Old 06-22-2012, 03:28 PM   #1
Someplaceville , Alabama
Brake Controller needed for a '66 22' Safari?
Hello All,
I am getting ready to drive to Oaklahoma to bring back a 22' Safari 1966. Do I need a brake controller for it? I have read that I do and that if I don't have one it will employ the magnetic brake system through the brake lights?
Does this sound correct? I am also thinking of the Prodigy brake controller if I do.
Any advise would sure be welcome. Thank you.
Raithier is offline   Reply With Quote
Old 06-22-2012, 04:10 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The brakes and the brake lights are on different pins on the trailer connector, and just running brake-light current to the braking circuit is likely to get you brief very-jerky brake application followed by a blown fuse in the tow vehicle.
I like having a brake controller, though we towed the Argosy 10 miles or so without one on the day I took possession. For a long, highway run like you describe I'd want trailer brakes, and you're probably legally required to have them in 1 or more states along the route.
I'm happy with the Prodigy P3, personally, though it requires some fiddling to get it right.
— David
Old 06-22-2012, 04:35 PM   #3
Ok I did some research and it looks like the trailer has Kelsey-Hayes brake control on the the trailer and that it has the 6 pin electrical adapter with brake pin. I will go with a Prodigy as well. Thank you very much for the help.
What Brake Controller Are You Using On Hydraulic Brake Classics? KJRitchie 2006 - 2010 Classic (all lengths) 30 09-25-2014 12:03 PM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
E53 w/ Tekonsha brake controller lights 3rd brake light when manual lever applied warmrain Brakes & Brake Controllers 10 11-14-2013 09:35 AM
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 02:17 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
