
"Chip Tank" is in Vacaville Ca.
CDONA is offline   Reply With Quote
Old 08-14-2018, 10:49 AM   #13
1976 31' Excella 500
Chappell Hill , Texas
it could have been smell from another vehicle that was or had been in the area.
tbashin is offline   Reply With Quote
Old 08-14-2018, 02:12 PM   #14
2016 25' Flying Cloud
Richmond Hill , Georgia
My F150xlt 3.5 has a temp gauge on the inst cluster. Top far right.
Imasailor is offline   Reply With Quote
Old 08-16-2018, 07:44 PM   #15
East Hartland , Connecticut
Are you sure it wasn’t your brakes?
Tombomb68 is offline   Reply With Quote
Old 08-17-2018, 04:09 PM   #16
weirdstuff's Avatar
Update.....
Since posting this, we’ve driven from Jackson, to Dinosaur National Monument, and to Salida, CO. A lot of that was winding and steep grades, though nothing as steep as Teton Pass. Have had no problems since.
Even though we still don’t know exactly what it was, thanks for trying to help us figure it out.
Old 08-17-2018, 04:50 PM   #17
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
A tool that I carry for questions just like this, an infrared temp gun. Shoot temps at drum, tires cast iron griddle etc.
It can be a very valuable tool.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-17-2018, 06:47 PM   #18
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
What others said. I ALWAYS smell burning bars on long downhills. It's never me, it's someone else. But it always makes me think it could be me, until I think it all through.
2019 Ford Expedition Platinum
Old 08-17-2018, 09:13 PM   #19
Mollysdad's Avatar
I notice that in the mountains and it's often the trucks ahead of me.
The smell from their brakes hangs on the road and you'll drive through it.
My plan was to keep the speed down at the top, and only pump the brakes to maintain that speed, not slow down. Use engine braking and lower gears too.
Old 08-18-2018, 02:14 AM   #20
1979 23' Safari
Wayland , New York
May have been spilled oil burning off from the oil change.
You should be able to pull up a digital display of the transmission temp on the dash center display, that’s what I watch when I hit heavy towing.
Downhill speed control Vitaver On The Road... 27 10-18-2016 08:26 PM
Downhill Engine Braking Longboard6 Towing, Tow Vehicles & Hitches 4 10-15-2016 02:34 PM
Towing down a steep grade without burning up the brakes PSU1981 Repairing/Replacing Floor &/or Frame 43 06-16-2016 10:33 AM
"It" rolls downhill...(too soon old, too late impulsive) Foiled Again Trailer Values 9 08-27-2015 09:52 PM
How steep is too steep? Tin Diesel Towing, Tow Vehicles & Hitches 14 02-12-2007 01:03 PM
