Old 02-10-2014, 05:20 AM   #1
2014 22' FB Sport
Atlanta , Georgia
Back a 22' into a driveway?
Is it even possible to back a 22' Sport into a driveway on a residential street? My street is kind of the standard residential street--you know, maybe just over three car widths' wide--and I can barely back my popup into my driveway. It is possible through some trick of Airstream Magic to back my new 22' in when I bring it home in a few weeks? I will have the equalizer hitch and sway bars on, and I drive a relatively long Toyota Tacoma Access Cab, which of course restricts turning angle and adds length, respectively.
Belbein is offline   Reply With Quote
Old 02-10-2014, 05:54 AM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
You can do it!! I do it in our subdivision with an average street width with our 29' and now I do it with our 32. A Single axle of course is always trickier because it will turn on a dime. I'm not sure what you have but with tandem axles for me it's much much easier. Again, you can do it. At first Katie would stand behind me and we would talk on cell phones with mine on speaker and she would give me "words of encouragement" to help but now I just back it right in. Practice practice. Maybe take it to a big box parking lot first and practice. Good luck.
Rob
Skatiero is offline   Reply With Quote
Old 02-10-2014, 06:01 AM   #3
2000 30' Excella
Toledo , Ohio
I do it with my 29' and up a hill , It's easier when no neighbors are watching
just go slow and use your mirrors .
woodfox45 is offline   Reply With Quote
Old 02-10-2014, 06:36 AM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I do it on a much narrower street- our street is only 2 car widths, in a short block with stop signs at each end on a very busy street. It is not angled like a campsite, it is a 90 degree angle- so it will never go in on the first try- it is a series of pull up, back up, pull ip, back up until it is in- then I give up on getting it straight and leave it crooked in frustration- i have come to the conclusion that it will always be crooked in relation to something- nothing on this lot is square- if it is lined up with the house, it is crooked to the fence or shed or something else- I learned to not be OCD about, put the truck in park, and go on in the house-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-10-2014, 07:07 AM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
The easiest thing to do is get a front receiver, then add a cheap triple ball to that receiver & hook the trailer to the front of your tow vehicle & back the trailer in, while driving facing forward. I have done this on both of my tow vehicles & this works great. The added bonus is that you can also use it for a bicycle rack or cargo carrier.
Good luck,
Colin
Colin H is offline   Reply With Quote
Old 02-10-2014, 07:41 AM   #6
rideair's Avatar
The first thing you need to do is take off any sway control or undo any kind of pressure on the system, people have snapped them off by backing up with them on since it could bind.
Second, learn to use your mirror's if you don't already and that should be all you need. If the hole is wide enough to get it in, one should be able to do it. To put my trailer in my driveway, I have to back through a space between my house and a wall that after the width of the trailer leaves less than six inches on either side.
MIRRORS, Mirrors, mirrors, if one learns the correct use of them, you and can back up and put any trailer you want anywhere, if you don't, you'll be looking for drive through sites the rest of your life ;-)
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 02-10-2014, 08:29 AM   #7
2014 16' Sport
Route 66 , Arizona
Follow this technique, you'll have no problems :
Skooter is offline   Reply With Quote
Old 02-10-2014, 01:45 PM   #8
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Haha That's how it was backing into my site on our Safaris maiden voyage. Nearly lost my mind with 20 drunks yelling directions. Up the windows. Turned up the radio and used my mirrors.
Sent from my LG-E617G using Airstream Forums mobile app
Cyquest is offline   Reply With Quote
Old 02-10-2014, 02:30 PM   #9
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Should not be any problem off a normal width street. The longer the trailer the easier it is to back. If there is no traffic pull across both lanes when you start so your turning angle will be less than 90 degrees.
If you don't already have convex mirrors for a wider view ad them .
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-10-2014, 03:04 PM   #10
Central , Mississippi
A good rule of thumb; if you can tow it out of the driveway, it's possible to back it into the driveway.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 02-10-2014, 03:06 PM   #11
Goal15's Avatar
Holly Lake Ranch , Texas
Of course that begs the question..... chicken or egg?
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 02-10-2014, 04:11 PM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
I can back my 30' into my driveway with my Suburban which isn't much shorter than your Tacoma. However, my driveway is two car widths wide at the end which helps.
I am quite sure that I could back your 22' into your driveway.
Whether you can do so depends on skill, which varies considerably among drivers. As others have noted, stage fright affects people backing trailers.
You might want to consider practicing with cones in an emty parking lot.
Old 02-10-2014, 04:20 PM   #13
1976 31' Sovereign
Oswego , Illinois
Smile Backing in driveway
If you have electric control mirrors you can rotate so you can see sides [corners] of drive when on angle, this is the way that pro semi trk drivers do to back in tight spots. Bill
Old 02-10-2014, 04:45 PM   #14
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
OK My favorite trick. With Variations.
Lay down a TRACK for the roadside trailer tire to ride on - which will result in a perfectly parked RV. In bright sun this can be water. Use a spray bottle or a big pitcher. Position the trailer ready to back in, get your pitcher or spray bottle and draw a gentle curve from the trailer wheel back on the pavement turning toward the drive, over the curb, and finally where that tire will have to end up to have the whole trailer in the drive rather than the shrubs or the trunk of a tree or a pole light. Back the trailer watching the tire cover the wet trail. If it's dark a series of little flashlights marking the curve OR rope lights will work... just drive NEXT to them, not over them. Sidewalk chalk in a bright color will work too.
If the only direction you can get in your driveway is a "backwards turn" turning with the roadside on the outside of the turn arc as opposed to the inside - you can do the same thing with the right mirror, it's just a bit more difficult.
Paula
Old 02-10-2014, 05:19 PM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Find a large parking lot and practice.You will find it very easy to back your trailer when you are calm and confident.It will also come in handy in your travels like when you pull into a stop with the only exit being the entrance you just used and now find yourself at a dead end.
I came upon a flooded road in MN a few years ago and it was blocked off with a State highway patrolman telling everyone to turn around.Me with a F350 Supercrew longbox and a 28ft Airstream backed up a half a mile on a narrow county road and found small private drive with trees on both sides turned around and off we went.Had I not been confident with my backing ability and experienced no telling how long we would have been there.
Old 02-10-2014, 05:45 PM   #16
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
I have never heard of using water before, not a bad idea. I have used orange extension cords ,ropes etc. Now I carry a set of cheap orange cones from walmart. My main use is to be able to park square where there are no references
13 Ram 2500 TD
Old 02-10-2014, 06:13 PM   #17
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Same kind of situation happened to us but we needed to do a U-turn right there or spend hours waiting for an accident clean up. Lucky for us we had a single axle and with a little maneuvering and the help of the State Patrol we were on our way. Single axle rigs do respond quicker and are easier to back up than multi axle rigs in short places, despite of what you hear here.
Ahab is offline   Reply With Quote
Old 02-10-2014, 06:17 PM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Whatever you do, under no circumstances watch Desi until you are safely parked. And remember "trailer brakes first".
Old 02-10-2014, 06:29 PM   #19
mariusg78's Avatar
1977 31' Sovereign
Black Diamond , Washington
Images: 21
Go slow. Have one person to guide, and only listen to that one person. They are there more to tell you if you are about to hit something on your blind side. Did I mention to go slow? I back up my 31' uphill slanted into a driveway. If you have nice neighbors that don't park on the street it makes it easier.
OK, so now here is my secret trick that I use when backing. So don't tell anyone
Place both your hands on the bottom of the steering wheel palms up. Grip the steering wheel. Then stick your thumbs out. The direction your thumb is pointing is the direction your rig will go. This is an easy reminder on which way to turn your steering wheel.
Not sure if I mentioned this, but go slow!
Have fun!
mariusg78 is offline   Reply With Quote
Old 02-10-2014, 07:03 PM   #20
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
Best thing to do is slam your had in the door, get mad as hell, hold it flat to the mat and don't look back.
O WAIT! (That was for towing in the mountains)
Backing up....
Drink 3 beers if no one is going to watch or direct...
If Wife is helping add 3 more total of 6
If Neighbors are directing / watching add 3 per neighbor
Ah what the hell just get a 30 pack.
shermantic is offline   Reply With Quote
2014 Bambi 16, Honda Pilot, and 11% driveway Grade ridensmile Tow Vehicles 1 02-01-2014 02:29 PM
Finally I have all 4 awnings back on my trailer perryg114 Awnings 5 07-03-2012 09:05 AM
Back to the Basics Rally, IL, 2012 TinLoaf Forum Rallies & Meet Ups 87 05-04-2012 12:26 PM
Bathroom and back overhead lights out in '72 TW RichHog Lights - Interior & Exterior 3 03-03-2010 09:32 AM
Van Nuys '47 Liner door handle 'hold back' Maybricks Doors & Locks 6 12-23-2009 11:40 AM
