Old 05-02-2015, 11:13 PM   #15
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
BTW AWCHIEF, meant to also say sorry about your accident, hope you are on the mend. Installer must not have torqued the bracket bolts for it to come off. Were both brackets' bolts loose? I will definitely check mine before next trip, thanks for sharing.
NWRVR is offline   Reply With Quote
Old 05-04-2015, 05:49 AM   #16
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Thank you, physically doing fine. All healed up. Going to try your idea of using a socket and long handle with an extension to get more leverage and further away from the brackets.
MICHAEL
Old 05-04-2015, 06:21 AM   #17
K.C. , Missouri
Some general comments to anybody considering this hitch: after using the blue ox for several years, my opinion is, if I am having to exert a lot of leverage on the wrench to turn the rotating brackets, that is a clear indication that I have not raised the trailer tongue high enough. My procedure is to get the bars slack enough, that they turn with almost no force at all. If I raise it high enough, I can literally turn them with my bare hands.
I would caution anyone using these to indeed be very careful if you are having to apply a bunch of torque on the wrench to release or install. The problem is, as Awchief found out is the saddle bracket can "twist" on the a-frame, and pop off.
Also, another point is, if the trailer is turned at an angle from the truck, that will result in one bar being "tighter" than the other, so be aware of that when dealing with the rotating brackets.
Chief, glad to hear you healing up. Scary indeed getting smacked anywhere in the head.
gmw photos is offline   Reply With Quote
Old 05-05-2015, 09:09 AM   #18
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
gmw, good point, that is why I take all the rotating effort out by using the adjustable air suspension to compress the bars. It makes for a much less dramatic hook-up/un-hook procedure.
Old 05-05-2015, 08:12 PM   #19
Longboard6's Avatar
2015 23' FB Flying Cloud
Sacramento , California
First Time Out With Blue Ox
Originally Posted by Longboard6 View Post
Anyone with ideas on Airstream dealership's installed Blue Ox Equalizer hitch? Having one as recommended installed on new 23FB Flying Cloud.
Just did my first day drive and unhitch. The ride was smooth as butter. The unhitch was easy and uneventful thanks to all the advice given here.
Thanks all,
Longboard6 is offline   Reply With Quote
Old 05-21-2015, 10:21 PM   #20
2016 30' International
Scottsdale , Arizona
AWCHIEF... glad you're alright and thanks for sharing this lesson with us!
DHart is offline   Reply With Quote
2004 Blue Airstream Land Yacht 30ft Class A Motorhome, Low Mileage! S2004 Blue Airstr eBay Watch Airstreams on eBay 0 03-22-2012 11:40 PM
Why do you have the Blue Beret? What is the Blue Beret for? PeeWee WBCCI Forum 12 02-22-2009 10:55 AM
Equalizer hitch and sway control Rod Pease Airstream Trailer Forums 15 04-07-2006 11:00 AM
Another hitch comparison - Equalizer vs. Blue Ox air19 Hitches, Couplers & Balls 13 11-27-2005 09:26 PM
Need for Equalizer?? smallfry Hitches, Couplers & Balls 10 01-24-2003 08:43 PM
