Old 06-06-2015, 05:59 PM   #1
Vashon , Washington
best 16' hitch setup
some say ballonly is ok with the 16'. Seems like sway is still an issue. What is best? Toyota Tundra tow vehicle.
guillaume is offline   Reply With Quote
Old 06-06-2015, 06:57 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
You did not say what year Airstream. That can make a huge difference as to the weight of the trailer. Personally I would go with the Andersen with that size trailer. You will need very little weight distribution but definetly some anti sway control will be required that the Andersen can safely provide.
MICHAEL
Curt Mfg. Weight Distributing Hitch Setup COArgosy78 Hitches, Couplers & Balls 20 06-28-2016 07:42 AM
Looking to buy a weight dist. setup best value? WineStream Hitches, Couplers & Balls 13 03-05-2009 07:27 PM
Best small green setup JoePfznik Tow Vehicles 1 01-16-2008 05:11 AM
Hitch Setup Jabba Hitches, Couplers & Balls 2 10-04-2002 10:33 AM
