07-22-2010, 04:21 PM
2009 25' FB Flying Cloud
North Bend
Bike rack for A/S bumper?
Is there a bike rack that is recommended by A/S? I need to tow 3-4 bikes and planned to get a bumper mount 2-inch hitch receiver and then use a standard bike rack. But then I recently drove by a Class C on the side of the road with a collapsed bumper that had bikes attached to it. I want to make sure the bumper on my 2009 Flying Cloud is rated to hold that kind of weight.
07-22-2010, 04:25 PM
1967 26' Overlander
Winston Salem
, North Carolina
From what I have read over the years,
adding a bike rack to the back of an Airstream is a major No No.
This will cause frame separation according the experts.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
08-30-2010, 08:53 PM
1976 31' Sovereign
Springfield
, South Carolina
I was going to do the same thing as I have a two bike rack to carry one mountain bike on rear bumper but I guess that is out now.
08-31-2010, 07:02 PM
2002 22' International
Austin
Someone in times past posted info about a stand that you can use on the inside of your trailer to neatly carry a bike. Available at Lowes or Home D. not sure. Seems the best deal we have.
I've tried to think of a way to front mount, but the tanks and batteries are just too much in the way.
If you had read the stories about cracks in the frame of my model, you wouldn't think of carrying a souvenir pine cone back there, much less a bike.
08-31-2010, 07:08 PM
2008 25' Safari FB SE
Fort Smith
, Arkansas
I was just at the factory at Jackson Center and asked that very question. what I got was a resounding no no no. I figure they know what they are talking about, I am not going there>
08-31-2010, 07:10 PM
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
08-31-2010, 08:06 PM
2000 27' Safari
Berkeley
Bike Rack
Best to place them in the bed/rear of your tow vehicle. The construction of an Airstream is the same as an aircraft, a careful balancing of stress and flex, due to road/travel induced factors. If you don't have area in the rear of the TV, perhaps consider a front mounted receiver and a bike carrier. A few pounds bouncing around on the end of your trailer can produce very interesting results, from the structural perspective.
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
08-31-2010, 08:23 PM
1964 22' Safari
Ozark
, Missouri
Dang! I was gonna put one on my airplane too!
08-31-2010, 08:42 PM
1967 26' Overlander
Winston Salem
, North Carolina
From all the information I have read,
adding anything on the bumper of an Airstream trailer is a major No No...
No bike racks.....
I know Andy from InlandRV would agree...
Greg
Winston Salem, NC
WBCCI 5218,
08-31-2010, 09:21 PM
1976 31' Sovereign
Rock Hill
, South Carolina
Yes bikes, storage boxes, generators, etc. off the rear bumper are generally considered a no-no. Some have done it with no reported issue, but the general consensus is not to do it.
So let's turn the table on this and consider hanging an Airstream rack off the back of your bike?
Check out some of Skip's handy work.
One of my other hobbies - Airstream Forums
Kevin
"...the most confident critics are generally those who know the least about the matter criticised."
Ulysses S. Grant
08-31-2010, 09:43 PM
1959 24' Tradewind
The Grass Capital of the World
, Oregon
boo airstream bumpers
I find this dilemma highly disturbing.
Why did they make the larger safari-type bumpers in the first place? Seems like they were made to haul luggage, not bicycles, which these days seem to weigh as much as marshmallows.
Did they just not understand frame separation back then? Has anyone out there actually experienced rear end separation from carrying something as light as a bike on their bumper? And what exactly separates?
My traveling water-slide idea is now totally destroyed.
09-01-2010, 06:13 AM
2008 Safari 27 FB SE
2008 27' Safari FB SE
Locust Grove
, Virginia
FordTruck
2005 F-150 5.4L Supercab 4X4 (Betsy 3)
2008 Safari 27FB SE (Arvin as in RV'ing)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
02-18-2011, 10:49 AM
1999 34' Excella
Eureka
Bike rack
Last year I puchased a 2 in. hitch receiver from the front of my 2005 Dodge Ram 3500 dually. It was a stock receiver made by Reese/Cequent Towing products. Curt hitch manufacturing also manufactures a similar model. It requires the removal of 4 bolts, 2 on each side of the frame, where the bumper brackets are mounted. Put the new receiver frame back on, reinstall the bolts, and you've got a hitch receiver good for 500 lbs. on the front of your truck. This should be adequate for 4 bikes. My truck is 2WD but the clearance is OK. I used it on a caravan last summer and carried 2 bikes for over 10K miles with no problem. I used racheting nylon straps (3) to secure the bikes to the carrier and the eyes on the frame below the bumper. Hitch manufacturers make this receiver for all makes. Check out some suppliers and the price is reasonable and won't stress the frame of your Airstream trailer.
02-18-2011, 11:11 AM
1966 24' Tradewind
1984 31' Excella
Lynchburg
, Virginia
Airstream/Bike Rack
I agree with SpaceEgg. If you have a reasonable solid rear bumper, I can't see where you are going to cause any problem carrying a 50 lb bike and bumper rack on it. One of the best books I ever read was the auto biography of Bill Lear (designer of the Lear 8 track player and the Lear Jet). What drove him was designing stuff that others said was impossible to do. He did not believe what some engineers told him that could not be done, until he tried it himself. Some times he was wrong, some times he was correct!
JW- I am going to order the front Class III rack for my Tundra to carry a light dual sport motorcycle on the front of my truck. It is only $122 from Curt Manufacturint. That would be a great way to carry lots of bikes. Headlight illumination would be the only issue (new solutions have new problems ya no).
Dan
| Thread Tools |
| Display Modes |
