Old 08-02-2009, 11:40 AM   #29
richinny's Avatar
2011 34' Classic
ouch $$$ maybe you can get a used jack with a bad motor?
Ricky
Old 08-02-2009, 01:02 PM   #30
Gainesville , Florida
Landscape timbers, much lighter than 4x4s. Just lay them next to the curb side by side, takesup about half of the 8 inches. Tires can easily roll over 4 inches. They are easily half the weight of 4x4s and cost about 4 bucks apiece here in fl. zz
Old 08-02-2009, 01:02 PM   #31
Bought mine at Home Depot. zz
Old 08-02-2009, 01:29 PM   #32
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by thecatsandi View Post
First I have to replace my jack. I finally after three years bent it, badly. ouch. $485 to replace.
Been there, done that. Fortunately (I guess), I was at Jackson Center at the time.
Family of Disney Fanatics
WBCCI# 4821
Old 08-12-2009, 04:07 PM   #33
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Good thread. Will keep for reference as I have contemplated this problem too.
Will look forward to pictures!
Old 08-12-2009, 05:49 PM   #34
casarodante's Avatar
2012 31' Classic
Here is a pic of my curb and solution (as mentioned above). You can also see the trailer tire marks from the hard angle I need to do.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 08-12-2009, 06:43 PM   #35
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
If this is going to be a permanent parking spot, and you've gone through the pains and expense to move other items (gas meter)...why not address having a contractor come over and cut a section of the curb and re-pour it for your needs.
Alwhisman is offline   Reply With Quote
Old 08-12-2009, 07:11 PM   #36
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Michelle, not to be a wet blanket here, but I think you're over-concerned about damaging your tires, and you're over-engineering what you need. Frankly, a 2x6x8 cut into two 4" pieces will be sufficient to get the trailer easily up and over the curb. You place them approximately where you need them, back up near the curb, set them where they need to be, and then back up over them. I've done that a bazillion times over the years. Slow and easy is the key. Actually a 6" curb is no problem even without the 'ramp', but the 2x6 does make it a little easier. The biggest issue is whether or not the overhang is too low to back the tires up to the curb without damaging the tank drain plumbing by dragging it on the ground.
Roger
Old 08-12-2009, 07:18 PM   #37
richinny's Avatar
2011 34' Classic
The stacked 2X4s most likely screwed together will be the answer.
Easiest to store and light enough to move easily. (Changed my mind about the ramps)
i think Michelle has found her solution. i think the curb was more than 6".
also, she's only allowed one curb cut.
Ricky
Old 08-13-2009, 09:15 PM   #38
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I bought six 2X4X8s screwed two pair together. I put one pair next to the other and the singles in front of the pair.
The curb is just under 6 inches.
Michelle TAC MT-0
Sarah, Snowball
Old 08-13-2009, 11:23 PM   #39
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I'm lost here in this discussion about ramps; Why do you need an eight foot wide ramp for eight inch wide tires? [maybe 24"s each] You have seen my driveway, someday I post pictures of my very narrow street. It's very close, but no ramps yet.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-14-2009, 12:00 PM   #40
2012 31' Classic
I would LOVE to see a video of you backing in there!
On the road!
Old 08-14-2009, 05:53 PM   #41
Keymar , Maryland
Ok here are the pictures. the video would have lasted 1.5 hours.
The 16 ft wide ramps were perfect. I hit one side of the stack with the right side tires and the left side hit about the middle of the other stack.
The process of getting in the back yard was difficult. It was my first time. The receiver on the front helps a lot!
ID:	85371   Click image for larger version
ID:	85373   Click image for larger version
ID:	85375   Click image for larger version
ID:	85377   Click image for larger version
Michelle TAC MT-0
Sarah, Snowball
Old 08-14-2009, 05:58 PM   #42
Keymar , Maryland
The damage... I got too close to the house The hook caught the gutter. The running light scraped the house. I had help or the damage would have been worse. The divot which is about 5 inches deep was from the weight of the truck and tongue weight of the trailer.
ID:	85379   Click image for larger version
Michelle TAC MT-0
Sarah, Snowball
backing, curb, ramp
Excella 31' Curb weight wvmiller 1978 Excella 18 10-10-2014 04:56 PM
Curb Weight slow-canoe Argosy Motorhomes 10 07-06-2009 07:00 PM
no water from curb side faucets lefthandtim Plumbing - Systems & Fixtures 6 10-06-2008 05:37 PM
Curb Feelers? Foiled Again Ribs, Skins & Rivets 4 03-17-2007 10:36 PM
Curb side galley window pipsmith22844 Upholstery, Blinds, Walls & Interior Finishes 1 03-16-2004 09:10 AM
