Old 12-10-2016, 11:59 AM   #1
2010 27' FB Classic
N/A , Texas
Anybody use a Hitch Grip?
I'm thinking of ordering a Hitch Grip to aid me in removing the hitch at campsites when stopping for a couple of days in one place. I hate to waste money buying stuff unless it really is helpful. It seems this tool would make things a little easier. I'd be interested in hearing what you think about this idea. Helpful item, or just another gizmo? Anyone use one?
Here is a Camping World link for the item and has a short video with it. I realize the price is cheaper elsewhere but they do show it in the best way.
http://www.campingworld.com/shopping...itchgrip/75569
Old 12-10-2016, 12:35 PM   #2
2014 25' Flying Cloud
Temple , Texas
I use one, reduces grease stains and a lot easier on my back
2014 Flying Cloud 25FB
2016 Ram 1500
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 12-10-2016, 12:42 PM   #3
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
When I got old, I bought one. It works as advertised.
The Ice Man is offline   Reply With Quote
Old 12-10-2016, 12:42 PM   #4
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . I have one, but really, removing the stinger is NOT that hard. You know what they say, the difference in men & boys is the price of their toys. . . ! regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 12-10-2016, 01:34 PM   #5
2007 22' International CCD
For my ProPride stinger, I just grab with a pair of sturdy gloves and set it in a corner of the garage.
Old 12-10-2016, 02:24 PM   #6
Hiwheel Joe's Avatar
1984 27' Sovereign
Oklahoma City , Oklahoma
Wonder if it would work on Airsafe hitch? About 80 pounds and top heavy.
Hiwheel Joe is offline   Reply With Quote
Old 12-10-2016, 02:36 PM   #7
2005 30' Classic
Burlington , Ontario
I made a simple one for handling the Hensley stinger in and out.
It is just a piece of 2"x2" wood maybe a foot long with a hole drilled through each end.
A short loop of rope hangs from the two holes. When i carry the stinger around one loop is over each and and the wooden bar becomes a carrying handle.
In one of the loops I have a snap connector thing just to make it easy to unhook that loop and remove the gadget once the stinger is into the truck receiver.
Probably not really necessary but cost me nothing and makes handling the stinger cleaner and easier. I do have some spinal osteoarthritis brought on by a fracture verterbrae about five years ago, so I think it is wise for me to use aids like this.
Very easy to find the balance point for lifting the stinger and that helps.
Brian.
Old 12-10-2016, 02:39 PM   #8
2015 25' FB Flying Cloud
Eugene , Oregon
I use an Equalizer hitch and I love using the Hitch Grip! I was quite skeptical of another gadget but an older friend had one and recommended it to me. I used to get back aches removing the hitch (maybe because I had to bend down more than when using the Hitch Grip....not sure) and now I don't.
Meeks is offline   Reply With Quote
Old 12-10-2016, 03:00 PM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Just for grins I picked one up for $5 at the International. I have to use it backwards as designed because the stringer gets in the way. It works but not as well as used properly I suspect.
MICHAEL
Old 12-10-2016, 03:14 PM   #10
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I use a Hitchgrip on my Equalizer head with my 2 1/2" shank for my Ram 2500. Since the shank is so heavy I use it this way. To make it easier I purchase a dolly with wheels from Harbour Freight so I can wheel it up to the truck then only have to lift a short distance.
http://www.airforums.com/forums/f464...ml#post1689935
http://www.airforums.com/forums/f464...ml#post1852683
Kelvin
Old 12-10-2016, 04:41 PM   #11
RxGuy's Avatar
2010 27' FB International
Bois Blanc Island , Michigan
That's what I do too.
RxGuy is offline   Reply With Quote
Old 12-11-2016, 10:44 AM   #12
2010 27' FB Classic
N/A , Texas
I ordered one. Thanks for the comments!
Old 12-11-2016, 10:52 AM   #13
2004 22' International CCD
Port Orchard , Washington
I use mine with my equalizer hitch. Makes things easier.
inthralled is offline   Reply With Quote
Old 12-11-2016, 11:01 AM   #14
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I have an Airsafe, and have used it for the past 7 years. I tried a Hitch Grip, and it just doesn't work well. So, I built a small dolly, and that works just fine. Put it under the Airsafe when I'm removing it from the receiver, and wheel it into the garage. Make it a lot easier for this old geezer...
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Clecos grip range rowdyATX General Repair Forum 2 04-30-2015 03:05 PM
Anyone tried diamond or coin grip rubber flooring? tvanwave Floor Finishes 6 11-27-2010 11:43 AM
Rivet Grip Strength monocoque Ribs, Skins & Rivets 10 04-12-2008 09:58 PM
Anybody use the chat room? kitchenclose Off Topic Forum 6 05-04-2006 02:24 PM
anybody use this guide to free campgrounds? Boondocker On The Road... 7 01-02-2006 01:05 PM
