Old 07-07-2015, 01:14 PM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Be very cautious adding rear airbags
This discussion was started on another thread and thought it was better to have its own thread. So here it is:
There seems to be a belief by some that one can add airbags on the rear suspension of their tow vehicle and get additional cargo capacity. This is not true and as a matter of fact they may well be creating a dangerous scenario from a vehicle dynamics scenario. Here is a quote from a tow vehicle dynamics expert:
"Stiffening the rear springs or adding rear airbags without doing so proportionally at the front, transfers more of the roll couple (roll resistance) to the rear suspension. This yet further loads up the outer tyre whilst cornering, thus increasing its slip angle. Here again if that footprint collapses or slides there is a very real risk of jack-knifing. This is not theoretical conjecture. It happens.
Because of the above, vehicle manufacturer's intended front/rear slip angle relationship should not be changed. If the rear suspension is stiffened (or air bags fitted), so should the front to the same degree (or a stiffer roll bar added) to maintain the intended roll resistance balance."
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2019 Canopenian
Alphonse is offline   Reply With Quote
Old 07-07-2015, 01:25 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Makes sense. Who is the "tow vehicle dynamics expert" ?
Doug and Cheryl
Old 07-07-2015, 01:36 PM   #3
Alphonse's Avatar
Lower Alabama , USA
The specific quote is from an author named Collyn Rivers.
Alan
Air #64439
TAC AL-8
2019 Canopenian
Old 07-08-2015, 08:07 PM   #4
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Al -
The 2011 to current F250 4x4 tend to sag in the rear under load. I've been thinking about adding the Firestone airbag system, not to add cargo capacity but to reduce the rear end sag and make the ride less stiff for the trailer. Our friends "Luckyducks" have done this and seem happy with the modification.
Others with the F250 4x4 have used mechanical devices to accomplish the same goal. One mechanical solution is to add an additional leaf to the rear springs, giving it the same spring setup as the F350. I haven't seen discussion of making adjustments to the front suspension on any of the rear sag solution forum threads I've read. I'm not saying it isn't needed, I'm just saying there are many people making changes to the rear suspension of their F250 trucks without doing anything to the front end.
There are many discussions about this F250 rear end sag issue, and solutions, on the Ford Truck, Powerstroke, and the Diesel Stop forums. I believe it has been covered here on AirForums as well. In the Ford truck world this topic generates as much passion, controversy, and emotions as the tire, hitch, tow vehicle, and WBCCI threads on AirForums.
Sadly, the one place I would not go for perspective on this topic is the service department of my local Ford dealership. If it isn't stock, they don't want to deal with it.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 07-08-2015, 10:04 PM   #5
Alphonse's Avatar
Lower Alabama , USA
Chuck,
The first suggestion I would give is to reduce some of the sag with restoration of load to the front of the truck with the WD hitch. I know you are familiar with hitch weight distribution so we won’t go into that. Of course the best is to also use truck scales to assure you are getting what you need.
The air bag vendors do market their systems to reduce sag. Unfortunately there is some anecdotal evidence here on the forum that they are also telling folks they can increase cargo capacity and that is simply not true. It also appears that some well-meaning folks here readily advise to add airbags to solve tow vehicle cargo capacity deficits. Both of these concern me because people come here to the forum to get information and they may rely on something that is promoted here that is simply not true.
In the pursuit of reducing sag with an airbag, you are modifying the rear suspension of the truck. The experts tell us that the addition of an airbag in the back suspension should also include corresponding changes to the front suspension. Without this you may well be creating the propensity for oversteer in your tow vehicle. This is dangerous territory from a vehicle dynamics perspective. This is why I plucked the quote from the author on the subject and posted it here to kick this thread off.
I am not surprised that Ford dealerships want no part of changing a suspension design because they would assume responsibility for the modification.
The static condition of raising the back of the truck to reduce sag with an airbag looks good and likely gives us a sense of comfort. But in fact you have changed the suspension system on the rear. The propensity for oversteer that may have been created will not necessarily show up until you get into an emergency condition such as a sway condition or the trailer beginning to push you going downhill causing a yaw in the tow vehicle. It is in these unstable conditions where this oversteer we may have inadvertently created bites.
I certainly do not claim to be a vehicles dynamics expert but I have had a deep enough interest in this topic to inform myself to some extent. My agenda with starting this thread here is to point out the danger of simply adding an airbag to a tow vehicle without an engineered change to the whole suspension system. We should be very cautious and challenge the competency of the salesman who is promoting a change to our suspension. I will again repeat a quote from a friend on the forum here, “Sometimes we must know more than the salesman.”
Sorry for the long winded answer. Hope it helps.
Alan
Air #64439
TAC AL-8
2019 Canopenian
Old 07-08-2015, 10:34 PM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
Originally Posted by Alphonse View Post
Chuck,
The first suggestion I would give is to reduce some of the sag with restoration of load to the front of the truck with the WD hitch. I know you are familiar with hitch weight distribution so we wonít go into that. Of course the best is to also use truck scales to assure you are getting what you need.
I certainly do not claim to be a vehicles dynamics expert but I have had a deep enough interest in this topic to inform myself to some extent. My agenda with starting this thread here is to point out the danger of simply adding an airbag to a tow vehicle without an engineered change to the whole suspension system. We should be very cautious and challenge the competency of the salesman who is promoting a change to our suspension. I will again repeat a quote from a friend on the forum here, ďSometimes we must know more than the salesman.Ē
The purpose of air bags is not to increase carrying capacity, but to level the truck when carrying varying amounts of payload in the bed in addition to the trailer tongue weight.
In the limiting case, oversteer is caused by rear axle weight share being in excess of 50%. Yes, roll angles, etc. can be used to adjust this initially, but in the end mass wins. If you're carrying this much weight, keep your speed down to avoid problems, esp. in slippery conditions.
My 1996 F250 has a 8800# gvw, and ~6000# capacity rear and ~4500# capacity in the front. Empty, the truck weighs 7200 lbs w/ 4000 or so on the front axle. When we're running at/over GVV, the rear has prob. something like 5000 lbs, and the front is 4200 or so, so if you took the truck
on a skid pad, you'd see oversteer - whether we used the airbags or not.
The airbags allow us to pull the trailer level, a good thing with Airstreams, and they cut down on porpoising significantly - important in CA, where the freeways are often heavily worn.
I do want to add air bags in front, but that's because the front suspension is heavily taxed w/ that 1000 lb diesel engine, and could use a little bracing after 200k miles.
As to leveling the truck w/ the WD hitch, the amount of force required to move a significant amount of weight onto the front axle of a 20' long crew cab pickup would not be good for vintage Airstreams.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-09-2015, 06:10 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Sag & wd
"As to leveling the truck w/ the WD hitch, the amount of force required to move a significant amount of weight onto the front axle of a 20' long crew cab pickup would not be good for vintage Airstreams."
Why?
I tend to agree with the WD option, the purpose of WD is to restore FA weight, weight equals sag, the restoration of which eliminates the 'sag'.
Old 07-09-2015, 10:57 AM   #8
1976 27' Overlander
Delta , British Columbia
I have a GMC 2500 HD with Firestone Air Bags. I installed them originally when I had a 2000 lbs slide in camper. I installed them for two reasons, #1 to bring the truck back to level (i.e. get rid of sag), #2 to control sway. My 2004 2500 HD would sway/rock with the camper before the air bags. With air bags at about 40 lbs pressure it took out all the sway. We have now sold the camper and upgraded to a 76' Overlander. When my fresh water tank is full I see some sag on the truck. I put about 25-30 lbs in the bags to bring the truck back to normal height, then do up the w/d portion of the hitch. Raising the back end up with the bags will transfer some weight forward simply by geometry.
Air bags are not for additional capacity, but they do allow the truck to handle the capacity better.
With respect to the oversteer, I drive pretty conservatively so I cannot comment. I have two young kids in the truck. My particular 2500 HD has the 6.0l gas engine which is about 800 lbs lighter than the Duramax so right there my front end has additional capacity.
Not an expert but it is what I have experienced.
Seabloom is offline   Reply With Quote
Old 07-09-2015, 11:12 AM   #9
2018 33' Classic
Newport , Pennsylvania
Wow
Many Airstreamer's want to push the envelope, tow with s jeep or a Honda van, just on the hitch, cheap hitch, build my own, modify the TV, buy a expensive hitch
hitching and towing is sort of like riding a motorcycle everyone has their own throttle and handle bars.. screw up and your skin is in the fire or follow good recommendations and quit pushing the envelope adding airbags, hitch modifications and on and on....Life is a highway ride at your own risk.
earl
EarlM is offline   Reply With Quote
Old 07-09-2015, 11:43 AM   #10
Cardinal283's Avatar
Dallas , Texas
Amen Earl! Everyone is over complicating this. This is a simple issue with a simple solution.... Don't try to tow with a vehicle that is underrated or near it's max. Bottom line. Airbags are not a legitimate solution. If it was tow vehicle manufacturers would put them on vehicles or offer them as an option. They don't for a reason. If you have excessive sag then you are either outside of the manufacturer's specifications or there is a problem with your suspension. Springs get old and weak with time and weight on them. Do yourself and everyone else on the same road as you a favor and address the issue directly.
Cardinal283 is offline   Reply With Quote
Old 07-09-2015, 11:49 AM   #11
Aftermarket Air Bags are like a girdle...if you need one, somethings wrong.
IMHO AB's do nothing to improve towing, and yes I have tried them.
But TETO...if they make YOU feel better when towing, that's all that matters.
Old 07-09-2015, 11:52 AM   #12
2017 30' Flying Cloud
Spotsylvania , Virginia
I added rear bags to my 2000 Dodge Ram 2500 4x4 with a HD tow package. Not for added weight carrying capacity but to reduce the jarring of 1000# of tongue weight going across expansion joints on the super slab. Run about 50 #'s in them and it makes my stiff suspension truck ride like a Lincoln Town Car.
KWN306 is offline   Reply With Quote
Old 07-09-2015, 11:56 AM   #13
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I've had Firestone AB's on my 2008 F-250 for the past 7 years with the on-board compressor. For me it has definitely helped with leveling my TV and AS, and also as important, it has basically eliminated the dreaded "interstate hop" . The naysayers that have not used AB's just don't know all of the advantages and instant differences a set will make on handling, sway control and overall "feel" of installed AB's.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 07-09-2015, 03:28 PM   #14
1976 27' Overlander
I find it interesting too that almost everyone who has posted on this (me included) have 3/4 ton trucks. Not small TV's.
My truck is a 2012 2500 HD and I really like driving with the truck level. The 2014 and 15 GMC 2500's c/w with factory AB's to reduce sag now.
Should also note the sag on my 2012 is far less than my 2004 was. Weigh capacity on the rear axle is similar.
My father runs a 2008 Chev 2500 HD with a 29 ft Dutchmen Denali and he relies a lot on his W/D hitch to keep him level.
Old 07-09-2015, 10:34 PM   #15
Maniacal Engineer
barts's Avatar
Why?
The wheelbase on my truck is 13'; the hitch is 4.5' behind the rear axle.
Say I wanted to move the effective tongue weight to be in the center of the vehicle. I'd need to apply (6.5 + 4.5) * 500 or 5500 ft-lbs of torque. If I'm carrying more weight in the bed, I'd have to crank it up more to level the truck. I'm way better off just leveling the truck w/ the air bags. I'm well within both rear and front axle loadings - this is purely a matter of ride attitude. It is much easier to adjust the air pressure than to fiddle with WD hitches.
- Bart
Bart Smaalders
Menlo Park, CA
Old 08-01-2018, 11:04 AM   #16
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Installed a Kelderman all air bag level ride air suspension system on the brand new 2012 Ram 2500HD Cummins on the drive from Indianapolis to Phoenix after taking delivery. The ride is comfortable for my full figured wife either towing or not towing. The original steel springs were not comfortable and all were removed during the conversion.
The axle ratings on the driver’s door post are the controlling numbers for the load as the tires at their rated pressures exceed the axle ratings.
Have towed our 2014 31’ Classic with no issues using a ProPriude hitch through the mountains and on the flats. The pressure in the air bags is automatically adjusted to the load to keep the truck level. We have a reasonable weight transfer to the front axle with the ProPride.
Old 08-01-2018, 11:43 AM   #17
MWBishop's Avatar
Huntsville , Alabama
Heck, I voiced my concerns about payload capacity to other RV'ers (TTs and 5'ers) and even RV salesmen and have numerously heard "I increased my truck's payload capacity by adding airbags and solved that problem".
There is a lot of misinformation and confusion out there!
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 08-01-2018, 11:58 AM   #18
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I don't think there is any dispute about air bags as a way to improve the ride under load. The crazy stuff comes in when people overload their axles using them. You still need to check things on a CAT scale .... The numbers on that sticker on the door post still apply.
Old 08-01-2018, 12:41 PM   #19
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
For those of us that have air suspension in some form: the correct sequence for hooking up a weight distabution hitch is as follows.
1. Before hitching up, turn off the air bag pump.
2. Hitch up normally and adjust the weight distribution bars as needed.
3. Turn on the pump and let the system settle out to the desired pressure.
If you do that you could turn off the pump because everything is stable unless your load changes. Watch the pressure gauge for a while to make sure there are no air leaks. I sure like my full air ride suspension system. So does my Airstream.
guskmg
Old 08-02-2018, 12:31 PM   #20
2007 27' International CCD FB
San Diego , California
In principle, airbags DO increase payload capacity. The primary component responsible for handling payload is of course the suspension, specifically the springs and their associated spring rate. The most fundamental change or upgrade to any vehicle to handle large loads is to increase spring rate. Adding bags indeed has the effect of increasing spring rate, and therefore load handling.
Whether every other component is up to the task, has enough structure, or necessary tuning, is wholly another question. Dynamically, the roll couple is tuning idea is interesting. But in practice, for a long body on frame pickup with generally low torsional stiffness and completely variable weight distribution depending on load, itís tenuous at best.
Legally, in respect to the stickered capacity, yet is another question still. Which airbag manufacturers have to dance around.
So itís left to the end user to play the game how they see fit. Risk averse individuals will draw a hard line interpretation.
guskmg
guskmg, youíre missing a critical step. Or youíre outright doing it wrong. This is the specific example of why there should be caution exercised when utilizing airbags.
Inflating airbags has the effect of lifting the axle. Lifting the axle has the effect of relaxing weight distribution bars. Therefore to adjust the WD bars prior to final inflation is a bad practice as youíre effectively reducing the WD applied. Many of us often use the tongue jack to lift the hitch point, to relax the WD bars for install or removal. Inflating the bags after adjustment has the same effect.
The steps you have is fine. But itís vitally important that you add a step #4 to adjust the WD after final inflation pressure is set. Only in this way, is there correct WD applied.
Another way is to have the desired airbag pressure set, prior to any hitch up and adjustment of WD bars.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
AS280 - Rear airbags bypassed dalefox Classic Motorhomes 45 02-17-2011 05:40 PM
Cautious or Paranoid? codybear Fun & Games 8 05-09-2008 04:55 AM
1990 345 Motor Home Rear Airbags Howard Lefkowitz Classic Motorhomes 5 05-11-2007 09:59 AM
To replace rear airbags on Classic 350 w/Tag Axle boones Airstream Motorhome Forums 0 05-06-2006 03:29 PM
Rear airbags needed for my 1988 345 motorhome Mr. D Mechanics Corner - Engines, Transmission & More... 2 04-03-2006 03:05 PM
