Old 05-12-2015, 10:47 AM   #15
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
It is like insurance you don't need it until you do.
urnmor is offline   Reply With Quote
Old 05-12-2015, 10:50 AM   #16
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Originally Posted by martin300662 View Post
I do always have a small 'chuckle' to myself when the number one rated TW in the UK/Europe would not be seen as adequate to tow the smallest trailer in the US
Volkswagen Passat Estate | Practical Caravan
Trailers in Europe are a different design then in the US. Much lighter tonque weights for one. What you see is often dictated by costs and restrictions and not by smarts or safety.
jtwind is offline   Reply With Quote
Old 05-12-2015, 11:02 AM   #17
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
And it is amazing how having gas prices a quarter of Europe is used to justify that something 'bigger' is needed. I have no issue with a 'belt and braces' approach, but that doesn't mean you 'need' both.
martin300662 is offline   Reply With Quote
Old 05-12-2015, 11:08 AM   #18
ericpeltier's Avatar
Superior , Colorado
I just drove home 220 miles with a 33' Streamline with no WD, no SC, and no brakes (!!!). With high crosswinds and over Raton Pass (7800'). It towed fine, attached to my Armada.
That being said, I will add WD and SC. Because why not. Cheap Insurance for the situation where my brakes fail, a semi overtakes me by 20mph, and I've drifted very close to said semi. It all adds up. My $0.02. YMMV
ericpeltier is offline   Reply With Quote
Old 05-12-2015, 11:09 AM   #19
Gainesville , Florida
The big Avions gave relatively low tw. My owners manual for my 30p mentions either reese or eazlift wd hitches withe the added on sway control. This was in 1984. I have towed mine on the ball with a one ton and I prefer to use a little wd in conjunction with the sway bars, I use two. I have an eazlift. Your 34 footer is listed as only I think 750 tw, probably less than that the way yours was set up. Jim
Old 05-12-2015, 11:13 AM   #20
2018 33' Classic
Newport , Pennsylvania
If you can afford an Airstream you should be able to buy a good hitch. but if not its your life ......
EarlM is offline   Reply With Quote
Old 05-12-2015, 11:15 AM   #21
gwg
gwg's Avatar
2015 30' Classic
Glen Mills , Pennsylvania
Just using a ball also. 30' Classic / 2014 Ram 3500 Cummins Diesel
gwg is offline   Reply With Quote
Old 05-12-2015, 11:20 AM   #22
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
We towed the Caravel for many years on the ball, but used a friction sway control as well. We didn't feel weight distribution was needed on our E150 van, as the tongue weight was so low (about 250#). It towed great.
When we switched to the Flex you could see how much the rear went down with the tongue weight on it, so we added WD. Whatever it takes to get everything nice and level.
Stephanie
Old 05-12-2015, 11:22 AM   #23
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Totally agree. Run a one ton F350 Diesel, could easily do without equalizer, but don't.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-12-2015, 11:24 AM   #24
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I towed naked ball until I sold the freightliner, didn't need WD or SC. Truck weighed 11,500 #'s, EB @ 7,800 #'s, pix in my gallery.
I didn't want to spend for two WD hitch setups unless I needed it.
My newer downsized truck I bought a Blue ox setup before I rolled again.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 05-12-2015, 11:25 AM   #25
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There are infinite possibilities, permutations and variables encountered in the real world.
The recommendations for "WD"(weight distribution), sway control/ elimination, braking, tires, loading, weighing, etc.. Are nearly as diverse.
As an example, a "screen door" is a marvelous invention!.. But it really is a poor APPLICATION to install one on a submarine. Same with a diesel vs gas vs dually vs Smart car comparison and their APPLICATION. Where I have towed 10,000 pounds with a 1971, 6 cylinder, manual transmission Chevy Chevelle, And survived without trashing the car,(but the clutch, brakes and rear axle complained), trailer or people, I have realized that was NOT a good thing to do.
So, now my TV (design specs) more closely match the work I do with it. Better brakes, drivetrain, suspension and anti-sway WD hitch. (Side note: My "towing experience" has greatly improved. )
As mentioned above, it is your "choice"... You don't have to "over compensate" my lack of manliness like I am. But, I FEEL I am safer and less of a threat to others I share the road with.
Old 05-12-2015, 11:25 AM   #26
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I use ball and sway bar only now. Last year I used Reese WD and sway. My 2500 tv was to much for the Bambi, I bent my a-frame almost 2" and had to have it replaced for very big $$$$$. My Tab and teardrop were ball only, but I had a 1500 suburban originally when I purchased the Airstream,which is why I had the Reese.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 05-12-2015, 11:35 AM   #27
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Ball only for me.. Seen more WD hitches set up wrong than right.. I found with ours that it tended to bind up on uneven ground too much. We like to go off road as much as possible and for us it just gets in the way.
Everyone is right,, proper loading of your trailer is important no matter if you pull with the ball or some high dollar hitch system.. Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 05-12-2015, 11:48 AM   #28
1966 20' Globetrotter
2008 23' International
Cedar Falls , Iowa
Send a message via AIM to hahnstead
I towed my '66 Globetrotter on just the ball for about ten years before I picked up a used Reese hitch with weight distribution bars. I haven't noticed much difference, but I feel a little more confident with my setup now. Never had any trouble before or since.
Hahnstead Airstream Park
hahnstead is offline   Reply With Quote
Just a 2" ball! 1966air Towing, Tow Vehicles & Hitches 4 03-09-2014 05:06 PM
Tow Ball Size LaurenAir Hitches, Couplers & Balls 13 05-30-2011 06:58 PM
What Size Tow Ball On 77 Argosy 22? Zenflyr Hitches, Couplers & Balls 2 04-01-2008 11:26 AM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
tow ball size iguana Hitches, Couplers & Balls 2 10-03-2002 11:39 AM
