Old 02-11-2019, 06:47 AM   #1
2017 22' Sport
Chicago , Illinois
Brake Controller on Both Trailer and Tow Vehicle?
I have a question that I hope will be simple? We have a 22FB with a trailer mounted brake controller and will be purchasing an F-150 with built in brake controller. How do I handle having two brake controllers? Do I just ignore the one on the trailer and leave its vehicle remote disconnected so it doesn't activate? Thank you!
aziskind is offline   Reply With Quote
Old 02-11-2019, 07:07 AM   #2
Mount Dora , Florida
Does the trailer 7-way plug in to the trailer mounted brake controller? If so, unplug it and plug it into the truck.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 02-11-2019, 07:36 AM   #3
lahrfarm's Avatar
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent , Oklahoma
I’d just remove the trailer mounted and use the truck. The built in controllers work great.
Have a blessed day !
TAC OK-5
lahrfarm is online now   Reply With Quote
Old 02-12-2019, 07:23 AM   #4
2017 22' Sport
Chicago , Illinois
Thanks all for your advice! Andy
Old 02-12-2019, 07:54 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can anybody enlighten a bit, never heard of a brake controller mounted on a trailer? Pics or link would be interesting.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-12-2019, 08:11 AM   #6
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Are you referring to the emergency break-away brake controller with the detachable pin and cable? That is a separate braking system that must be left intact and connected to battery power.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 02-12-2019, 11:02 AM   #7
Lebanon , Tennessee
I think the OP is a bit fuzzy on what is going on with his brakes. Maybe the best thing is to go to the dealer he bought it from and talk to the service manager.
If he bought used, even then just go to a dealership or maybe camping world service department and have someone explain how brakes work.
No way does he have a brake controller mounted on his AS. He must be talking about the breakaway switch.
And as we all know, don't pull the breakaway switch instead of using chocks.
Rzrbrn is offline   Reply With Quote
Old 02-12-2019, 12:12 PM   #8
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
The RF style brake control module mounts on the trailer tongue. The umbilical cable connects to the module and the module has an umbilical that connects to the tow vehicle 7-pin connector. https://www.amazon.com/Tekonsha-9025...a-436206402953
To use the truck brake module, remove the brake control module from the trailer and connect the trailer umbilical to the tow vehicle. Do not plug in the prior control remote. Use the truck dedicated controls.
Note - if the existing module is left in place, it will provide a braking signal to the trailer when the rig slows. It does not need the remote to be plugged in and powered. It does need that remote powered to activate the brakes in an emergency.
Note - the break away switch is not connected to the umbilical cable.
If the above is not logical, get professional help to work out the correct installation and explain it to you. This is important. Do not tow your trailer until you understand how the brakes function. You may never need to over-ride the brake control, but you must understand how and why to do that. Consider it part of towing 101.
Apology to those offering info. The RF control is a different system.
Travel safe. Enjoy your new coach. Pat
Old 02-12-2019, 01:37 PM   #9
Tom T
Tom_T's Avatar
Orange , California
No Pat -
The Tekonsha RF only sends a signal if the 7-way is plugged into the trailer unit - if not, then it just sits there unpowered.
I know - I have one - & rent Enterprise trucks all of which have their own controllers (F250, RAM2500).
I prefer to use the RF unit because I can keep the control unit in my lap/seat close at hand in case I need to use the boost button - rather then searching & reaching for the built-in controller's boost button on the lower dash, while trying the maintain control of the rig!
Andy - you can use either brake controller you prefer - depending upon which -
> if the RF on trailer, then plug the trailer's 7-pin into the Tekonsha box, & the the Tekonsha box's 7-pin into the truck/TV.
> if the truck/TV controller, then unplug the trailer's 7-pin from the RF's box, & directly into the Truck/TV.
Try them both & try out using the boost button for both, then decide.
Either way, just leave the trailer RF box on the trailer, & take the RF controller with you on trips, just in case you'd need to tow in an emergency with a TV not equipped, &/or if you have multiple TVs & not all with their own built-in controllers.
My guess is that you'll prefer the ease of the hand-held RF controller, rather than reaching for the one on the dash.
Cheers!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 02-12-2019, 02:55 PM   #10
GCinSC2's Avatar
A pic from the OP sure would be nice.
S/OS #001
Old 02-12-2019, 03:03 PM   #11
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
It surely will make a few of these posts obsolete.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is online now   Reply With Quote
Old 02-12-2019, 05:21 PM   #12
2016 25' Flying Cloud
2003 22' International CCD
2004 28' Safari
Sahuarita , Arizona
Originally Posted by Tom_T View Post
No Pat -
Cheers!
Tom
X2 -
I too have a Tekonsha RF and a Tundra with built in controller. I just use the Tekonsh and ignore the truck controller.
AzAirstream is offline   Reply With Quote
Old 02-12-2019, 10:41 PM   #13
PKI
PKI's Avatar
No Pat -- snip --
"Do I just ignore the one on the trailer and leave its vehicle remote disconnected so it doesn't activate?"
"If the existing module is left in place"
Disconnecting the module fron the umbilical is not leaving it in place.
Thanks for clearing up the confusion. Pat
Old 02-12-2019, 11:42 PM   #14
Tom T
Tom_T's Avatar
Orange , California
Just to be clear -
You only need to use & plug-in the hand unit in the cab when you're using the trailer mounted RF. I suggested bringing it along on trips in case needed for a non-brake-controller equipped TV used in a pinch.
Disconnecting the RF module on the trailer from the trailer's 7-pin, but leaving the module in-place - i.e.: leaving it mounted on the trailer's tongue - leaves it inert, & there is no reason to remove it from the trailer.
If the OP wants to use the TV's controller, then disconnect the 7-pin - leaving the RF module in place & forget about it.
It won't send any sort of confusing signal to the trailer brakes nor to the TV/controller when disconnected.
IIRC - if the OP plugged in the hand-controller into the 12v/Cig. Lighter socket in the cab - while the RF Controller box on the trailer is not connected to the 7-pin, then it will just show "n.c." on the screen of the hand unit.
I don't know if that clears it up, but I tried!
Cheers!
Tom
Orange CA
Tips for removing both wheels to replace both tires chaeha 2005 and newer - Bambi all models 16 10-31-2018 07:57 PM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 10:37 AM
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 03:17 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 11:46 PM
Which Brake Controller for Vintage Tow Vehicle?? commander31 Brakes & Brake Controllers 8 04-25-2007 06:37 PM
