Old 08-07-2014, 06:09 PM   #15
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I've towed with a Reese Dual Cam for years and a lot of miles. No problem. The only advice I would offer is to quickly find a dealer who knows what he's talking about.
Larry. ����
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-07-2014, 07:18 PM   #16
1976 31' Sovereign
Oswego , Illinois
Smile backing up
Larry. ����
I agree with Larry about reese dual cam as I have 1 of original set ups never had problems even when jack knifed when backing with no damage, plus many miles as he stated find another not one who doesn't have idea what he is talking about.
Old 08-07-2014, 07:30 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
No problem with ProPride. Even backing uphill.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-07-2014, 08:00 PM   #18
r carl's Avatar
Lin , Ne
No problems with the Reese dual cam in any direction.
Old 08-07-2014, 08:17 PM   #19
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
I just started using the Blue Ox sway pro. And one of their selling points is to be able to back up with it.
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 08-07-2014, 09:20 PM   #20
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
No problem with backing the Andersen system. I am having a Blue Ox Sway Pro installed tomorrow. It is reported to also not be a problem backing up.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 08-07-2014, 09:51 PM   #21
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our ProPride, which does not use friction for sway control, backs easily.
Doug and Cheryl
Old 08-07-2014, 09:52 PM   #22
1999 30' Excella 1000
small town , Maryland
The only people I listen to are the Andys and this forum. Thanks fellow streamers
streaminwild is offline   Reply With Quote
Old 08-07-2014, 11:12 PM   #23
mefly2's Avatar
2015 25' FB Eddie Bauer
EQ WDH that we back with often - no problems.
Old 08-08-2014, 04:26 AM   #24
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
I have backed my previous 25 and 27 footers into many a spot between semis in the truck stops and into tight back in camp sights and have never had a problem with the Reese dual cam weight distribution sway control hitch. Maybe checking with another dealer would be good as this advice sounds almost like they have no idea what they are doing. Either that, or I do not know....mmmm....
Or, possibly someone was confusing backing while flat towing a vehicle behind a motorhome. This is impossible without severely damaging the towing setup and towed.... In almost all situations. Apparently there are some super talented folks who can back straight, but I have never seen them.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4065 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 08-08-2014, 04:33 AM   #25
Tincampers's Avatar
Sneedville , Tennessee
If you are going to Foley, be sure to ask for Gary to install your hitch. He knows his stuff.
Tincampers is offline   Reply With Quote
Old 08-08-2014, 08:11 AM   #26
AWCHIEF's Avatar
Images: 33
Gary is installing my hitch at this very moment.
MICHAEL
Old 08-08-2014, 08:29 AM   #27
I'll add Gary to my list next the Andy's
Old 08-08-2014, 11:19 AM   #28
AWCHIEF's Avatar
Images: 33
Just got back home with my new Blue Ox Sway Pro. I can confirm there appeared to be no issues with backing.
MICHAEL
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
how works a weight distribution hitch remcolent Hitches, Couplers & Balls 5 11-10-2003 06:24 PM
Recommendation on weight distribution hitch davidlaxson Hitches, Couplers & Balls 30 08-31-2003 09:38 PM
