Old 08-03-2015, 12:47 PM   #1
Granbury , Texas
Blue Ox Sway Pro to tow 23FB?
Wondering if anyone might have towing experience with Blue Ox and the 23FB. Wanting to order me one but not sure if I need the 750lb bars or 1000lb bars?
I know they both will work but which would be better for that size and tongue weight?
I have heard the tongue weight of the 23FB can get to around 700-800lbs real quick with batteries and full propane bottles. Hitch weight added in there too can bring that factory 489lbs up quick. Thanks
cabinetmaker is offline   Reply With Quote
Old 08-03-2015, 02:18 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use the BO towing my 2006 23 with a 2011 Jeep GC Overland Hemi. Other then personal injury caused by my negligence it works fine. I use at the recommendation of BO 750 lb bars.
MICHAEL
Old 08-03-2015, 04:04 PM   #3
2014 28' Flying Cloud
San Antonio , Texas
BO hitch
I use the blue Ox on my 28 and am very happy. It's important to remove bar loading prior to lowering bars by rising the tounge of the trailer with hitch jack. I also bought a longer "Breaker Bar" to lock/unlock bars much easer to control longer bar. I get no sway while pulling with my F250 diesel and use the 1000 lbs bar because of the heavy tounge weight of my 28 footer, about 1200 lbs
Good luck
Dave
747 Mech is offline   Reply With Quote
Blue Ox Sway Pro AWCHIEF Hitches, Couplers & Balls 163 08-02-2017 02:15 PM
Blue ox sway pro Sjcjr Hitches, Couplers & Balls 31 08-02-2017 02:11 PM
Blue Ox Sway Pro W/D System Ganglin Towing, Tow Vehicles & Hitches 46 01-07-2017 08:17 PM
Equal-i-zer Sway Control Hitch vs Blue Ox Sway Pro airstreampek Hitches, Couplers & Balls 31 06-18-2014 10:56 PM
