Old 04-05-2018, 11:31 PM   #1
Anahuac , Texas
Balance wheels
Is it necessary to balance wheels on the TT? I will be putting new 16” wheels and tires on my 07 Classic also adding TPMS. And never noticed before that the existing 15” wheels and tires are not balanced, the trailer seems to tow just fine. So what y’all think 🤔.
Thanks Shb2777
shb2777 is offline   Reply With Quote
Old 04-06-2018, 12:01 AM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
It depends on your definition of "necessary."
I choose to balance all my tires and also use Centramatics (http://www.centramatic.com/balancers.rhtml). We camp extensively throughout the year and average about 12K annually. Our trailer is almost 16 years old at this point. Most of our trips are short weekend outings within 200 of home, but we generally do an annual continental tour of around 6-7,000 miles with many 300 mile legs.
Sustained highway speeds will build up temperatures in the tires which is the cause of many tire issues. Unbalanced tires build up heat rapidly. If you are staying nearby and traveling infrequently, you could choose to forego balancing but watch for abnormal tread wear and possibly popped rivets in the trailer shell per many posters.
Personally, I don't recommend going unbalanced. Of course, others will have varying opinions and reasoning.
Sirs Gawain & Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-06-2018, 12:41 AM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, always have your trailer tires and wheels balanced. Trailer brake drums are not balanced so I use Centramatics on my trailer.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-06-2018, 04:34 AM   #4
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
As mentioned, the trailer drums are not balanced. I once spun a bare drum on a wheel balancer to see just how out of balance it was. It was a lot!
Simply balancing the trailer wheel/tire won’t accomplish anything as a result of the drums imbalance.
We use Centramatics now...
Bruce
Barely getting by, towing our 16' Bambi with our Ram 2500 CTD "Moby"!
Bruce B is offline   Reply With Quote
Old 04-06-2018, 05:02 AM   #5
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Same as above. I have only had to replace one rivet in last 30000 miles
"We don't normally balance trailer tires....." Pick Tires 36 07-16-2012 02:30 PM
How To Balance Running Gear Inland RV Center, In Axles 26 07-08-2004 03:14 PM
Tire balance Melvin P. Thorpe Tires 12 12-30-2003 07:21 AM
anyone ever balance the airflow on a furnace? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 18 11-25-2003 12:16 PM
RV weights and balance gwsullivan Link Archive 0 08-21-2002 02:50 PM
