Old 02-02-2015, 02:35 PM   #1
Grand Rapids , Michigan
Best locking receiver pin recommendations?
I need to replace my Reese receiver locking pin. The old one is pretty new but I had a devil of a time getting it unlocked today. Spray lube doesn't help so I need to get a new one.
Any recommendations?
crampshaw is offline   Reply With Quote
Old 02-02-2015, 03:38 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Not sure why you would need a locking pin?
Doug and Cheryl
Old 02-02-2015, 03:56 PM   #3
dznf0g's Avatar
Oswego , Illinois
Well, for me $199 in Rocktamers and $249 for an adjustable stinger. They do walk away.
-Rich-
Old 02-02-2015, 04:04 PM   #4
dznf0g's Avatar
Oswego , Illinois
I've had this one for about 5 years. Don't know if it's better or worse than any other. Shows little wear. I picked up the first 2.5" pin I found...at Farm and Fleet, IIRC.
Welcome to DeadBolt - Products - Hitch - RH5-XL
-Rich-
Old 02-02-2015, 05:10 PM   #5
r carl's Avatar
Lin , Ne
5/8 bolt with a self locking nut?
Old 02-02-2015, 07:02 PM   #6
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I used one that uses a barrel key lock with a 1/4 turn lock. It was out in the weather on my old truck for my 2" receiver for 10 years...no problems. The barrel key locks don't freeze up like those with a standard key lock. Had to get a new one for my new truck as it uses a 2.5" receiver. I got one from eTrailer that I like as it has a smaller profile...like this one...Diversi-Tech Quarter-Turn Chrome-Plated Hitch Lock for 2" Hitches - Tube Key Diversi-Tech Locks DT30005
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 02-02-2015, 09:20 PM   #7
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
"Bolt" locking pins are the only way to go! They are the only one that keys to your tow vehicle's ignition key. You just order one for your make and model, insert your key and presto, no more having another key to mess with. They are sealed against the weather also. I have had two, one for my previous GMC and now have one on my new F-350. The only drawback is you can't have them re-keyed, but I still like only having one key for everything on my truck. I have the auto-locking door on my Leer top that locks and unlocks with my key fob, no key for that task.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 02-04-2015, 08:58 AM   #8
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I just upgraded to a Titan Class V receiver, which I bought from etrailer. With the upgrade, I ordered the 1469DAT Stainless Steel Trailer Hitch Lock for 2-1/2" Receivers by Master Lock for $25 from them.
My preference is for stainless steel. Chrome plated steel will rust if the chrome gets nicked or worn.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Receiver Hitch pin hole repair ? Davis Hitches, Couplers & Balls 17 06-15-2017 06:03 PM
9 pin to 7 pin conversion ck21084 Electrical - Systems, Generators, Batteries & Solar 4 06-10-2010 02:58 PM
6-pin connector to AS 7-pin eugnicfrlie Towing, Tow Vehicles & Hitches 6 04-15-2009 10:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
