Old 06-17-2016, 04:55 PM   #1
Opelika , Alabama
Better to wire lift jack to TV or trailer?
I'm completely restoring my AS and am wondering if I should wire the motorized trailer hitch jack to the electrical system in the trailer or to the plug in the tow vehicle. Any ideas?
Thanks.
racecannon is offline   Reply With Quote
Old 06-17-2016, 06:04 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Just wire it to the feed wire that goes from the umbilical plug to the junction in the trailer. Do you really want to have to go hook up the tow vehicle to the trailer just to raise or lower the tongue an inch or two?
Old 06-18-2016, 06:09 AM   #3
richw46's Avatar
Lexington , Kentucky
I thought they all had a wire that went directly to the battery box with an in-line fuse holder. That's how mine is set up.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-18-2016, 06:24 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have done it both ways. Prefer having the trailer jack wired to the trailer battery. Figured it out about the third time I needed to raise or lower the trailer to get the lawnmower under it...
However on my work trailers it is wired to the tow vehicle side, because they typically don't have a large battery on them, just the small one for the breakaway switch.
Aaron
WBCCI #XXXX AIR #2495
Old 06-18-2016, 12:56 PM   #5
Mission Viejo , California
To the trailer. What if you have to use a different truck?
Bill Lynch is offline   Reply With Quote
Old 06-18-2016, 01:50 PM   #6
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
If you wire the jack to your trailer battery, you have an extra option: If the trailer battery is dead for whatever reason, you can connect your trailer's umbilical your TV. Then, with your TV running you'll have plenty of power to raise/lower the jack.
Don't ask how I know this.
Rocinante is our 2014 International Signature 27FB
Old 06-18-2016, 02:52 PM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
The jack is fused for 30 amps. The wiring in the truck would not support that load alone. Yes in an emergence but why run the risk of burning up the TV wiring.
2004 Excursion 4x4
Old 06-20-2016, 08:48 AM   #8
1996 25' Excella
Tillsonburg , Ontario
Originally Posted by Rocinante View Post
If you wire the jack to your trailer battery, you have an extra option: If the trailer battery is dead for whatever reason, you can connect your trailer's umbilical your TV. Then, with your TV running you'll have plenty of power to raise/lower the jack. Don't ask how I know this.
Mine too. When the battery was dead the TV could be used to run the jack Also if the battery is out of the trailer (as in winter) you can use the TV to run the jack
My TV is fused 30 Amp right on the battery post with 8 gauge wire to the umbilical plug. Only time I blew the fuse was when the jack motor limit switch failed.
JCW
JCWDCW is offline   Reply With Quote
Which would you rather? Better brakes, better hitch, or better wheels/tires? bjmckernan General Repair Forum 30 07-17-2016 06:47 AM
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 10:40 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
Where to place jack to lift trailer BDD2939 Jacks, Stabilizers, Lifting and Leveling 1 03-02-2011 03:25 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
