Old 08-05-2014, 02:01 PM   #1
1999 30' Excella 1000
small town , Maryland
Backing with weight distribution hitch
I visited a airstream dealer last week to buy a reese weight distribution hitch. They told me, '' Its only a forward motion hitch and not to back up with it''. Is this true ? Does everyone disengage the trunnion bars before backing up? I don't remember reading this on the forum, but I also can't remember what I had for breakfast. Who can back up with their hitch without breaking something? This website is the reason I own a airstream. Thank you Gregg
streaminwild is online now   Reply With Quote
Old 08-05-2014, 02:06 PM   #2
1974 Argosy 20
Kooskia , Idaho
I towed with a Reese square bar trunnion stile hitch for many many years and never had any problems backing up. It was not one which the straight line sway control system built in, but even then I never heard of issues with backing with them either.
I currently tow with an Andersen WD hitch, agin, no issues backing.
Old 08-05-2014, 02:17 PM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I currently have a 1997 31' Excella 1000 and use a Reese WD hitch. Mine is the one with the separate sway control bar. Backs up just fine.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-05-2014, 02:22 PM   #4
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
I have a reese wd hitch with a seperate sway control bar. I always take off the sway bar but not the wd trunnion bars before backing...never had a problem
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 08-05-2014, 02:24 PM   #5
2008 25' Safari FB SE
Frederick , Maryland
I also have the Resse WD hitch and have no problem backing in.
VWill is offline   Reply With Quote
Old 08-05-2014, 02:51 PM   #6
Thankyou for the quick responces. Now I know why backing up was never mentioned. Gregg
Old 08-05-2014, 03:00 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have backed up using Reese with snap up trunnion bars and Reese with dual cam trunnion bars. I had no problems with either. But, when turning and backing at the same time it really puts a lot of extra stress on the spring arms. I can understand how one could break when really stressed.
It's important to read and follow the instructions for whatever type of hitch you decide to buy. I read the install instructions for a Reece WD hitch, and backing up is not mentioned there.
Alan
Old 08-05-2014, 03:04 PM   #8
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I have a Equalizer 4 point WD and back up without any problems.
Old 08-05-2014, 03:07 PM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I used to have a Reese with the separate friction sway bar and forgot to loosen/remove it ONE time... bent the trunnion. The ball and this massively thick piece of cast iron just bent about 30 degrees. I now have the Hensley and don't loosen up the bars until I'm backed in. (I am very careful backing and avoid anything sharp turns while doing it.)
Carry ON.
Paula
Old 08-05-2014, 03:31 PM   #10
I'm glad that I asked this forum before buying. This dealer will match amazons hitch price, for streamers that need to know.
Old 08-05-2014, 08:55 PM   #11
2016 30' Classic
Erie , Colorado
ProPride I have I back just like a normal trailer. Only thing I do as a last step is to make sure the hitch head is re-centered. I have pieces of illuminescent tape that help with alignment as I back into the hitch. I can see them in the backup camera on the truck. After backing into a space I look at the camera, pull a little bit forward and then back up cranking the wheel to swing the back end to move the head back into alignment.
Reason for doing this is that if the head is shifted far left or right the power jack won't clear the spring bars. I don't loosen them until the jack has a load. Maybe wouldn't be a problem if I unloaded them first and then they would swing freely. Centering it takes just a moment.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 08-07-2014, 02:27 PM   #12
JFScheck's Avatar
Rockville , Maryland
Images: 33
Backed up with the ProPride all the time for many, many, many years - no issues at all!!!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 08-07-2014, 04:54 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
No problem with backing with our Reese dual cam hitch. I can jackknife it at almost a right angle with no problems. I do not use an additional sway bar.
Old 08-07-2014, 05:00 PM   #14
helenhindley's Avatar
2014 23' FB Flying Cloud
Spokane , Washington
Had the same conversation at the dealer about our new-to-us 23FB. We went with the Blue Ox when they assured us that system backs with no problems. We still intend to be cautious... hate to bend or stress anything.
helenhindley is offline   Reply With Quote
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
how works a weight distribution hitch remcolent Hitches, Couplers & Balls 5 11-10-2003 06:24 PM
Recommendation on weight distribution hitch davidlaxson Hitches, Couplers & Balls 30 08-31-2003 09:38 PM
