Old 04-20-2017, 02:38 PM   #1
2012 25' FB Flying Cloud
albany , Georgia
Bicycle hitch.
I have just got one of these at Lowes, so it can be returned. Is there anyone out there that uses one of these. The two bikes and the carrier will clock in at 95 LBS, so that does add quite a lot to the hitch weight.
ID:	283776   Click image for larger version
jmpgino is offline   Reply With Quote
Old 04-20-2017, 02:51 PM   #2
2005 30' Classic
Burlington , Ontario
Interesting idea, but I did notice this in the description .......
"Gross trailer weight capacity up to 4,000 pounds and a combined tongue weight of 400 pounds"
I'm not sure what the stats for your AS would be, but those numbers don't seem very high
I did see another brand of similar adapter (Curtis or similar I think) and it said "Reduces your hitch capacity by 50%.
As long as that works for you, sounds like a plan!
Old 04-20-2017, 02:56 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Even if you are within the weight restriction the bikes will not clear your tongue jack.
What are you towing with? if a truck or van consider a front receiver on the TV. The advantage is you can carry the bikes while the trailer is parked
2004 Excursion 4x4
Old 04-20-2017, 03:23 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I bought one to use with a pop up. I did not use it. There was a lot of play in it due to adding one more slip to fit connection....There is no way I would try to use it with a 25ft AS. I feel certain it would fail within time.
CRH is online now   Reply With Quote
Old 04-20-2017, 03:54 PM   #5
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I have one left over from my motor home days, would never use it on my AS because of that 4000lb disclaimer.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 04-20-2017, 04:21 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Bicycle hitch.
Don't do it!
It's only rated for 400lbs tongue weight - basically a basecamp size trailer.
If you hitch up to an airstream of most any size I would say that the leverage generated by your weight distribution hitch will most certainly cause concern - either you wont get enough weight transferred to the front axle AND/OR you would have to really load the tension bars and something would likely fail - either the extension itself, your hitch head or your hitch receiver!
Your shank needs to be as short as possible for proper weight distribution.
Bad idea dude be safe
wulfraat is offline   Reply With Quote
Old 04-20-2017, 06:16 PM   #7
dasams's Avatar
Palm Desert , California
Can you imagine the added leverage by pushing your ball out 8-10"?
^ This
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
airstream pulled by bicycle fancy pants Our Community 8 01-04-2008 09:45 PM
How to place BICYCLE RACK ? flyfishfred On The Road... 42 01-01-2008 02:38 PM
Bicycle rack tport40 2007 Safari SE 29 08-11-2007 11:29 AM
Bicycle rambling RedSHED Off Topic Forum 52 06-13-2007 12:16 PM
I want to ride my bicycle wheel interested Our Community 22 12-15-2003 01:35 PM
