Old 10-07-2016, 11:02 AM   #1
Summit , New Jersey
Backing question
Simple question. When you are ready to back into a site how far do you go past the pivot point? Do you go to the rear axle or do you clear the tail?
cirrusdriver is offline   Reply With Quote
Old 10-07-2016, 11:12 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The more the better. Clear the site with the back of your trailer. This lets you start the turn before the axles get to the pivot point. Often on thinner sites you will have to almost touch the edge of the site with the axles so take as much advantage as you can to keep from jackknifing.
2004 Excursion 4x4
Old 10-07-2016, 11:13 AM   #3
Gainesville , Florida
I go to the tail and use the mirrors if possible or a spotter.
xrvr is online now   Reply With Quote
Old 10-07-2016, 11:16 AM   #4
1976 31' Sovereign
Oswego , Illinois
There are so many variables with road width, hard to answer your Q. but I always clear site with rear.
Old 10-07-2016, 11:22 AM   #5
Summit , New Jersey
Excellent feedback. Thank you.
I'm getting better. Mirrors. Wife. Walkie talkies.
Old 10-07-2016, 11:54 AM   #6
2008 27' Safari FB SE
Long Beach , California
I have found that much of my challenge with back tends to be the width of the road that I'm backing from. When I first started, I always focused on and intimidated by the width of the trailer space. Instead, it's really been an issue of how wide I can or cannot swing my truck and obstacles on the roadway/path.
Also - this little "trailer reversing game" online helped me a lot with visualizing and understanding the trajectory of the trailer. I don't actually follow their little zig-zag road, but rather work on a clean 90-degree backing scenario.
Give it a try:
LBOskiBear is offline   Reply With Quote
Brake Backing Plate Question Kris. Brakes & Brake Controllers 2 11-30-2009 04:03 PM
Tips on backing up and Turning radius NewStreamer On The Road... 36 08-12-2006 08:27 PM
Backing with a Hensley Steve Heywood Hitches, Couplers & Balls 26 08-23-2005 10:30 PM
Creeking/Shaking only in backing sovereignrwe Axles 6 07-26-2004 12:34 PM
Extreme Angle Backing Airstreamer67 Our Community 11 05-19-2003 08:45 AM
