Old 10-25-2012, 06:21 AM   #1
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
Atlanta Area Tow Experts
Andrew T is often mentioned as a towing expert in Ontario. Can anyone recommend someone that is at least competent in the Atlanta area? We would like to have our hitch arrangement adjusted but don't know where to go.
BeachHouse is offline   Reply With Quote
Old 10-26-2012, 05:24 AM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
D-I-Y is about the best way to go. The "CAT Scale" thread is a generic must-read (non hitch specific, overall). CAN AM excels at custom hitch receivers, but a name brand hitch and "ordinary" TV can be set up by about anyone if following hitch and vehicle manufacturer instructions. Videos online as well.
Rough it in at home (level ground) using fender measurements, and then spend a couple of hours at a truck stop using a CAT Scale to dial it in (restore Front Axle to the unhitched weight with the TV loaded for travel values). The scale work is the part which really matters. TV tire pressure, etc, is also from that.
Dealers have no real interest, IMO. They'll sign off as "good enough" a combination that still needs work.
If the Jeep Commander is what you are using, then contact Andrew_T for his insights as well.
Old 10-26-2012, 05:36 AM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
There will be a group of us camping at Hard Labor Creek SP on Nov9-11 if you would like to join us. I am sure collectively we can answer questions for you and help with your setup.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
