Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 10-01-2006, 07:17 AM   #1
Profile:  2007 27' Safari FB SE
McKinney , Texas
Bumper Rollers
Does anyone here have rollers installed on their trailers? I am trying to protect my investment from those crazy dips in some drives at out of the way places. Any reccommendations
Krazyjohnny is offline   Reply With Quote
Old 10-01-2006, 07:45 AM   #2
Profile:  1972 21' Globetrotter
jefferson , North Carolina
i have them on a 34ft avion and they work great. i have to have them for my driveway. trailer had the hard plastic ones when i got it, they will not hold up, get the steel ones from tractor supply.
rock60 is offline   Reply With Quote
Old 10-01-2006, 08:32 AM   #3
McKinney , Texas
Got any pictures?
Old 10-01-2006, 08:46 AM   #4
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I intended to install them on my '98 Safari before it got crashed. I had already bent both sides where it had little "scrape plates" to protect the bumper. I would spent the extra $$ and get good ones. My current trailer seems to do fine in most dips.
Fyrzowt is offline   Reply With Quote
Old 10-01-2006, 09:05 AM   #5
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
I am curious about the use of rollers, obviously Chummy does not need them, but I wonder if it would possibly damage your frame. You are placing an item below the bumper and when it hits the pavement it will put all the pressure on the rear of the frame. Granted the dents and dings you get when hitting a dip in a drive are unsightly but the soft aluminum or bumper has absorbed all of the shock. Just a thought.
Chaplain Kent
WBCCI #7235 - Former VAC
1982 280 Turbo Diesel Motor Home (Chummy)
http://goodsamclub.mytripjournal.com/Chummy
Chaplain Kent is offline   Reply With Quote
Old 10-01-2006, 09:28 AM   #6
Fyrzowt's Avatar
Images: 8
That's a good point on placing them below the frame - you don't want to further lower your angle of departure. I would pull a string between the rear wheel contact point and the rear bumper and then mount the rollers so they only protrude below that stringline as much as needed. The further forward you mount them the less contact they will make with the ground. FWIW.
Old 10-01-2006, 01:56 PM   #7
Commercial Vendor
Profile:  Corona , California
DO NOT install rollers.
They "will" cause damage to the rear quarter panels should the rollers hit the ground, because the trailer will be artificially lifted with an added shock.
All Airstream trailers have built in "skids" plates added to the bottom of the rear frame. Slow down, drag the trailer on the skid plates and your OK.
If and when the skid plates become severely worn, simply replace them.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 10-01-2006, 02:26 PM   #8
Profile:  2004 28' Safari S/O
Newtown , Connecticut
Andy,
I put 5" swivel wheels on my 03 28 SO.Safari when we brought it. They are just inside the skid plates and hang down just about 2". this has not hurt the trailer at all. I do agree with you about slowing down.
I have seen skid plates broken, even when going slow. I will take my chances with the wheels.
Eric
Eric 28
Eric 28 is offline   Reply With Quote
Old 10-01-2006, 03:31 PM   #9
my 34 ft avion has 6inch frame and heavy steel bumper with swivel wheels.
i see a lot of swivel wheels on longer trailers and 5th wheels in campgrounds
all the time.
Old 10-01-2006, 03:42 PM   #10
Commercial Vendor
Originally Posted by Eric 28
Andy,
Eric
We replace dozens of rear quarter panels every year, that got damaged because the trailer had the dolly wheels.
Inlandrv.com
Old 10-01-2006, 04:35 PM   #11
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
I went to the lumber yard today, and bought a 2x10, cut it in half, and use that to bridge the low spot in our driveway. Our '63 has no skid plates, and I think a $7 piece of wood is cheaper than replacing several aluminum panels.
Obviously you can't do this while driving down the road, but it helps here.
You repair things with tools. You fix things with a hammer.
AIR#2611
Old 10-01-2006, 05:05 PM   #12
McKinney , Texas
My plan is to bring it home without them and see how it does coming up the driveway. My drive is not extreme but it would raise my awareness especially when I go to back it in.
Old 10-01-2006, 05:09 PM   #13
Images: 52
Terry.
Check your axles. If they are bad, the trailer will be lower to the ground, which aggravates the problem.
http://www.inlandrv.com/articles/dur...axle-92001.htm
The axles aren't that great, they are dead level, and on my list of things to fix or replace, slowly moving to the top.
AIR#2611
Old 10-01-2006, 07:30 PM   #14
Tinsel Loaf's Avatar
Profile:
I solved the bottoming out quite by accident. I installed air shocks on my E350 extended van and use them to raise and lower both the rear of the van and the Airstream. When I see a bottom scrape problem coming I inflate the rear shocks to the max and slowly move over the scrape zone of the rear of the van so it won't scrape than let all the air out of the shocks so the rear of the Airstream is higher off the ground so it won't scrape. Going slow and inflating and deflating timing the shocks is important than remembering to put the air back in the shocks at the right pressure for my unit once on level ground. It really works. Andy from inland told me that air shocks were a bad idea "an accident waiting to happen". Well after thousands and thousands of miles towing I think the air shocks saved us from many close calls not to mention avoiding bottoming out problems.
Tinsel Loaf is offline   Reply With Quote
Pingbacks are On
Older Argosy MH Bumper Needed Rik General Motorhome Topics 1 04-18-2004 09:54 PM
what kind of bumper carrier is that ? femuse Bumpers & Bumper Storage 2 05-03-2003 10:09 AM
Rear Bumper AccessMaster General Motorhome Topics 1 04-17-2003 06:43 PM
Where to seal rear bumper? 65trotter Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 02-17-2003 02:32 PM
Correct color of bumper and tongue gmc70 Clearcoat, Exterior Paint & Trim 2 06-24-2002 06:19 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
