Old 11-14-2012, 09:46 AM   #1
2015 30' FB FC Bunk
Phoenix , Arizona
Battery-op TOW DOLLY Recommendation?
Hello All:
We recently acquired a 25' Safari LS in place of our old 19' Bambi which we stored on a side yard next to our garage. We are hoping to do the same with the Safari however, it is a TANDEM axle and as you can imagine is not quite as easy to manuever with two of us to rotate it 90 degrees.
We were told that an Electric or Battery Operated Tow Dolly would help us immensly when hooked up to the ball hitch.
Can anyone recommend a good Dolly to use for a TANDEM Wheel Safari. We have to pull the trailer down our alley, and pivot it 90 degrees and then from there we do have a winch to help us pull it forward.
Thanks to any and everyone for their insight and help!!
TGadaire is offline   Reply With Quote
Old 11-14-2012, 10:02 AM   #2
1974 Argosy 20
Kooskia , Idaho
I know you will think this is stupid, but when I had a tandem axle 25' AS and a very very difficult place to put it, I would take off the rear tires to move it into place. The problem was that the sideways scrubbing of the dual's made it virtually impossible to move precisely enough to put it into place. By effectively temporarily converting it to a single axle unit I had a much easier time in placement. The dolly I used at that time was called a Maco Mule, but I have not seen them advertised in a lot of years. It was a manual, not an electric dolly and had to be used with great care as it could very easily allow the trailer to run away if not on a dead level surface.
Old 11-14-2012, 11:49 AM   #3
1974 Argosy 20
Kooskia , Idaho
A few minutes ago I was looking at Craigs List Phoenix (I winter here) and found a Power Mover for $775. Apparently it is commercially made.
Search Phoenix Craigs List, For Sale, recreational vehicles, airstream and it should come up, with the photo. It is electric, half hp motor. Nice that it is local to you.
Old 11-14-2012, 02:05 PM   #4
Denis4x4's Avatar
Durango , Colorado
A front receiver hitch is far better and considerably cheaper to move a trailer into a tight space.
Denis4x4 is offline   Reply With Quote
Old 11-14-2012, 02:13 PM   #5
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
a handy little bit of instruction, here - PowerWheel USA, LLC - Trailer Tips
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 11-14-2012, 10:57 PM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
+1 that's how we do it. Search for posts with regard to front hitches.
2015 25' Eddie Bauer Int Sp Ed
2015 Chev Duramax 2500; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
Battery Issues imuir Batteries, Univolts, Converters & Inverters 29 08-08-2011 07:27 PM
