Old 12-08-2017, 12:14 PM   #1
Boise , Idaho
BlueOX - 2017 F350 Shank
Has anyone out there confirmed or not if the 9 hole Blueox shank will get low enough on the 2017 F350? I am trying to avoid going to the 11 hole if possible. I keep reading mixed reviews.
wponder is offline   Reply With Quote
Old 12-13-2017, 11:35 PM   #2
Maple Valley , Washington
I have one on my my wife's Audi that we use to tow. I'll test on my 2017 F350 tomorrow and will report back. Was supposed to do today but got lazy.
jimmyle89 is offline   Reply With Quote
Old 12-14-2017, 11:51 PM   #3
9 hole does not sit my trailer completely flush. I am going 11 hole. The trailer i have is a 19FC. I hope this helps.
Old 12-16-2017, 08:58 AM   #4
Boise , Idaho
Thanks Jimmy. was it close? Yours is about 1/2 in lower than ours. That 111" is log. looking like that is the path we will need though
Old 12-16-2017, 12:55 PM   #5
2017 30' Flying Cloud
Pleasant City , Ohio
When you say 9 hole - have you found a 9 hole shank that is a 2 1/2 inch, or are you using a 2 inch shank with a reducing sleeve?
KCCO is offline   Reply With Quote
Old 12-17-2017, 08:21 AM   #6
Boise , Idaho
Im just planning on using a 2" with my reducer sleeve. Mine does not have slop in it so it does not bother me.
Old 01-11-2018, 03:56 PM   #7
Boise , Idaho
In Case anyone runs into this. I ended up getting a Curt Welded shank. I got Curt #17173. It's 1/2 the price of the BlueOX 11 hole and also weighs 8lbs less. It's also shorter by 3 1/2 inches giving more ground clearance. I set it on the bottom hole. Things look good and level. When I was checking it prior to torquing the bolts down and before setting the bars. It looked like the nose of the AS was slightly down. After setting the bars it seemed spot on. I possibly could go one hole up and might need to if I have weight in the bed but I am going to run with this for now.
Ford's electronic sway control VS Blueox sway bars Vitaver Towing, Tow Vehicles & Hitches 30 06-09-2018 10:58 PM
Different BlueOx Shanks for Different Ball Mounts? zapper Towing, Tow Vehicles & Hitches 14 08-18-2017 02:17 PM
Blueox hitch, replacing original with secure bolts Vitaver Hitches, Couplers & Balls 27 11-30-2016 11:21 AM
BlueOx SwayPro 22FB Ford F150 ? ChrisnPatty Towing, Tow Vehicles & Hitches 12 06-04-2014 12:08 PM
BlueOx Hitch set-up? laynlow Hitches, Couplers & Balls 1 03-10-2010 07:15 AM
