Old 08-18-2009, 07:04 PM   #43
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
You are braver than I am. I would surely done more damage to both house and Airstream.
Family of Disney Fanatics
WBCCI# 4821
Old 08-18-2009, 09:36 PM   #44
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
It looks like you ended up with a beautiful home Michelle. And a snug fit for the trailer. You and Robertsunrus are going to be trading parking stories I can see.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 08-18-2009, 09:44 PM   #45
Central , Mississippi
Some folks will go to extremes to limit courtesy parking
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-18-2009, 10:15 PM   #46
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Barry
Hi, Barry. Hey, Hey, Hey, hope you don,t mean I have to hit my house!
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 08-18-2009, 10:34 PM   #47
catson4's Avatar
1991 34' Limited
Port Orchard , Washington
Remember that only one tire will be on a short ramp at a time and the other tire will STILL be supporting it's share ( 1/2) of the load per side..
Get a piece if 4' X 8' X 3/4" EXTERIOR plywood. Rip it into 4 pieces that end up being 24" wide X 48" long. Also buy a couple of 2 X4 s and and a couple of 1 X 4s so you can make the supports that go under the plywood. This will give you TWO 2' X 4' long ramps that will not be that heavy to move around. The 3/4" ply WILL hold your trailer, one wheel at a time cause you are not going to be on it that long.
Throw on a coat of KILZ oil based primer and a coat of exterior paint and you are ready to go for the next few years.
This is not a case where the weight of a given tire will be carrying all the load. No more than it is if you run over a 1 X 4 board in the road or a speed bump. . ALL the tires will carry their respective loads.
By having 2 ramps, this also gives you the ability to back in at an angle and still hit theramps.
JMHO
Claude
One bazillion fish
1991 34' 60th Aniversary Limited Edition #008
2007 Chevy 2500 HD Duramax/Allison
One big parade float & a 40' Wells Cargo 5th wheel trlr.
"Wake each morning & Smile at the GREAT DAY you about to experience"
www.catson4ponds.com
catson4 is offline   Reply With Quote
Old 08-19-2009, 08:09 PM   #48
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Barry
Thank You. I like the house. The deal was I had to have a place to park the trailer. The distance between the house and the fence is 10'. The trailer is 8'6". I should have a much easier time the next time around.
Michelle TAC MT-0
Sarah, Snowball
Old 08-19-2009, 08:12 PM   #49
Keymar , Maryland
Actually, I do have courtesy parking. 30A at curb and water from a hose. I had to get the trailer out of the driveway and I could not leave it in the street. Not safe from other vehicles.
Michelle TAC MT-0
Sarah, Snowball
Old 08-19-2009, 08:17 PM   #50
Keymar , Maryland
JMHO
I made two ramps out of 6 2X4s. I laid one on the ground in front. I screwed two pair together and put the against the curb. 1 1/2 step each time. the last 1 1/2 step was up to the curb.
Worked great and is was cheap. a total of $9.
Michelle TAC MT-0
Sarah, Snowball
Old 08-25-2009, 08:42 PM   #51
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I appreciated the pictures. I have made a few scrapes in my time.
As a side note, there are linked plastic treads sold for use by Bobcats and mini-excavators to prevent damage to lawns. My Dad used to use 2x12's (guess who got to move them as we backed along). A real help on muddy days. Slow, though . . real slow.
backing, curb, ramp
Excella 31' Curb weight wvmiller 1978 Excella 18 10-10-2014 04:56 PM
Curb Weight slow-canoe Argosy Motorhomes 10 07-06-2009 07:00 PM
no water from curb side faucets lefthandtim Plumbing - Systems & Fixtures 6 10-06-2008 05:37 PM
Curb Feelers? Foiled Again Ribs, Skins & Rivets 4 03-17-2007 10:36 PM
Curb side galley window pipsmith22844 Upholstery, Blinds, Walls & Interior Finishes 1 03-16-2004 09:10 AM
