Old 07-02-2013, 09:52 AM   #29
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Originally Posted by gypsydad View Post
SSquared- I have a 25' 08' FB and used to own an 06' 25' FB. With the 06' had a reese pulling with a 08' new Tahoe. Terrible towing the AS; no power and it never felt stable, even after having dealer set up 3 times. Dealer talked me into an 2012' Tahoe with newer AS (08'); said with 30 more HP and 6 speed trans would tow like they were made for each other; THEY WERE NOT! Now have 2013' Ford Echoboost short bed, and night and day difference. You don't even know the AS is hooked up! Wheel base, suspension, and power of the truck are so much different, you would have to drive yours against the pickup to understand and see for yourself! I tow to MT from TX and now have 30K miles on the truck. No problems and wife also drives from time to time with no concerns. Oh yea, I have the 750 lb bars on Blue Ox....link is between 7-8. No issues so far after a year, and much easier than the reese.
how close do you watch for ANY sway? Do you notice any at all? Small amounts that start but that the hitch mitigates and corrects? if it does move a bit, what is the most you have saw it move?
The PP folks seem to state that ANY movement could spell catastrophe and is thus highly undesirable...I guess I could buy that if it exceeds some small amound of oscillation...otherwise, the problem could be theoretical?
Your thoughts (and others) on describing sway in detail as you see it with this hitch is appreciated.
My plan is to video record my 4.5 hour trip back from dealer in oct/nov with a video camcorder HD, review it...and post it on youtube for other to analyse.
PharmGeek is offline   Reply With Quote
Old 07-02-2013, 09:53 AM   #30
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I assume I will need 1000 lb sway bars with it...with my tongue weight being 880 lbs...
Old 07-02-2013, 10:22 AM   #31
K.C. , Missouri
Is your tongue weight going to really be 880 pounds, or is that simply the claimed TW from A/S ?
If that is the TW of a dry trailer out the factory door, I would suspect it is going to be substantially higher in the real world once you are loaded to head out the driveway.
Next item for discussion is going to be whether you are going to damage the relative fragile riveted aluminum structure if you over-bar it and/or tow it with the heavy duty truck !
This will be as big a discussion as everything else so far. I'm going to throw out a pre-emptive strike here and say that potentially the air safe hitch may have a role to play ?
EDIT: you may want to call Inland Andy and pick his brain on all this. There are possibly those on this forum that may disagree with him.....but....it's hard to ignore his long experience in all things Airstream. ....just sayin'.......
gmw photos is offline   Reply With Quote
Old 07-03-2013, 12:34 AM   #32
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
What sway?? don't see any sway...my take with F150...not sure if there are other folks who have issues, but I do not notice...I travel 65-70 most of the time...
Old 07-17-2013, 11:32 PM   #33
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Final chapter on my SwayPro experience
Here’s the final chapter on my SwayPro experience.
We have just returned from a month long, 3900mile round trip from Colorado to Ontario. (We have a 25FB FC, towed by a 2010 Yukon Denali, with a SwayPro and 1000 pound bars) The first couple days the rig felt pretty unstable—it wiggled a little after every bump, passing vehicle, and steering input. My wife got a scary case of repeating oscillations when coming around an on ramp. I decided to make one more attempt at going to a tighter chain link. By putting three plastic blocks under the jack, and running the jack all the way up, I was able to get the extra link. But it was difficult to turn the brackets, and the trailer creaked a lot when we jacked it up. The good news is, our handling improved noticeably, though not as much as we hoped.
I should say at this point that our TV receiver flexes more than you would expect (2010 Yukon). When WD is applied, the shank develops a significant slope down toward the front of the car. I believe the flex here means the SwayPro bars wind up with less flex than they normally would. The guys at Blue Ox say the bars need to have a good amount of flex to work well, so maybe the receiver flex was preventing the SwayPro from working like it should. Who knows.…
Andy T. at Can-Am RV told me this receiver flex is typical of this vehicle, and he recommended having the receiver reinforced. Since we were heading east, we went to his shop to have the work done. After discussing matters with Andy, we ditched the Blue Ox and replaced it with an EAZ-LIFT Elite plus two friction bars. This made a big improvement—better than the SwayPro ever was for us.
When we changed hitches, two other changes were made at the same time. The other changes were
1) Reinforcing the receiver to cut out the flex
2) Shortening the horizontal part of the shank, which reduces the leverage the trailer has on the TV
Also, Andy’s set-up used more WD force than we ever used with the SwayPro. With 4 ½ links showing on the SwayPro, we got the front axle weight close to what it was with the trailer not connected. And the front fender height was also about the same. With the EAZ-LIFT (1400 pound bars), Andy set it up with the front fender ¾ inch lower than when unhitched, and the front axle weight is about 200 pounds more.
So our experience is not a proper apples-to-apples comparison of the two hitches. Still, my conclusion is that the EAZ-LIFT is the better system for us.
One other surprise to me was that I found it easier to apply the chain tension with the EAZ-LIFT’s old-fashioned snap-up brackets that with the SwayPro’s rotary brackets. I chose the SwayPro in the first place partly because I thought the rotary brackets would be easier and safer to use.
Compared to the EAZ-LIFT, the SwayPro still has some usability advantages:
• No grease on bars
• Bars weigh less
• More ground clearance
• No friction bars to mess with
• No clips to remove
• Don’t have to remove friction bars to back at sharpest angle
SSquared is offline   Reply With Quote
Old 07-19-2013, 09:45 AM   #34
gypsydad's Avatar
Passed right through Longmont on way to MT last month...no issues; no sway; Blue OX working well with 25FB 08' AS...towed to Glacier couple weeks ago on windy highway through Sealy Lake and Flathead area...no issues...Again; I understand there are several higher price hitches, but so far, Blue Ox working fine and 25' AS is well matched for my F150 short bed Echoboost.
Old 02-27-2014, 06:57 PM   #35
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I just saw an ad in the current Blue Beret for the Swaypro that says it prevents sway from happening. I checked it out at their site:
http://www.swaypro.com/p-1181-swaypro.aspx
They mention a 4-point system which calls to my mind the Hensley design.
Does anyone know from an engineering perspective if this is a "virtual pivot projection" type of hitch? I was under the impression that the PullRite (no longer manufactured for most vehicles) was a sway prevention hitch as the pivot point is literally/physically at the tow vehicle's rear axle (it's basically an upside down 5th wheel). The Hensley designed hitches (the Arrow and the ProPride) prevent sway as they virtually project the pivot point near the rear axle of the tow vehicle through the geometry of the 4-point hitch head.
The Blue Ox doesn't seem to have that design, but I'm no engineer. Can anyone tell if their 4-point system is a virtual pivot projection and whether it truly does prevent sway before it can happen? Thanks!
Old 02-27-2014, 10:43 PM   #36
Vitaminsea's Avatar
2012 28' International
Alameda , California
If you can, just make one adjustment at a time to the rig. That way you'll know better on what effected the change. Sounds like a great rig.
Vitaminsea is offline   Reply With Quote
Old 02-28-2014, 07:23 AM   #37
SteveH's Avatar
Common Sense , Texas
SwayPro By Blue Ox
The Blue Ox is not a pivot point projection hitch.
Regards,
Steve
Old 07-24-2015, 01:54 PM   #38
lindaebrewer's Avatar
2015 23' FB Flying Cloud
Sacramento , California
First significant trip - Sacramento, CA to Whistler, BC. Have BXW1000 installed by dealer on 2015 23' FC. MAJOR (scary) sway. Previous TT 17.5' Bigfoot w Equalizer was rock solid. Bad installation of Blue Ox possible???? Wrong TV 2006 Toyota 4Runner, V8 w tow package for this unit possible????
lindaebrewer is offline   Reply With Quote
Old 07-24-2015, 02:07 PM   #39
K.C. , Missouri
Let's see your scale tickets from three passes over the CAT scale. See Ron Gratz's posts for how to do it if you don't know the procedure.
Old 07-24-2015, 08:15 PM   #40
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
The SwayPro really needs some bow in the weight distribution bars to bring the sway under control. I'm not sure what the tongue weight is on a 23, but the 1000lb bars may be too much for that trailer. I think BlueOx sells 750lb bars. You may want to call them and see what they suggest. If the 750lb bars will distribute enough weight then I think they would give you better sway control.
Echelon73 is offline   Reply With Quote
Old 12-17-2016, 08:13 PM   #41
Stewball's Avatar
2015 28' Flying Cloud
Sumter , South Carolina
Total newbie here - we're taking delivery on a 2015 FC28 next week and we'd appreciate any relevant inputs on an appropriate hitch. Our tow vehicle is a 2016 Sierra 1500 Denali (4x4 with the max tow package) and we have never towed before. Our dealer recommends Blue Ox hitches. Our first trip will be a ~200 mile drive from the dealership to home. We'd be grateful for any specific inputs (or useful links) on this very heavily discussed issue. Thanks! (We hope to be at Canopener 2017 in January)
Stewball is offline   Reply With Quote
Old 12-17-2016, 08:21 PM   #42
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, Here us one link. There are several more in the hitch section.
http://www.airforums.com/forums/f464...er-147849.html
MICHAEL
