03-21-2013, 07:21 PM
#21
1988 32' Excella
Robbinsville
, New Jersey
Originally Posted by Jammer
There has been one publicly reported weld failure of a ProPride hitch resulting in the trailer becoming disconnected from the tow vehicle. Thankfully, no one was hurt, since it took place at low speed and the safety chains were sufficient to control the trailer. Based on the photos of the broken hitch, I believe the failure was due to a defective weld. ProPride has announced no recall and has not answered questions about the extent of the problem or any engineering or production changes they may have made to address it.
This is not true.
Originally Posted by Sean Woodruff
Can I get your link source?
This is one of 2800+ hitch bars on the road. His name is John Rest. This came from BEFORE we had our welding in house.
It was determined that this piece of bar was not properly pre-heated before the weld. The others in this batch WERE as I have followed up with the bars welded on this day and not one has had a problem.
We now have a pre-heat process with an electronic thermometer to bring the part to the proper temperature before any weld is placed on it.
What The Welding Inspector Should Know About Preheating And Postweld Heat Treatment
03-21-2013, 08:44 PM
#22
Contributing Member
Austin (Hays County)
Another fact to consider, that is rarely brought up, is that the Propride hitch limits the angle between the trailer and tow vehicle to about 80 degrees, which complicates parking in certain situations.
I find that the actual maximum turn angle is at least as good with the PP as with my previous Reese. The extra length of the PP (or Hensley) allows the corner of the pickup to safely clear the trailer front.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
03-21-2013, 09:16 PM
#23
2011 27 FB International
Keswick
, Ontario
Hensley
03-22-2013, 04:59 AM
#24
2002 25' Safari
Fountain Inn
, South Carolina
Same case for me with the same truck and trailer, Reese vs PP.
Bud
03-22-2013, 11:03 AM
#25
Wise Elder
2010 30' Classic
South of the river
Originally Posted by Wazbro
This is not true.
I was unaware of Sean's 2011 post which you quoted.
Nonetheless, on advice from people more familiar with welding and metalworking than me, I will be taking my own hitch bar to a welder for an independent assessment and possible re-welding. I have taken some "before" photos and may end up writing up the results of the visit to the welder at some point, if community interest is strong enough to outweigh the difficulty of dealing with what is bound to be a divisive topic.
03-22-2013, 01:31 PM
#26
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Originally Posted by HeadWest
It is now less then a month off of our new 28 International Signature being completed. ... The pluses I see with each are:
Reese Dual Cam
1) Common and pretty simple
2) Does not cover up the hitch coupler on the trailer for moving with other equipment
3) Less expensive
4) Quicker and easier to hitch and unhitch
Propride
1) Sway elimination
2) No holes drilled in trailer a frame
...Thanks!
Most of the posts on here from actual users of either PP and H are very happy. We'd sure like to try one.
Just for devil's advocacy, we didn't have to drill our trailer frame on either of our AS to install the Progressive EQ hitch ... as you indicate with the Reese ...
03-22-2013, 01:37 PM
#27
Oswego
[QUOTE=Jammer;1275925]Hi HeadWest
Jammer,
Do you know where those pictures are? I've never seen them and would like to.
-Rich-
03-24-2013, 07:48 PM
#28
2013 28' International
Bozeman
, Montana
Lots of good info from everyone, I do appreciate it. I wish this was easier but it still is tough knowing what I'll be happiest with in the long run. Obviously safety is first priority along with the less stressful driving.
03-24-2013, 10:38 PM
#29
Wise Elder
2010 30' Classic
South of the river
03-24-2013, 11:12 PM
#30
1978 31' Excella 500
Genoa
, Nevada
Amazing, looks like it went out of the factory with 2 sides welded, 3/16 inch weld X 4 inch of weld, or about 3/4 square inch of weld. Total. Probably 70ksi filler metal, or about 52,000 pound strengt in that weld. What kinetic force does a moving trailer push with when you're stopping? I forget that physics.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
03-25-2013, 12:36 AM
#31
Salem
, Oregon
Hi, that would be scary to have your hitch break like that while traveling.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
03-25-2013, 02:24 AM
#32
Vintage Kin
Fort Worth
I have a Hensley. Today, I'd have the PRO-PRIDE were I starting anew.
The weld failure above is a non-starter, IMO.
And, further up, driver skill -- while important -- is only part of larger perspective and that is risk minimization. Hitch design is part of that, as is hitch set-up (certified scale values in use). Same for type of road, weather, traffic, tires, brakes, etc. All play their part in avoiding loss-of-control accidents.
A PRO PRIDE, trailer disc brakes and state-of-the-art brake controller is a no brainer for starting off right.
03-25-2013, 08:32 PM
#33
Genoa
, Nevada
I'm sure adequate engineering is in place for that weld, just that particular piece didn't get the welding, or the inspection.
NevadaGeo
03-25-2013, 09:59 PM
#34
1969 27' Overlander
SW
, Missouri
The weld on the left has lack of fusion nearly the complete length of the weld. It didn't tie into the stinger at all. The bending stresses were concentrated in the lower weld causing a crack to propagate. You can tell how far the crack got on the bottom weld by where the rust is.
Once the crack weakened enough of the good weld, it was just a matter of time before a high stress event led to a failure. Based on the reported circumstances of the failure, I'm guessing the TV was backing while turned to the right when the stinger failed.
I am a little surprised that the joint isn't beveled more and a multipass weld used to allow for greater penetration and a larger weld. Particularly since the reinforcement has to be ground off to allow for stinger height adjustment. However, with a good weld it's not likely to be an issue.
03-28-2013, 10:59 AM
#35
Small Town
As a former welder / instructor ... I would rate that as a failure due to limited penetration ... a "surface weld" only. In this day and age - most anybody can fire up a mig machine (and call themselves a welder) ... not necessarily properly, however. It is unlikely that the welder responsible for that weld only worked on one hitch. If it was inspected prior to shipment ... all of the welds done by that person while employed there would be suspect and possibly subject to recall ... IMHO.
03-28-2013, 12:07 PM
#36
2012 25' Flying Cloud
Battle Lake
With my first Airstream I wanted a Propride but started with a Equal-I-Zer hitch because the dealer said they would have trouble servicing with out a stinger, I'd have to leave my pickup there. They also sold Equal-I-Zer with dealer commission, but not Propride which offers no dealer commission; instead Propride sells direct to the customer saving you $500+ on similar products. So it was more than the servicing that concerned them.
Not liking the hitch I had, I bought an Andersen hitch. What a great improvement in ride, sway control, weight and ease of use, loved it. Now I find out the Andersen is not compatible with my Airstream hitch coupler, could break the latch and come loose from the ball. Not good, but I could cut off the coupler and weld on a different model. A terrific hitch design, it would probably work, but what if it didn't.
Tired of all this and two long trips coming up (one in two weeks), I spent the bucks to get what I wanted in the first place, a Propride. The Propride and Hensley stand alone, no other hitches provide the safety and ease of towing these do. I choose the Propride because of the excellent reviews by users who have used both. Dealers recommend what suits their business and profits best. Internet forum opinions are of little value unless the poster has experience with both products.
So this is how I came to the long and more expensive route to Propride. It'l be here in a week or so and we'll see how it goes. Hope I'm done buying hitches.
doug k
03-28-2013, 12:10 PM
#37
2013 27' FB International
El Dorado Hills
For those of us without 3/4 or 1 ton trucks, hitch weight is a concern. From what I've read the ProPride or Hensley hitches weigh in at around 220 lbs, putting most Airstreams at or over 1,000 lbs at the tongue. That's a big hit to payload too. The weight of the removable part of the hitch is also a "back pain" issue.
03-28-2013, 12:44 PM
#38
Wise Elder
2010 30' Classic
South of the river
That particular dealer (and probably many others) likes to use a skid loader to move trailers around the lot. They have a Hensley stinger in the skid loader but not a ProPride one. I think my trailer was the first one their service department saw with a ProPride hitch.
The first few times I was there for warranty service they had me leave the trailer in a location where they could work on it without moving it. The last time I was there they asked me to leave the stinger for them to use, which worked out OK.
So now they seem to have it down to a system.
I installed the ProPride in their parking lot after taking delivery of the Airstream. I've never towed it with anything else.
The lighter systems still weigh a little over 100 pounds, so, sure, there's a difference, but it's 120 pounds not 220.
Yes the stinger is heavier than the WD bars on a Reese Dual Cam. Some people have made a handle for the top to make it easier to carry.
03-28-2013, 03:20 PM
#39
Battle Lake
The Propride and the Hensley seem to be equal in performance, so I looked for details, none of which are much by themselves, but begin to add up in favor of the Propride.
Here is a cut & paste from another forum, describing the differences/improvements:
Both the Arrow hitch and the 3P operate through the exact same principle. Towing down the road you wouldn't be able to tell which hitch was on the trailer. The linkage that projects the pivot point was Jim Hensley's original patent. However, over the years Hensley owners voiced many things they'd like to see addressed with any new design. All improvements the 3P has came from listening to the Arrow customers and finding a solution for the problem or complaint. Those improvements are as follows:
The 3P has an adjustable hitch bar to match different tow vehicle and trailer tow heights, instead of a solid piece like the Hensley. This can save the hitch owner some time and $$ in shipping charges when a different offset is needed when switching tow vehicle or trailers.
The hitch bar wedges on the 3P are closer to the hitch bar tabs which moves the effective pivot point even further forward.
The 3P's hitch bar wedges and the hitch box have a greater angle to help in hitching and unhitching without the bar sticking in the hitch head.
The 3P uses a one piece yoke to hold the hitch head square to the front of the trailer instead of the strut bars used on the Hensley. The one piece yoke is not as prone to allow movement as the struts can in some cases.
The 3P hitch requires NO drilling into the frame for installation, the Hensley does in some cases.
The weight distribution jacks sit on top of the frame with the 3P rather than hang on a pin outside of the frame. This can provide better leverage for the spring bars by moving the tail ends of the bars closer together.
The spring bar keeper is a disk rather than a spring loaded keeper. The disk will not wear and allow the spring bar to fall out of the bottom of the head like has been known to happen with the Hensley.
The steel is properly pre-treated for powder coating. This will help prevent against chipping and rusting, which Hensley hitches are known for.
The control links on the 3P are thicker.
The hitch box on the 3P has been reinforced to eliminate warping of the top edge of the box.
The main unit is 20# lighter because there is no unnecessary orange steel.
doug k
03-28-2013, 03:52 PM
#40
2002 25' Safari
Fountain Inn
, South Carolina
I have owned an Equalizer, Reese dual-cam, and a Propride. From my experience the Equalizer head weighs more and is much more difficult to lift and mount to the truck as compared to the Propride stinger. The Reese head may weigh less than the Propride stinger. I have not ever weighed the hitch heads and stinger individually... just estimating from experience in using the three different hitches.
Bud
