Old 08-08-2018, 05:25 AM   #29
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Who reads the * 😂
Originally Posted by RandyNH View Post
And the lower right corner of page 3 in the Ride-Rite brochure
* Never exceed your vehicle’s maximum GVWR.
Brochure
So we can forget about the GAWR?
The answer I got from the jobber.
"The Firestone air bags will increase your weight carrying capacity by
5000 pounds."
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 08-08-2018, 06:35 AM   #30
2007 22' International CCD
Sales droids only lie when their mouth is moving, obviously trying to sell you something.
That’s total BS. The axle is a mechanical thing and the rating is set by the bearings, strength of the materials, and size. Airbags are not going to do anything other than make it easier to overload it.
Old 08-08-2018, 09:40 PM   #31
Maniacal Engineer
barts's Avatar
Menlo Park , California
I've also got air lifts on my 1996 Ford, and they work very nicely to adjust for a level ride (and a level Airstream) as the bed load varies. I don't use a WD hitch, as it's really not necessary w/ a 500 lb tongue weight on an F250 w/ a 1000 lb diesel on the front wheels. I did the numbers - the weight on the ball reduces the weight on the front wheels by 117 lbs - less than either of us . Sometimes the truck is at GVWR, and sometimes 800 lbs below even when pulling the trailer - but adjusting the air pressure makes it ride nice. It also helps, as others have commented, on reducing the pogoing on some Interstates.
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 08-11-2018, 08:19 PM   #32
Storm Master
Ampman's Avatar
2005 25' Classic
I ran the Firestone bags on my old F-250 and they worked great. I put the Airlift bags on my current F-250 and they work even better. Airlift incorporates an internal Jounce stop that under zero pressure makes it behave exactly like the normal suspension before the bags were added. I air up to about 20 psi with the HA-WD and depending on what other trailer (cattle, hay, bobcat, dump, etc.) I'm hauling I'll run up to 50 psi to keep things level. Not only do things tow and brake better but I can keep my headlights on the road and not in other drivers eyes. I only use them for truck leveling and never load beyond factory specs.
Ampman is offline   Reply With Quote
Old 08-12-2018, 06:12 PM   #33
Vintage Kin
Fort Worth , Texas
The scale weights are a stand-in. Static.
Better had you increased the Steer Axle weight by 120-lbs than reduced by same. Especially without WD.
Worth your while to try WD.
AS280 - Rear airbags bypassed dalefox Classic Motorhomes 45 02-17-2011 05:40 PM
Cautious or Paranoid? codybear Fun & Games 8 05-09-2008 04:55 AM
1990 345 Motor Home Rear Airbags Howard Lefkowitz Classic Motorhomes 5 05-11-2007 09:59 AM
To replace rear airbags on Classic 350 w/Tag Axle boones Airstream Motorhome Forums 0 05-06-2006 03:29 PM
Rear airbags needed for my 1988 345 motorhome Mr. D Mechanics Corner - Engines, Transmission & More... 2 04-03-2006 03:05 PM
