Old 10-23-2015, 01:15 PM   #1
2016 25' International
Upper Arlington , Ohio
Brake Controller Wiring for 2016 Cayenne
Does anyone have a brake controller wiring diagram for the current model Porsche Cayenne? I went through this frustrating process back in 2008 when I bought my first Cayenne GTS and had hoped by now Porsche would admit the Cayenne is a tow vehicle. Seems the dealerships are still no help on the topic. I have a new Diesel on order which should arrive the same time my new AS 25 International arrives and would appreciate any help with the wiring. Thanks all.
Brad Waite
2016 25FB International Serenity
bwaite is offline   Reply With Quote
Old 10-24-2015, 07:10 AM   #2
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Brad,
See post 24 in this thread. It provides details of the parts required, how to locate the connector and a few other tips.
If you have some prior experience with basic wiring you should be able to DIY. A good auto mechanic with these details should also be able to do this for you.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 10-24-2015, 07:52 AM   #3
Great. Thanks for your help.
Brad Waite
Old 10-24-2015, 08:03 AM   #4
It's Porsh-Ah
Franswa's Avatar
Boston , Massachusetts
The pre-wired brake connector is above the OBD port on your 92A. The dealer can hook up your controller, if the dealer doesn't have an Audi dealer with them it can be tough to get the connector housing and pins, as they need to be sourced from VW usually, but it can still be soldered in without a connector. The "connector" that some people think should come with their vehicle is actually a European 7 pin to US 7 pin receptacle that screws into the hitch. This needs to be bought and installed at the time of delivery, as it is purchased through Westfalia USA. Most dealers will stock it, or can get it the next day. For what ever reason VW does not ship Tauregs and Cayenne's with a country specific 7 pin connector, but it's simply 4 screws, and replaces a blank cover. If you see salt or weather use stainless hardware, anti-sieze and dielectric grease liberally on the screws and body side connector, and inside the 7 pin connector under the cover, as the pins corrode easily and may need replacement more than once if used heavily, this will save a lot of headache versus broken screws and annoying trailer lighting warnings. And contrary to what some posts say, we know plenty about towing....
Sent from under the bonnet of some rich guys Porsche
Franswa is offline   Reply With Quote
Old 10-24-2015, 04:25 PM   #5
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Seems the prewire connector is not in exactly the same place in all the Touaregs & Cayennes....but in the same vicinity depending on the factory installer.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 10-26-2015, 07:34 AM   #6
Many thanks Franswa. That information will be a huge help.
Brad Waite
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 09:40 AM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 04:57 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
wiring impulse brake controller remcolent Brakes & Brake Controllers 2 08-06-2007 08:48 AM
brake controller wiring? Chuck Brakes & Brake Controllers 1 09-30-2004 07:10 PM
