Old 05-24-2015, 08:07 PM   #15
2015 25' FB Flying Cloud
Madison , Wisconsin
Just got back from the first excursion in our new 2015 25 ft FC FB. All went well in large part due to all of the reading and ideas from the forums. One thing that could have gone better was leveling, and it has me searching and reading some more.
We were in sandy soil and when I drove up onto leggo blocks they just shifted and came apart. The second try was on a 2x10 board we use at home. However the board shifted, popped up, hit and broke the cover on the storage tube. duh. Third try on the same board we ended up perfect.
Comments? Thoughts? Anyone ever just dig a trench in sandy soil when you need "a board thickness"? The Andersen levelers look pretty neat but seem to have issues in sandy soil also?
trakker is offline   Reply With Quote
Old 05-24-2015, 08:13 PM   #16
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
For soft dirt I carry a couple of 1X10X2ft to put under the Levelers or blocks. So far that has worked.
MICHAEL
Old 05-24-2015, 08:33 PM   #17
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Originally Posted by peetoe View Post
Bold Adventure.
I may be wrong. With mine I've been putting the smaller red chalk under the curved portion for support. I think as a whole there worth the money and seem bomb proof.
That's funny, see here: http://www.airforums.com/forums/f457...ml#post1608702
Everyone told me I was doing it wrong.
I am sure either way is fine.
As for chocking the other side, I use an X-Chock Amazon.com: X-Chock Wheel Stabilizer - Pair - One Handle - 28012: Automotive
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-24-2015, 09:02 PM   #18
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Like the others, Anderson's are great. I put a line on mine at 1", 2", and 3" lift (4 is max). I read the number of inches at my desired location from a Hopkins level and just back (or pull) to the desired position. Oh, and yes, I still have the old blocks to put under the Andersons in soft dirt or sand. I chock the other end of the axle with conventional chocks.
The Ice Man is offline   Reply With Quote
Old 05-24-2015, 09:05 PM   #19
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
For Leveling, using 1/2" plywood and plastic blocks under wheels. The plywood spreads the load on sandy/ loose soil. Also, the plastic tends to NOT slide on wood where it might on cement. Next, plastic sandwiched with plywood for stabilizers.
Now, when you get "close" on the level, I use screw jack stands. It really tightens up the trailer from bouncing.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-25-2015, 07:26 AM   #20
Madison , Wisconsin
thank you all for the comments and hints!
What to use as leveling blocks flint Jacks, Stabilizers, Lifting and Leveling 34 06-25-2012 07:49 AM
Alternative to leveling blocks tschat Jacks, Stabilizers, Lifting and Leveling 18 06-30-2011 07:54 AM
"Lego" leveling blocks--bad experience! Kistler Jacks, Stabilizers, Lifting and Leveling 9 08-28-2003 05:42 AM
