Old 03-01-2019, 02:49 PM   #1
2019 30' Classic
Pleasant Garden , North Carolina
Bar weight and sway control
Do the ratings on the bars have a bearing on the amount of sway control provided? I am getting a little sway/push from my 30' Classic. When we picked the trailer up and our dealer set up the Reese Dual Cam WD hitch, he said the 1000lb bars it came with would beat up the trailer. He switched it to 800 lb bars. I am wondering if that was a mistake as far as sway control goes. BTW, my TV is a 2018 F250 4x4 CC diesel.
jlandreth is offline   Reply With Quote
Old 03-01-2019, 02:55 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think so. I have a much older 32 foot excella and have pulled it with both the 800 and the 1000 bars with the Reese Straight line hitch. I am happy with the 1000 and was unhappy with the 800. Of course how well it is setup might matter also. And the bars were slightly different lengths so I had to reset the arms.
Bill M. is online now   Reply With Quote
Old 03-01-2019, 03:08 PM   #3
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
I'm not familiar with the Reese Dual Cam, but I have the same truck and a Blue Ox Swaypro. I used to use 1000# bars with a 1/2 ton truck and could restore my truck's front axle weight and had NO sway. When I moved up to the F250, I had to get 1500# bars to restore my F250's front axle weight. I have to crank the bars hard to achieve full front axle weights, so I've had a few popped rivets - nothing major. I just replace the popped rivets and they never popped again. I have over 31,000 miles on my 2017 FC25FB.
I am a believer of big bars and full front axle weight restoration. But I too am having push/pull issues with my new F250 and have spent many days trying different setups to improve the situation. Have you done a three pass CAT scale weighing? You can see mine here: http://www.airforums.com/forums/f42/...ml#post2202254 and more posts of what I've tried to fix my F250 further down the thread.
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 03-01-2019, 03:12 PM   #4
2019 30' Classic
No, I haven't scaled it yet, that was going to be my next step. Noticed over on the Power Stroke forum there are people who aren't happy towing with their late model PS diesels. Maybe just a coincidence.
Old 03-01-2019, 03:19 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
On my classic 34' and Excursion tug, I use the Reese Straightline, with 1200# spring bars. 300000 miles and no damage, popped rivets (except one over and over again in the bathroom), or wrinkles! Love the way I have never felt sway!
The Ex is softly sprung so the more aggressive springs help keep everything level.
Old 03-01-2019, 03:36 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Really depends on how much weight you need to move and how stiff your TV suspension is.
For our rig....1200lb TW
560 to the FA
160 to the AS
720 moved= 1000lb bars with our Hensley hitch.
I'm not a fan of the hitches that depend on WD tension for sway control. If you don't require the tension you may not have the sway control you need. YMMV
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-01-2019, 07:22 PM   #7
2013 20' Flying Cloud
Westerly , Rhode Island
Reese rates their bars for "maximum" tongue weight of the trailer. Our 800 lb. bars are rated for 400-800 lbs which works well with our tongue weight of about 650 lbs.
smithcreek is online now   Reply With Quote
Old 03-02-2019, 06:36 AM   #8
2018 28' International
Fayetteville , Georgia
I tow a 2018 28 Serenity with a 2018 F250 diesel. I have no sway or push, using a FastWay E4 weight/sway hitch with 1000 lb bars. Every setup is different. I am using 6 washers and have no rise on the front axle and one inch compression in the rear.
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 03-02-2019, 09:54 AM   #9
2017 27' International
Galt , California
towing, tow vehicles
I have a 2017 F-250 4x4 lariat crew cab diesel, and I am pulling a 2017 27' FB International Signature. My tow package is a 4 point 1000# Equal-I-zer.
My old 2001 25' Classic Excella was towed with a draw-tite system. I have never experienced any of the "push -pull, or light front axle as I read about here.
My original trailer was towed by 4 different F-250 4x4 diesels, all with the DrawTite system. I had the dealer install the Equal-I-zer over the Blue Ox with the new truck/trailer combo. I don't have any experience with the Blue Ox, so I can't compare. I can say that the above listed packages performed well, and the truck drove/drives like nothing is behind it. My only issue with both trailers has been the amount of bouncing on our great California roads In Oregon( our only out state visits) I don't seem to have the problem of everything being on the floor.
absteen is offline   Reply With Quote
Old 03-02-2019, 10:19 AM   #10
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
The dual cam is supposed to have independent sway control adjustment and weight distribution. So, your first move is to understand the cam adjustment, assuming you have established that the 800's shift enough weight and your receiver is not flexing. If you are at max sway control for your 800's then you may need to do some load adjustment in the coach. The more weight that you can remove off the rear, the less mass/force your hitch has to control. All the elements are related. If your tongue weight is balanced with the 800's then you may need to move to a PPP if the sway control proves to be insufficient with the dual cam. Seems unlikely, but it will take some tuning to establish ideal for your rig.
Note that the Blue Ox Sway Pro hitch has dependent weight distribution and sway control. It is not the same game.
Good luck with your tune. Proceed one parameter at a time and be conservative with your adjustment. You will see more sway under some wind and road conditions. Verify it's the tune that results in improvement or degradation. Pat
PKI is online now   Reply With Quote
Old 03-02-2019, 10:20 AM   #11
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I have a similar setup TV and trailer, but I have a ProPride hitch. I also had experienced a bit of push and sway. After working with Sean at ProPride, adding more pressure on the bars (1400) helped.
What really helped me was adding a full tank of fresh water before towing as I was told by serveral 30 Classic owners here. It worked so well that I also gained 1 MPG in performance. I still get a small amount of sway, but that may be attributed to the ProPride hitch "swinging" from side to side in certain conditions and may not really be called dangerous sway.
I recently added a rear sway bar (ford) and Bilstein shocks and notice a big improvement in the trucks handling. My trailer is in AZ so I can't test the towing experience, but I believe it will be better. The Platinum f-250 2017 did not come with a rear sway bar.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 03-02-2019, 10:55 AM   #12
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
I do not find 2017 F250 rear Bilsteins available. (coming soon)
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 03-02-2019, 11:15 AM   #13
2016 27' Eddie Bauer
westminster , California
No kidding about the CA 405...some Cali roads are great but I've really taken notice of the surface irregularities in SoCal....that 405 is everything BUT flat.
alevinman is offline   Reply With Quote
Old 03-02-2019, 01:06 PM   #14
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
After looking at new trucks I decided to just do a full bulletproofing of my 2005 F250 6.0 which included Bilstein shocks all around and a lift kit to level the truck. It's a 4x4 Lariat with very low mileage. I'm towing a 2017 28' International with a 1,200# Equal-I-Zer 4 point system and couldn't be happier with performance. The only issue I have and it is likely due to adjustment is a small amount of squat on the truck. When it warms up I'll tune the hitch and check it on a CAT scale. I've only put a few thousand miles on the hitch but so far I have not noticed any adverse effects on the my AS. Because the hitch is stiffer than the 1,000# Fastway the dealer installed I expected to see chaos inside the trailer when I took it on our first trip with the new hitch ... not the case.
VaTravelers is offline   Reply With Quote
Anti-Sway Bar or WD with Anti-Sway for 19' FC? CanonFan Towing, Tow Vehicles & Hitches 32 09-20-2016 05:29 AM
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
