Old 10-13-2012, 06:30 AM   #99
withidl's Avatar
2002 31' Classic
Houston , Texas
Evidently I failed to effectively communicate.
Originally Posted by mefly2 View Post
Wow. I like red! Our beamer was green, however and the closest repair facility is over 200 miles away ... we'll stay with the Ram for towing ... however stupid that may appear to some ...my experience and opinion is still mine. And just because the battery in our 300 series convert is in the back of the trunk has nothing to do with braking potential - handling twisties, yes; braking ability / fade resistance, NO. So I guess that I will keep an eye open for fleets of x5s as potential commercial TVs... should also be cheaper to operate than the darned old trucks anyway. E=m*v^2 .... hmmmm, now if we can just change that darned formula for energy ... I SAID, YMMV.
  • I used red hi-lite ONLY to reference your statements; no “rage” intended; maybe I’ll use green next time.
  • Stupidity and ignorance are two separate entities; one is only stupid after their ignorance has been logically enlightened and they reject the enlightenment.
  • Width of tires = pavement adhesion = stopping tractive effort.
  • Size of brake disks/calipers & venting = less fade = duration of stopping tractive effort.
  • Lower engine & battery placement = lower center of gravity = more stability/controllability during stopping tractive effort if AS brakes fail.
  • The X5 is initially expensive and somewhat difficult to have repaired if your stuck out in the toolies (unless you’re a ‘gear head” like me), but for 109,000 miles it has never failed me mechanically (yes I had warranty items) and does very effectively for the price replace the purchase of three separate vehicles basis the following:
    • Excellent stable, powerful tow vehicle.
    • Excellent build quality and luxury.
    • Excellent twisties capability when not towing.
withidl is offline   Reply With Quote
Old 10-13-2012, 11:41 PM   #100
mefly2's Avatar
2015 25' FB Eddie Bauer
No, W-
I think that you did communicate your condescension rather well with implied "stupidity and ignorance" reference (uncalled for IMO) but I couldn't agree with you more. Actually, we had two BMW coupes paid for as well as a convert; multiple Porsches and corvettes ... all with great handling and performance. However, none were designed to handle a load behind the rear axle. Yes, as you point out; they were all expensive. None of them had axles or load rated (not speed rated)tires with appropriate loading for LD TT towing. None had brake sizes designed to carry loads down long hauls. So, your denegratig reference to toolies must be precisely where we live... Spokane, WA is the closest BMW dealer (over 200 miles away) and we haven't bought a new BMW 4-wheel machine for over 5 years ... even with promised flat bed retrieval for warranty repairs... the BMW X-series that we tried simply did not inspire any sense of confidence when pulling a load- yes, I have been in multiple professional drivers classes. Sometimes mass in the e=mv^2 is the most significant variable to address for safety. Grasshopper, I have been enlightened for many years! YMMV as I said right up front.
Old 10-14-2012, 03:42 PM   #101
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
Payload...
As has been mentioned on this thread already, one needs to decide if they are comfortable pushing the design ratings on a TV, or living within the specifications.
While I am not an automotive engineer, I am an electrical engineer. In the design of telecommunications equipment, we will push the specifications of components in certain areas, but this is generally a) in consultation with the manufacturer b) based on considerable direct experience and c) validated with significant testing.
Neither are generally available to the individual car buyer.
As such, I like to live within the design specifications as I feel the consequences of being wrong are too significant.
A few more thoughts (these are my options based on experience in a design engineering field) -
  • There has been mention of tow ratings being marketing driven numbers rather than based on design specifications - I don't buy this. For a company like Ford and their F-150, there is simply too much at stake to release an under spec'd truck. Now I can guarantee there will be a group of conservative engineers at Ford who 'simply cannot believe the reckless specifications being published', but there will be a balance of conservative and more aggressive engineers and a balance will be achieved.
  • Tow ratings and payload ratings are derived to keep the vehicle safe over the life of the vehicle and under dynamic load. Forces applied to a loaded vehicle at speed in tough conditions are considerably higher than the forces at rest. We don't know how much margin is built into the design - but living within the specs again gives me some comfort. I also want that margin as my vehicle ages and rust starts to set in. If you live in an area with no rust, or plan on trading your vehicle often this is much less of a concern.
  • Work vehicle manufacturers will spend considerably more time testing their products under towing conditions as compared with Minivan or high end Sport utility manufacturers who have very few customers interested in this application. It's not money well spent for these manufacturer. This gives me more confidence in the design of the work truck to live up the rigors of towing.
Now back to the OP's questions of the suitability of a BMW X5. As in most vehicles, I don't look at the tow ratings, but at the payload as a starting point. The X5 (Canadian Spec) X5 35d has a maximum payload of 585kg (1290 lbs) If the intended application is pulling an Airstream with an 880lb tongue weight then this does not leave much for anything else inside the vehicle. If we allocate 350lbs for driver + passenger*, plus 50lbs for a hitch then we are at maximum payload. (plus watch any options, as they also eat into this payload specification)
The Mercedes SUVs look like a better choice as they have a higher payload rating. The GL350 has a payload specification of 725kg (1600lbs) which rivals most 1/2ton pick-ups.
*apologies to those folks that are considerably lighter...
MaxTow is offline   Reply With Quote
Old 10-15-2012, 12:39 AM   #102
OrangeKid
2013 23' Flying Cloud
Portland , Oregon
Originally Posted by MaxTow View Post
[/LIST]
Where did you find the Mercedes payload spec? According to Consumer Reports the GL450 has a maximum load (different than payload spec?) of 1210 lbs and the GL320 (2009 model) has a maximum load 1155 lbs. I could not find a maximum load or payload spec listed on the Mercedes Benz site. I have checked many SUVs and most have a maximum load rating of between 1100 and 1400 lbs. According to the 2113 MB Owner's Manual the maximum tongue weight rating of the GL is 600 lbs.
OrangeKid is offline   Reply With Quote
Old 10-15-2012, 08:54 AM   #103
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Maxtow,
Thanks for your very considered view on manufacturers' design ratings, the more input the better I think.
In terms of the means by which vehicle tow ratings are set then I'd again refer you back to the Truck Trend article, in which named figures from the manufacturers themselves say that it's more to do with marketing and competition. Indeed, the thrust of the article is to highlight the new SAE ratings system which is supposed to provide the market with proper and measurable methods of arriving at a tow rating, simply because tow ratings have been allowed to be set by marketing men and lost their true value.
Where I do agree with you is that certain vehicles, pick-ups especially, are tested in towing situations, quite often to the point of breaking them - it's the market they serve and as you say, a company like Ford cannot get it wrong. It's also true that other vehicles such as SUVs and Minivans are not tested much, if at all, to see how they tow. The bulk of buyers in the market for an SUV or minivan don't want to tow so it's wasted money for the manufacturers. Ask for a tow rating, though, and they'll offer you something well within the vehicle's capacity but won't, indeed can't, back that up with any meaningful data other than tire and axle loadings which, incidentally, are set by the manufacturer of the part, not the vehicle's manufacturer.
Better minds than mine have set up towing systems that go beyond the published design specification for a given vehicle, including the X5 as originally mentioned by the OP. Testing and real world experience has proven that these systems work so in my view, shouldn't be ignored when looking for a tow vehicle and trailer combination. However, if you're not happy to go beyond the manufacturers' recommendations then all is well and you'll still find that match of TV and TT that you require.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 10-15-2012, 10:23 AM   #104
Road Ruler's Avatar
Images: 38
Yes, with our car we are in the same boat with a limited payload capacity.
But the beauty of having a good sized Airstream with a generous payload capacity is that most of the goods we carry go in the trailer, not the TV. This arrangement works great for us.
Old 10-15-2012, 12:30 PM   #105
sierrafun's Avatar
Ladera Ranch , California
Mercedes Payload Specs
Hi OrangeKid,
I found the Mercedes Payload specs by calling Mercedes corporate and speaking with their customer service department. They then researched the information with the engineering department and provided me with the information. Attached is a spreadsheet I created which outlines not only the GL's payload but others as well. PLEASE NOTE THE MODEL YEAR of the vehicles I researched. This is especially important for the Toyota Sequoia as the payload changed in the 2011 and 2012 models.
Hope this helps you
Kindly,
sierrafun is offline   Reply With Quote
Old 10-15-2012, 01:28 PM   #106
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Nice job!
Old 10-15-2012, 02:36 PM   #107
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Sierrafun
Great job on all the TV specs. After looking at all the results on your spreadsheet, I don't feel so bad knowing that I am towing my 66TW and am over my GVWR (6900 lbs) by only 60 lbs.
Dan
TouringDan is online now   Reply With Quote
Old 10-15-2012, 05:06 PM   #108
Road Ruler's Avatar
Images: 38
.......and it boggles my mind that a large, Hemi, quad cab Ram that weighs almost twice as much as our mid size sedan can only carry 150lbs more than our car. What's wrong with this picture???
Old 10-15-2012, 05:53 PM   #109
sierrafun's Avatar
Thanks so much!
Thanks so much Bill and Dan for the nice compliments
@ RoadRuler:
Please keep in mind that the Dodge Rams I specked (both 1500 and 2500) are 4x4 and also top of the line in terms of trim (Laramie Limited).
This is important to note because the payload and tow ratings increase with the 4x2's and also fewer bells and whistles.
Being a lady, I tend to like bells and whistles in my SUV's & trucks which is what I specked for all the vehicles in my spreadsheet
Old 10-15-2012, 08:43 PM   #110
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
Pulled from the Canadian Mercedes Benz site:
Mercedes-Benz Canada - Facts & Figures - Technical data
Old 10-15-2012, 09:37 PM   #111
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
Originally Posted by MrUKToad View Post
Maxtow,
Having gone through the search for a TV, I have found that the tow capacity is not that useful a number. It is almost always the payload that limits the operation of the vehicle. So having a standardized test methodology will certainly aid the public (and salesmen) in comparing vehicles.
So maybe I'll modify my original statement. The tow rating of a vehicle might certainly be set by the marketing department - but (if published) the GCWR is the real number of interest. Subtract the GVWR from the GCWR and this (in my opinion) is the true tow capacity.
As for minivans and SUVs, you are correct - in the absence of significant testing, a manufacturer might decide to be ultra conservative in the specifications. However payload is something that all users need, so this is a detail that will get examined very closely both during design and system validation.
The X5 has limited payload capability when coupled with heavy towing. At maximum load, assuming optimal distribution, there not much headroom before one exceeds the GAWR.
My personal search ended with a Ford F-150 with the HD Payload package. This gives me a payload capacity of 2150lbs. But I want to be able to load up the truck with canoes, 4 people and a specialized bicycle and wheel chair for my son who has CP in addition to towing the AS. Is the truck ideal? No - I would like something more comfortable, and something that's not as big...but it fits my overall needs the best.
(BTW, we're changing from a '04 Toyota Sienna pulling a 20' SOB...kudos for pulling the AS with the Toyota. I'd love to see how that drives for comparison)
As for setting up 'underrated' vehicles for higher capacity towing - I can understand strengthening a hitch receiver for the forces involved. And towing more dead weight means more wear and tear on the TV's drive train - but that should not be a safety hazard (within limits) - just an issue of longevity. But I personally draw the line at overloading a vehicle.
Product testing is tricky business. To truly test design limits, one needs multiple samples and then test each to failure. This is not practical for anybody other than the manufacturer to replicate. So does this mean potentially passing up very capable tow vehicles that have ample margin for the job? Likely. But the point is, we (I) don't know which ones without the manufacturer's specifications.
Old 10-15-2012, 09:55 PM   #112
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
Originally Posted by sierrafun View Post
Hi OrangeKid,
Hope this helps you
Kindly,
Great Table!!
Be careful with calculating the payload capacity by subtracting the published curb weight from the GVWR.
The published curb weight will most likely be the minimum for the trim line being listed. Any additional options will add to this curb weight and therefore reduce the payload capacity.
In the case of my F150 recently purchased:
GVWR - Curb Weight = 2484lbs.
But by adding options such as the Max Tow package, running boards, etc, the maximum payload as listed on the label on the drivers door is 2150lbs.
Also - in the summation of payload requirements don't forget to add the weight of the hitch. In the case of a Hensly or Propride this is heavy at about 200lbs. Then of course there's the tongue weight of the AS (or portion there of if using a WD hitch)
