Hi, I'll be picking up our new 2006 16' Bambi International Friday (our first RV). The dealer has suggested installing a Husky weight distribution hitch with out any sway controls.
Does any one have experience with this set up on a 16' Bambi (3,500# GVWR)? And if so does this seem reasonable?
Or does any one have a better (?) recommendation?
Thank you,
Willy Gorrissen
My '78 Minuet is comparable to your new coach in weight, but is a little over 19' and also on a single axle. I went with a Reese Strait-Line Hitch that includes the Dual Cam Sway Control. To obtain the best results with my K2500 Suburban tow vehicle, I went with an older set of 350 pound weight distribution bars for my hitch -- and it performs flawlessly under all conditions. I use 550 pound weight distribution bars with the hitch when I tow with my softly sprung Cadillac Eldorado.
I suspect that your 2006 Bambi 16' will likely have a proportiantely higher hitch weight than many competing brands. My Minuet has a GVWR of 3,250 pounds -- typical loaded weight is 3,100 pounds -- with 525 pounds on the hitch. The recommendation that I received directly from Reese was that the Dual Cam system was acceptable so long as the loaded hitch weight is at least 400 pounds for the coach.
While a single axle Airstream coach is not typically prone to sway, I like the extra security of knowing that I have a quality sway control unit built into my hitch system. My experiences with friction sway controls was terrible, and my preference has been to avoid them if at all possible as they are an adjustment nightmare if you follow the manufacturers recommendations.
Good luck with your investigation!
Kevin
Kevin D. Allen WBCCI (Lifetime Member)/VAC/Free Wheelers #6359 AIR #827
IMHO, you should at the very least have a friction sway control for even a 16'.
I have one on my 19CCD. It performs both WD and sway control in one unit. Very simple to set up and hitch up. Works flawlessly. I'm not familiar with the Husky brand of hitch. I would do a little research before you commit to buy one. There is a reason why Equalizer and Reese are so popular......THEY WORK WELL!
lewster is right on with his comments about the Equalizer brand.
In the 1990s, I had a 21' Sovereign, and I bought the Hensley Arrow because I was towing with a short wheel base (Ford Bronco). The Hensley was a great hitch, and I never had trouble while on the road, with cross winds, semis passing, etc. However, we mostly dry camp, on uneven ground, and it was always a hassle getting hooked back up when time to go. Not a problem on paved areas, like my driveway or a parking lot, but on uneven ground it seemed things never lined up right.
Now, I have a 16' CCD and tow with a Dodge Ram 2500 (I know, I do most things backwards like this). I use the Equalizer hitch, and it works flawlessy. I agree with the previous poster who said the Hensley is over kill with the 16'. I will point out that, when I tried towing the 16' without installing the weight bars, there is a noticeable difference in how it tows, even with my large TV.
If you go with the Equalizer, you get weight distribution and sway control integrated in the same hardware. If you go with some other brand of weight distributing hitch, then be sure to get the kind that you can add the friction sway control later (a 2nd, smaller ball on the hitch head). Then, you can decide later if you want to add the friction sway control, it won't be a big deal at all.
Just my thoughts, buying the Airstream is the biggest step towards good towing!
I have a Husky hitch with weight distribution bars and a single friction sway controller. My 19' trailer pulls level and straight as an arrow. The hitch is rated up to 800 lbs. tongue weight.
BTW - LOVE the Chi-town trend in posters so far! Keep em coming!
Not to rock the boat here, but what is the 'logic' on the SC with a small 16'er and a big TV.
There is likely no 'wag-the-dog' or similar scenario. Is this the 'bigger is better', 'more hitch is just enough hitch' and the 'HUGE TV (w/mega motor/trans) with small/medium/ large-ish' trailer phenomina...? Where are we going here?
Just curious as it seems that gas/diesel is going to the strosphere or above, big TV prices will likely dive as a result, not to mention larger trailer units following due to 'operating costs'.... Not to mention the seeming upcoming drought of 'big' gasser motors..... None of these are positive indicators.
Not sure where I am going with this but the 'bigger is better' logic needs to be looked at sometimes.
Peace all - hope I can bail all I am going to get...!
FWIW, I did a Reese High Performance with friction sway control. Some on the Forums would tell me it's insufficient, some would say it's not necessary, and some would say it's downright dangerous. Some would say it's..... just right.
I noticed little tendency to sway both before and after installation. I more or less averaged the opinions I received to make my decision.
