Old 02-10-2014, 05:19 PM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Find a large parking lot and practice.You will find it very easy to back your trailer when you are calm and confident.It will also come in handy in your travels like when you pull into a stop with the only exit being the entrance you just used and now find yourself at a dead end.
I came upon a flooded road in MN a few years ago and it was blocked off with a State highway patrolman telling everyone to turn around.Me with a F350 Supercrew longbox and a 28ft Airstream backed up a half a mile on a narrow county road and found small private drive with trees on both sides turned around and off we went.Had I not been confident with my backing ability and experienced no telling how long we would have been there.
Old 02-10-2014, 05:45 PM   #16
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have never heard of using water before, not a bad idea. I have used orange extension cords ,ropes etc. Now I carry a set of cheap orange cones from walmart. My main use is to be able to park square where there are no references
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-10-2014, 06:13 PM   #17
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Same kind of situation happened to us but we needed to do a U-turn right there or spend hours waiting for an accident clean up. Lucky for us we had a single axle and with a little maneuvering and the help of the State Patrol we were on our way. Single axle rigs do respond quicker and are easier to back up than multi axle rigs in short places, despite of what you hear here.
Ahab is offline   Reply With Quote
Old 02-10-2014, 06:17 PM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Whatever you do, under no circumstances watch Desi until you are safely parked. And remember "trailer brakes first".
Old 02-10-2014, 06:29 PM   #19
mariusg78's Avatar
1977 31' Sovereign
Covington , Washington
Images: 21
Go slow. Have one person to guide, and only listen to that one person. They are there more to tell you if you are about to hit something on your blind side. Did I mention to go slow? I back up my 31' uphill slanted into a driveway. If you have nice neighbors that don't park on the street it makes it easier.
OK, so now here is my secret trick that I use when backing. So don't tell anyone
Place both your hands on the bottom of the steering wheel palms up. Grip the steering wheel. Then stick your thumbs out. The direction your thumb is pointing is the direction your rig will go. This is an easy reminder on which way to turn your steering wheel.
Not sure if I mentioned this, but go slow!
Have fun!
mariusg78 is offline   Reply With Quote
Old 02-10-2014, 07:03 PM   #20
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
Best thing to do is slam your had in the door, get mad as hell, hold it flat to the mat and don't look back.
O WAIT! (That was for towing in the mountains)
Backing up....
Drink 3 beers if no one is going to watch or direct...
If Wife is helping add 3 more total of 6
If Neighbors are directing / watching add 3 per neighbor
Ah what the hell just get a 30 pack.
shermantic is offline   Reply With Quote
Old 02-10-2014, 07:21 PM   #21
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Be sure to do a "driver side back-up" if at all possible. If you are backing into a slot (drive way) that is on the drivers side it will go much smoother than just using the passenger side mirrors. I back a 31' trailer w/ a '97 Ford F350 dually long-bed (53' total length with horrible turning radius) into a single car drive from a narrow road. I have to drive past my home to get the rig turned the other way before I can back in. I've done it the other way too but it was NOT pretty! I agree with previous post, best if the neighbors are not watching...
captmatt is offline   Reply With Quote
Old 02-10-2014, 07:22 PM   #22
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Absoutely, you can do this. I solo. I have a 60 foot normal width driveway that I back into....and at the end of that driveway is a shed I had built for my trailer. Due to space limitations, I have 11 feet between the posts that I back into...that means my 8 1/2 foot wide trailer has to be navigated with barely a foot on either side OR big time expensive bent aluminum. The secret: go SLOW, get out and look at what you are doing. If you are in a rush, do it later. I had never backed a trailer until I bought my brand new Airstream. All this takes is time and practice. I also use aids such as my mirrors, and when I get close to a rear obstruction I put down wheel chocks to back into.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-11-2014, 09:17 AM   #23
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I have a 31' Classic and quite easily back it into my driveway. My home is at the end of a cul-de-sac so it is a little more complicated due to having the island in the center restricting my turning radius of my van. The secret to it and to any backing is to make sure you pull forward from the drive itself. This gives you more room to start your turn for backing with smaller angles which keeps you from having to pivot your trailer at extreme angles. We see this all the time in campgrounds where folks with back in sites start the back in when the rear end of their trailer is at the edge of the site. This causes them to have to go in at an extreme angle. If they would pull another 20 feet past their site, they could start the turn at a gentle angle without the need to do the back and forth effort necessary to correct for an extreme angle back in.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-11-2014, 10:02 AM   #24
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Yes! What jcanavera said exactly!! That's what I do and then usually once it's in the drive it's at a goofy angle so I pull all the way forward where the front of my van is on the opposite side of the street which straightens everything out and then back straight in. It's quick and easy.
Rob
Skatiero is offline   Reply With Quote
Old 02-11-2014, 11:59 AM   #25
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
backing up
My neighbors park across the street from the end of my driveway and my area is not that safe, so I drive the trailer in front first. I put pavers in to make a small parking pad about 3 ft from the edge of the drive. I pull in with a circular motion that ends with the trailer being straight and the SUV at an angle in the driveway. I still have room to get the car into the garage. The trailer takes up about 4.5 ft of the width of the drive and no one can to the hitch to steal it. I just back up to it at about the same angle to hitch up and the trailer is already at the right angle to back out again. joe in Minnesnowda
joqin is offline   Reply With Quote
Old 02-11-2014, 07:07 PM   #26
2014 22' FB Sport
Atlanta , Georgia
Thanks, everyone, for your input. You've given me a lot of support, some great suggestions, and a good deal of foolish self-confidence. I'll report back in once I bring the beast home.
Belbein is offline   Reply With Quote
Old 02-11-2014, 07:33 PM   #27
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my driveway is narrow and so is my street. We plan to leave on street sweeper day [no cars on the street] and come home on a week day when all of the young people are at work. [only a few cars if any]
At my new house, my driveway is wider but the actual area is narrower. I also have to watch out for an in-ground power box. So I bought a "Powermover" trailer dolly.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-11-2014, 07:50 PM   #28
1991 29' Excella
casselberry , Florida
The front receiver hitch is your best bet.
It took me an hour to get my 29 foot in the driveway backing in.
With the front hitch I was able to pull it off the driveway, and push it to the back yard in one try.
korn is offline   Reply With Quote
2014 Bambi 16, Honda Pilot, and 11% driveway Grade ridensmile Tow Vehicles 1 02-01-2014 02:29 PM
Finally I have all 4 awnings back on my trailer perryg114 Awnings 5 07-03-2012 09:05 AM
Back to the Basics Rally, IL, 2012 TinLoaf Forum Rallies & Meet Ups 87 05-04-2012 12:26 PM
Bathroom and back overhead lights out in '72 TW RichHog Lights - Interior & Exterior 3 03-03-2010 09:32 AM
Van Nuys '47 Liner door handle 'hold back' Maybricks Doors & Locks 6 12-23-2009 11:40 AM
