Old 05-06-2015, 04:04 PM   #1
1961 22' Flying Cloud
Parkville , Missouri
"Bolt On" vs. "Clamp On" Brackets
I've narrowed down my search for Weight Distribution, but I have to decide if I want a "clamp on" bracket or a "bolt on" bracket.
Since I'm a newbie on this subject, I want to hear if there are any major considerations I should think about.
The "Clamp on" makes sense from a multi-use standpoint, but it also seems like it puts a lot of trust into a couple of tightened bolts. Has anyone ever lost a bracket while on the road?
kirkrik is offline   Reply With Quote
Old 05-06-2015, 04:47 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
The brackets that came with my Curt WD system work just fine and I wouldn't worry about losing them. My brackets slip over the top of the tongue and are held in place by one bolt each. Especially when the bars are doing what they do, significant downward pressure is put on those brackets. If anything is happening to make those loosen up, you have bigger, more pressing problems to deal with.
http://www.curtmfg.com/part/17063
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-06-2015, 05:35 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Not on the road but I did have a Blue Ox clamp on bracket fly off and hit the side of my head while releasing a bar. I made the mistake of trusting the work done at a dealership. I should of double checked the brackets for proper install. Lesson learned the hard and painful way.
MICHAEL
Awning Clamp Assembly airtime Awnings 5 06-20-2018 05:23 PM
Blue Ox...Clamp on or bolt on? cajohnson 2005 and newer - Bambi all models 19 12-24-2014 07:43 AM
Bolt on Shock Brackets? Silverflames Axles 13 11-21-2012 09:11 PM
Propane tank clamp/bracket Dan S All Argosy Trailers 7 07-17-2010 11:47 AM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 07:08 PM
