Old 05-26-2017, 09:53 PM   #1
Durango , Colorado
Anyone using a 2017 Raptor as a tow vehicle?
I love the new Ford 2017 Raptor with the 450 HP 550 lb-ft torque HO v6 ecoboost engine.
Supposedly this vehicle is rated to tow 8000 lbs with a weight distribution hitch and maximum of 800 lbs of tongue weight.
I have a 2015 International Serenity 27FB with a pro pride 3 hitch.
I think it is within specs to use a Raptor as the tow vehicle but obviously I am worried about being that close to maximum considering that the 27FB is rated to 7600 lbs GVWR and has a hitch weight of 791 lbs.
Has anyone here tried using the new Ford Raptor for towing yet? I would be interested to hear your results. Specifically, I am wondering if the frame, brakes, and towing abilities are fully capable to handle a 27FB without having a death grip on your steering wheel.
I saw a towing video demonstration on youtube where they were testing the Raptor performance towing 7000 lbs. and they appeared to be pleasantly surprised. But I would rather hear from someone with first hand knowledge.
RVDreamer is offline   Reply With Quote
Old 05-27-2017, 02:15 PM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
I used to have a 2014 Raptor. The problem with the Raptor is payload. In 2014 it was 1200 pounds. The problem is the soft off road suspension. I traded it for an Escalade with almost 1600 lbs payload.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-27-2017, 03:34 PM   #3
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
My 27FB tongue weighs, per sureline scale, 950 lbs.
kscherzi is offline   Reply With Quote
Old 05-27-2017, 04:16 PM   #4
FCStreamer's Avatar
Add a driver and passenger and you'll likely exceed payload. Never mind luggage or other passengers. I've seen some folks modify their Raptors with air bags to prevent it from bottoming out, but I decided I didn't want to push my luck.
Old 05-27-2017, 05:57 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
IMHO The off road suspension will ineffective at damping road imperfections quickly enough; allowing for too much porpoising and suspension travel. Also adding weight to the back of a sofly sprung Raptor would change the ride dynamic considerably at either end of the truck. I don't know if there would be enought adjustment in a weight distribution hitch to balance that out. It's the same problem that people face with Toyota Landcruisers, but the Toyota's and Jeeps arn't as softly sprung as a Raptor.
You want your tow vehicle to absorb potholes, ridges and undulations with the least amount of hitch movement possible but still have a decent ride.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 05-28-2017, 03:22 AM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Well said above.
A vehicle compromised in favor of service on unpaved roads is just that: Compromised.
Wrong tires, wrong suspension tuning, wrong vehicle height.
In other words, an already bad design (any truck) is now worsened.
A pickup is the vehicle most likely to itself be the cause of a loss of control accident. It's less stable than these trailers. It is the weak link.
A pickup modified not for roadworthiness, but for off-road will be that much worse. 4WD already makes poor poorer.
Good highways and fair weather deceive many into believing a pickup a good tow vehicle.
Old 05-28-2017, 05:45 AM   #7
Gainesville , Florida
After reading these comments just remember a lot of this info is opinion, some with an agenda.
Old 05-28-2017, 08:57 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It's not perfect.
But assuming you are getting a Raptor to pull your Airstream reasonable distances so you can spend some time exploring the back country with your truck, the first priority is the truck that can also comfortably tow your Airstream. Concern yourself less with GVWR/payload and more with axle ratings and weight distribution for safest towing. You already have a ProPride hitch on there, it's not going to be a death grip going down the road. It's accident avoidance and loss of control where pickups fail.
If you were getting a Raptor to tour America's highways day after day, there are better choices.
Low center of gravity for stability, full independent suspension for wider suspension-to-frame connection and less body roll, short rear overhang relative to wheelbase for sway mitigation, no frame flex or twist; a few design elements to start with for a good towing platform. Pickups in general don't do well, some Raptor off-road features take it farther away from the ideal.
So it's not always about the ideal, sometimes it's about how you will use it.
Doug and Cheryl
Old 05-28-2017, 12:44 PM   #9
2019 25' International
Washington , Washington, D.C.
Buy the Raptor with the 3.5L V6 Ecoboost + Max Tow Package and you'll be gold.
PatLee is offline   Reply With Quote
Old 05-28-2017, 12:53 PM   #10
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Just add a set of Firestone air bags and don't worry about soft rear suspension.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 05-28-2017, 01:16 PM   #11
FCStreamer's Avatar
They don't make a Raptor like that.
Old 05-28-2017, 01:33 PM   #12
2003 30' Classic
Fresno , California
I just don't get it....towing on the edge or even over the edge makes absolutly no sense to me. I have knowledge of people who push the limits and have a wreck only to find their insurance company won't cover it because of the running at or iver limits. Do yourself and all the other drivers on the road a favor...get a proper tow vehicle. Lives matter.
ldireland is offline   Reply With Quote
Old 05-28-2017, 03:44 PM   #13
dkottum's Avatar
Air bags can be useful for leveling the vehicle when hauling heavy loads with no trailer attached, but they do nothing for weight distribution. That is the task of a capable, properly set up weight distribution hitch when towing a heavy trailer.
I think many people think a bigger truck is needed when they have stability problems with the one they are using. The bigger truck with diesel engine sets the steering axle firmly on the ground. They could have done the same thing with a good weight distribution hitch setup, and enjoyed the vehicle they already have. Safely. The Airstream will just follow rather than try to control the combination.
In other words, what you have may well be a proper tow vehicle.
Doug and Cheryl
Old 05-28-2017, 03:50 PM   #14
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
He already has a pro pride distribution hitch. No airbags won't help with weight distribution, no one said it would. Yes airbags will stiffen the ride of a vehicle whether it is towing or not. Air bags will stop the porpoising that soft off road suspension is known for while towing. Know this for fact as I have two trucks running firestone bags.
1973Argosy is offline   Reply With Quote
Ford Raptor 6.2L as Tow Vehicle BoldAdventure Tow Vehicles 24 01-05-2016 10:58 PM
Any Ford F-150 Raptor owners pulling Airstreams? ZBoater Tow Vehicles 13 11-16-2015 08:34 AM
Ford SVT Raptor dkottum Tow Vehicles 4 03-29-2010 08:50 AM
