Old 04-05-2019, 10:07 AM   #43
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by ROBERT CROSS View Post
My 31 year old "Opinion"...
OK... then what is the point of my using 1400lb bars to move 720-780lb?
Our TW has no relevance to the weight being moved.
Seems to me the closer the bar is rated to the actual weight to be moved the better.
Soft ride less chance of AS damage.
Could it be that it's the design of your hitch that requires the stiffer bars?
Over engineered and poorly designed? ��
Porpoising has more to do with harmonic oscillation from the road surface than the WD setting.
It may dip bounce that was the problem, stiffer bars would limit the bounce and increase shock to the AS.
But what do I know? ��
I'm just an anknictdotal bucklenuster. ��
Ok; I'll bite...porpoising can be caused from a few different things, (or combination) including poor weight distribution/loading, bad shocks, and also could be bad set up with the WDH system....just saying. The BO system uses the "spring" loaded bars to help dampen/control the load of the TT and transfer the tongue weight back to the front of the TV for better control, right?? I'm not sure why you would mention #1400 bars and the load of 720-780lbs?? For BO, they offer 1000# bars and recommend if your above that TW, to move up to the next size bars; #1500 is what I use. They were stiff in the beginning but as I say, this system employs a "spring" effect with these bars which helps control sway, dampen load, and transmit weight back to the front of the TV...might not be same method for other bar systems folks are using... I only know after studying this system over the years and using it on the last 3 TT's, it works fine.
Important to consider the Mfg. recommended tire pressure also for the load of your AS...for a smoother ride...
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Anti-Sway Bar or WD with Anti-Sway for 19' FC? CanonFan Towing, Tow Vehicles & Hitches 32 09-20-2016 05:29 AM
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
