I just bought a 2004 Ford Excursion to tow my 34 fter.
I am using the same Reese dual cam sway control system I have used to tow this trailer with for 12 years behind a Suburban. The only significant difference is the tires on the Excursion. They are 305/50/20 ziex stz04 tires. I was quite surprised at the amount of sway and the fact that even small cars would affect the sway.
The rig handled well on truly flat roads, IE concrete or new asphalt, but was effected by passing vehicles on any road that had the least amount of grooving from heavy equipment.
My question is, has anyone towed with an Excursion with the original 265 75 16 tires and not had a similar experience. In which case the tires will go.
I have noticed on other forums that most towing 30' plus trailers with the Ex are using a Hensley or modifying the Ex with after market radius rods to tighten up the suspension to prevent wallowing. Tires too may be an issues. Others here may know best.
__________________ Airstreams..... The best towing trailers on the planet!
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein 2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
We towed several 34's for years with an Ex (diesel), and I still think the Ex might be my favorite all time vehicle. We did use a Hensley, and I couldn't tell you the first thing about what tires we had. But with what I can only presume were standard tires, and using the Hensley, we towed flawlessly - for many thousands of miles.
The Slowsky's
2008 27FB International Ocean Breeze (Wanda Fa)
2008 King Ranch Crew Cab F250 4X4 w/6.4L Diesel
Hensley Hitch AIR 9623
Former 2005 34' Classic Limited with Slide Out (Vickie)
Former 1999 34' Classic Limited
34' Airrstream pulled by 1/2 ton truck. That's a really tight fit. It's not within my comfort zone.
Moosetags,
I thought the Excursion was a 3/4 ton truck basis, since it originally came with the V10 gas or V8 diesel, and the Expedition was a 1/2 ton truck basis. Am I confused.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Best Truck tires I've ever had. Now at 53K with no issues. I keep mine at ~65 PSI. No sway from tires - has some sway with Equal-i-Zer hitch in some condtions, but now with Hensley rock solid.
In addtion, I've added/upgraded the suspension as follows:
I know a guy that pulls a 34', with a 2001, V-10 4x4 standard hitch no problems at all. I would check a couple of things:
1. Tire size, The Excursion came with 265/75/16. I can tell you first hand, put a larger tire on that truck and you will get more roll, done it, did it, got it. I went up just one size and 285's and got more roll, never again
2. Is the hitch setup correctly for the Excursion? My guess, the Excursion is a little higher than the Surburban and changes may need to be made in the hitch.
Paul Waddell Region 2 VAC Guy WDCU "Past Prez" (In the words of Richard Nixon "You won't have me to kick around anymore!")
I've been towing my 34' with an '05 Excursion PSD for a year and a half now. I have the equilizer hitch w/d set up. My first towing experience was a very soft, mushy tow, and the AS pushed the Ex around the curves. Oh, the Ex came with the heavy duty towing option. I learned that that did not include a rear anti-sway bar, so in went a helwig anti-sway bar. I also added rear air lift suspension in lieu of adding an addition leaf spring. Now the Excursion controls the AS, and it's a great tow. I do notice I get more draft sway when a semi passes me than when I towed with the F250, but the F250 was a long wheel base. I have BFG all terrain tires, but I don't think they have impaired the towability of the Excursion.
The Excursion comes with a soft suspension so that the ride could compare to the Surburban. If you stiffen it up a bit, as I and others have, I think you'll notice a dramatic change in your ride.
____Tom
Blog: www.travelpod.com/members/wbcci1529
'04 34' Classic S/O lounge, dome king, twin a/c, faux fireplace to keep the wife warm , equa-li-zer, prodigy, 4 birds, cat, dog - no kids allowed!
'05 Excursion 4x4, 6.0 PSD, magnaflow, helwig anti-sway, air lift springs.
The trailer and hitch were set up to the Excursion before the trip, trailer dead level. I had only set the WD by measurements not scales.
A review of the system after my post showed the drivers side saddle wa about 1/2 way off the cam because the u bolts had slipped back on the tongue. This might amplify the start of any sway rather than retard it. I corrected that.
I took the rig the the cat scales and found I only had 40 lbs., not a lot to retard any sway, added to the front axle, this has been increased.
The truck does have a rear sway bar. While the Excursion has MUCH SOFTER ride than my Suburban, 1/2 tow Excursion verses 1 ton on the Suburban I am not questioning roll or read axle steering just sway induced by passing vehicles.
I will most likely put a set of Michelins on before towing next weekend.
Current weights
truck front axle 4160
truck rear axle 3900
truck front axle with trailer before readjusting 4200
truck rear axle with trailer before readjusting 4440
I was quite supprised that a 34 footer only added 580lbs to the truck
The scale I went to had a rule that you could not disconnect the trailer on the scale so I could not get a good dry tongue weight. A very busy scale in centeral NJ.
